Full Version: [Preset] Woofer.vtx
Hi!
This is my first preset. I hope you like it.
PHP Code:
// woofer.vtx
// Author - morte0815
float angle 0;
void Init()
void Quad(float xfloat yfloat zfloat widthfloat tu_u,float tv_lfloat tu_b float tv_r)
gfxBegin(PRIM_QUADLIST);
gfxTexCoord(tu_utv_l);
gfxVertex(x,y,z);
gfxTexCoord(tu_btv_l);
gfxVertex(x+width,y,z);
gfxTexCoord(tu_btv_r);
gfxVertex(x+width,y+width,z);
gfxTexCoord(tu_utv_r);
gfxVertex(x,y+width,z);
gfxEnd();
float Length(float xfloat y)
  return
Sqrt(x*x+y*y);
void Render()
  if (
BASS>0.5f)angle += TIMEPASS*5;
  if (
BASS<0.5f)angle -= TIMEPASS*5;
gfxTranslate(0025.0f);
gfxRotate(-100,1,0,0);
gfxRotate(angle,0,0,1);
gfxSetTexture(TEXTURE_ALBUMART);
    for (
int i = -1010i++)
    for (
int j = -1010j++)
      if (
Length(i,j) <= 10)
float height=(Length(i,j)/10.0f*BASS);
height+=((10.0f-Length(i,j))/10.0f*TREBLE);
height+=((5.0f-Length(i,j))/10*MIDDLE);
Quad(i,j,height,1,(i+10)/20.0f,(j+10)/20.0f,(i+1+10)/20.0f,(j+1+10)/20.0f);
gfxEnd();
Now some Questions:
Is there a manual with all functions listed?
How do the environmentmaps work?
CYA Morte
YEYH for u!
only 'guide' so far is this => http://forum.xbmc.org/showthread.php?tid=22365
Please feel free to add it to our online-manual (WIKI)
Thanks Morte! Better docs are coming.
I'm quite impressed with your first preset, looking forward to seeing what else you can do, hehe
--- gone to two new threads ----
morte, would be good if you created one topic per item, much easier to get an overview then! and also mention the name in the topic name
pike Wrote:morte, would be good if you created one topic per item, much easier to get an overview then! and also mention the name in the topic name
OK, no problem!
Hey Morte, great work mate.
Thanks for taking the time to have a play with Vortex.
As mentioned the docs are currently being worked on but feel free to ask me if there is anything you need help with, but you seem to be doing quite well on your own.
Also let me know if there is anything you think needs adding, math functions etc.
Looking forward to more of your work.
Cheers!
MrC Wrote:Hey Morte, great work mate.
Cheers!
I have to thank you for giving us such a great tool to play with!NodNod
I think some more explanation of the blending functions would be great and (if not already there) some functionality for specifying the alpha level of an texture would be great (for transitions, so you could smoothly blend them from a to b).
