2015-04-10, 17:49
Hi, I've had this issue for a while now(xbmc 13+). The only way all my files get added to the library is if I do an add source. When I use the library update app and run it manually, it shows a very brief scan but does not add the newly available files to the library, Eg I recently added survivor eiposde 8 to the NAS. I can access it via "files" browsing but not through the tv shows library. The only way to add it to the library is to remove the directory as the library source, then readd it, which will initiate the full scan. What am I doing wrong?
