I use a raspberry pi but i dont know if i should put this thread there cause is a debian package issue.
My problem is:
I would like to use the kodi-send command like i used to with xbmc-send in previous versions.
i have installed the
sudo apt-get install kodi-eventclients-kodi-send
but no kodi-send was installed, the only files that it has are:
/usr
/usr/share
/usr/share/doc
/usr/share/doc/kodi-eventclients-kodi-send
/usr/share/doc/kodi-eventclients-kodi-send/copyright
/usr/share/doc/kodi-eventclients-kodi-send/changelog.Debian.gz
am i trying to install the wrong package? i have also tried to install another package:
sudo apt-get install kodi-eventclients-xbmc-send
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package kodi-eventclients-xbmc-send is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'kodi-eventclients-xbmc-send' has no installation candidate
Can someone give me any help?
Cheers,
hespanhol
is it still called xbmc-send by any chance? (even if the package was renamed to kodi-send)
(2015-04-09, 12:02)Memphiz Wrote: [ -> ]is it still called xbmc-send by any chance? (even if the package was renamed to kodi-send)
No. The /usr/share files are the only ones in that package and in /usr/bin i dont have any xbmc-send neither kodi-send
I've pinged our packager ...
this doesn't look an official ubuntu package done by us.
this is how it looks like on ubuntu with our PPA:
$ dpkg -L kodi-eventclients-xbmc-send
/usr
/usr/bin
/usr/bin/kodi-send
/usr/share
/usr/share/man
/usr/share/man/man1
/usr/share/man/man1/kodi-send.1.gz
/usr/share/doc
/usr/share/doc/kodi-eventclients-xbmc-send
/usr/share/doc/kodi-eventclients-xbmc-send/changelog.Debian.gz
/usr/share/doc/kodi-eventclients-xbmc-send/NEWS.Debian.gz
/usr/share/doc/kodi-eventclients-xbmc-send/copyright
whats the output of:
apt-cache policy kodi kodi-eventclients-xbmc-send
workaround: if you have a proper kodi-eventclients-common package(must contain /usr/share/pyshared/kodi/xbmcclient.py), you can just download
https://github.com/xbmc/xbmc/blob/master...di-send.py
If xbmcclient is missing, you can download
it as well and put it in /usr/share/pyshared/kodi/
Sorry, dont know why i didnt get notification about your reply.
This is what i get when i execute that command.
sudo apt-cache policy kodi kodi-eventclients-xbmc-send
kodi:
Installed: 2:14.2~git20150311.e7ba06f-1wheezy
Candidate: 2:14.2~git20150311.e7ba06f-1wheezy
Version table:
*** 2:14.2~git20150311.e7ba06f-1wheezy 0
100 /var/lib/dpkg/status
2:14.1-1~wheezy 0
500 http://archive.mene.za.net/raspbian/ wheezy/contrib armhf Packages
500 http://archive.raspberrypi.org/debian/ wheezy/main armhf Packages
kodi-eventclients-xbmc-send:
Installed: (none)
Candidate: (none)
Version table:
According to you i should be installing the kodi-eventclients-xbmc-send instead of kodi-eventclients-kodi-send ?
cat /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
am i missing any sources so i can install the correct package?
Here are the contents of the packages:
sudo apt-file list kodi-eventclients-common
kodi-eventclients-common: /usr/share/doc/kodi-eventclients-common/changelog.Debian.gz
kodi-eventclients-common: /usr/share/doc/kodi-eventclients-common/copyright
kodi-eventclients-common: /usr/share/pixmaps/kodi/bluetooth.png
kodi-eventclients-common: /usr/share/pixmaps/kodi/mail.png
kodi-eventclients-common: /usr/share/pixmaps/kodi/mouse.png
kodi-eventclients-common: /usr/share/pixmaps/kodi/phone.png
kodi-eventclients-common: /usr/share/pyshared/kodi/__init__.py
kodi-eventclients-common: /usr/share/pyshared/kodi/bt/__init__.py
kodi-eventclients-common: /usr/share/pyshared/kodi/bt/bt.py
kodi-eventclients-common: /usr/share/pyshared/kodi/bt/hid.py
kodi-eventclients-common: /usr/share/pyshared/kodi/defs.py
kodi-eventclients-common: /usr/share/pyshared/kodi/ps3/__init__.py
kodi-eventclients-common: /usr/share/pyshared/kodi/ps3/keymaps.py
kodi-eventclients-common: /usr/share/pyshared/kodi/ps3/sixaxis.py
kodi-eventclients-common: /usr/share/pyshared/kodi/ps3/sixpair.py
kodi-eventclients-common: /usr/share/pyshared/kodi/ps3/sixwatch.py
kodi-eventclients-common: /usr/share/pyshared/kodi/ps3_remote.py
kodi-eventclients-common: /usr/share/pyshared/kodi/xbmcclient.py
kodi-eventclients-common: /usr/share/pyshared/kodi/zeroconf.py
kodi-eventclients-common: /usr/share/python-support/kodi-eventclients-common.public
i guess this one is right;
sudo apt-file list kodi-eventclients-kodi-send
kodi-eventclients-kodi-send: /usr/share/doc/kodi-eventclients-kodi-send/changelog.Debian.gz
kodi-eventclients-kodi-send: /usr/share/doc/kodi-eventclients-kodi-send/copyright
and this one is not
