2017-11-08, 14:54
I will take a look at it in the next few days and let you know what I find. It sounds like the connection to KODI is no succeeding.
$dll(if,1,$dll(kodi4smartie,7,XBMC.GetInfoLabels,Player.Title)#,$dll(kodi4smartie,7,XBMC.GetInfoLabels,System.CurrentWindow)#$dll(if,1,$dll(kodi4smartie,7,XBMC.GetInfoLabels,MusicPlayer.Artist)#,#$dll(kodi4smartie,7,XBMC.GetInfoLabels,MusicPlayer.Artist) - )$dll(kodi4smartie,7,XBMC.GetInfoLabels,Player.Title)$dll(if,1,$dll(kodi4smartie,7,XBMC.GetInfoLabels,MusicPlayer.Album)#,# [$dll(kodi4smartie,7,XBMC.GetInfoLabels,MusicPlayer.Album)]) )
$dll(if,1,$dll(kodi4smartie,7,XBMC.GetInfoLabels,Player.Title)#,$dll(kodi4smartie,7,XBMC.GetInfoLabels,System.CurrentControl)#$dll(kodi4smartie,7,XBMC.GetInfoLabels,Player.Time(h:mm:ss))$dll(if,1,$dll(kodi4smartie,7,XBMC.GetInfoLabels,Player.Duration)#,#/$dll(kodi4smartie,7,XBMC.GetInfoLabels,Player.Duration(h:mm:ss)))
$dll(Kodi4smartie,2,,)
$dll(Kodi4smartie,1,,) $CustomChar(1,0,14,21,23,17,14,0,0)$Chr(176)$Time(hh:nn)
(2017-11-12, 22:05)skite2001 Wrote: [ -> ]Hello.You probably need to enable something in the config file. Try the following section. You might need to turn on logging, reproduce your issue and see what is shown in the log file in order to display the correct character. I only can display what is given to me.
I really, really like this plugin and it works very good with just 1 annoying bug..hope it could be fixed...
I'm from Germany and got the "ä, ö, ü" letters. If i write some text directly in lcd-smartie the letters works as they should but it seems that kodi or the plugin doesn't.
Look my screenshot:
both should be correctly called "Bluträcher" instead of the chinese thing.
Same happens if i'm at the mainmenu which is called "Hauptmenü" -> the "ü" is again replaced by this chinese character
my code:
Code:$dll(if,1,$dll(kodi4smartie,7,XBMC.GetInfoLabels,Player.Title)#,$dll(kodi4smartie,7,XBMC.GetInfoLabels,System.CurrentWindow)#$dll(if,1,$dll(kodi4smartie,7,XBMC.GetInfoLabels,MusicPlayer.Artist)#,#$dll(kodi4smartie,7,XBMC.GetInfoLabels,MusicPlayer.Artist) - )$dll(kodi4smartie,7,XBMC.GetInfoLabels,Player.Title)$dll(if,1,$dll(kodi4smartie,7,XBMC.GetInfoLabels,MusicPlayer.Album)#,# [$dll(kodi4smartie,7,XBMC.GetInfoLabels,MusicPlayer.Album)]) )
(2017-12-01, 18:46)eddedrukker Wrote: [ -> ]no answer yet, not found the problem?For some reason I did not get an update in my email for your response. The problem is that kodi is not passing the title to me. It used to. It got broken somewhere in an early 17.x release. I was trying to write up a bug but didnt have the time to figure out how to do it. Once day once I get sometime I will write up a bug to see if it can get fixed.
hope you can fix it
gtrz ed
(2017-12-04, 23:14)Jakester34 Wrote: [ -> ]ok we wait thankx for the answer(2017-12-01, 18:46)eddedrukker Wrote: [ -> ]no answer yet, not found the problem?For some reason I did not get an update in my email for your response. The problem is that kodi is not passing the title to me. It used to. It got broken somewhere in an early 17.x release. I was trying to write up a bug but didnt have the time to figure out how to do it. Once day once I get sometime I will write up a bug to see if it can get fixed.
hope you can fix it
gtrz ed
