Full Version: No space left on device
I'm running an issue:
I was using Lily USB creator using the 14.0 ISO image of KodiBuntu to create a USB key with Kodi
I boot my PC using that USB using Persistence Mode.
To get the latest Kodi 14.2 I was run:
sudo apt-get update
sudo apt-get upgrade
but the second failed with No space left on device.
Any advise?
Halof
your userdata is probably full and or the apt-cache
sudo apt-get clean
will do one part but if userdata is full I suggest you use http://forum.kodi.tv/showthread.php?tid=158373 with
python ./teexturecache.py P
The try running R and Xd for maximum effect.
That also to say if you plan on running it from a usb drive permanently you will need to keep an eye on these areas or get a bigger usb drive.
