popcornmix I promised to make a DVD sample for you regarding the frame skipping, but I have no idea how to do that without changing the format.
And btw, would a sample really matter since no matter what DVD (disc, img, iso) source I use, nothing is playable?
Even the DVD menu isn't working properly. (Even on clean install).
It's really strange that DVDs works for you tho. So maybe if you have a DVD sample then I can try it and see how it preforms at my end.
Do I have to set the number of channels to 7.1 since I have only 5.1 system
Also I understand that using this build I will be able to play full 3D movie, but when I play an ISO 3D bluray, it shows only 2D. Should I have to convert it to MKV?
thanks
(2015-04-19, 18:43)arryo Wrote: [ -> ]Do I have to set the number of channels to 7.1 since I have only 5.1 system
Either should work. If you set to 7.1 your receiver will downmix. If you set to 5.1 Kodi will downmix. Try both and see which you prefer.
Quote:Also I understand that using this build I will be able to play full 3D movie, but when I play an ISO 3D bluray, it shows only 2D. Should I have to convert it to MKV?
Currently MVC in ISO file is not supported. You need to run makemkv on the ISO and make sure the stereo channel is enabled.
This is quite quick (a remux rather than a re-encode). This will produce an MVC mkv file that will play in 3D.
popcornmix
DTS is playing okay on build #417,
with and without the advancedsetting (see 2 logs)
i didn't use #418 (see coment from other users and me)
THX
seeYah
New OpenELEC Isengard build #0419:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.0.0 #1 Sun Apr 19 21:02:44 BST 2015 armv6l GNU/Linux
# vcgencmd version
Apr 11 2015 17:37:07
Copyright (c) 2012 Broadcom
version 311b05fb4e33655a083a6f65b645e6a14e322803 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150419210152-#0419-g7671ddf [Build #0419]
# vcdbg log msg 2>&1 | grep DTOK
001543.998: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (7671ddfe,
changelog) and tip of
XBMC master (29908c2e,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.0.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (7b3b44cd)
- Includes libcec master (707bd51c)
- Includes latest libnfs master (77e3d80f)
- Includes latest addons: audiodecoder.modplug (c7e8ca82), audiodecoder.nosefart (c77e5a12), audiodecoder.sidplay (f2e7d985), audiodecoder.snesapu (9fc775b1), audiodecoder.stsound (775c858d), audiodecoder.timidity (bf9ff93d), audiodecoder.vgmstream (0c3a51a2), audioencoder.flac (84acb141), audioencoder.lame (3eb59de9), audioencoder.vorbis (d556a687), audioencoder.wav (40aaedfa), kodi-platform (48bdd985), pvr.argustv (96ee8750), pvr.demo (64749530), pvr.dvblink (5d505b87), pvr.dvbviewer (bd2c01f5), pvr.filmon (413fe9ec), pvr.hts (4bf1a97a), pvr.iptvsimple (000ff75b), pvr.mediaportal.tvserver (6f8ca82e), pvr.mythtv (ef9cf412), pvr.nextpvr (1ecbf87c), pvr.njoy (fcd62943), pvr.pctv (0a0924eb), pvr.vdr.vnsi (3a28e39a), pvr.vuplus (d6abad38), pvr.wmc (37b4b292)
- Include patch: Add dcadec package for DTS HD-MA support
- Include patch: Add experimental splash video
- Include patch: Enable audiodecoder, audioencoder, pvr and visualization addons
- Include PR:6732: [pvr] fixed crash when multiple add-on instances get registered
- Include PR:6919: added: also hide thumbs for unwatched episodes if option to show plot is off
- Include PR:6979: [switchplayer] fix multiple ghost choices in contextmenu
Build Highlights:
- New v92 videodb schema
- mmal updates
Build Details:
- OpenELEC:
- connman: revert debb37a (PR:4101, 2 commits, 3 files changed)
- scripts/create_addon: add support for project specific addons (71febe4a)
- XBMC:
- videodb: add a delete trigger for the files table (PR:6972, 1 commit, 1 file changed)
- [stringutils] do not capitalize after apostrophes (PR:6965, 1 commit, 1 file changed)
- FIX: passthrough volume warning no longer showed (fixes #15925) (PR:6981, 1 commit, 1 file changed)
- [VideoSyncIos.h] Typo (PR:6983, 1 commit, 1 file changed)
- [Confluence] add DefaultAddonUISounds.png (29908c2e)
- dcadec:
- Prevent wrapping in dcadec_frame_buffer_size(). (3580cbe8)
- Un-inline bitstream array functions. (7b3b44cd)
- newclock4:
- New commits in this build:
- [mmalcodec] Fix initialisation of m_format in init_vout (b31337ba)
- fixup! [mmalrenderer] Add shared lock around MMAL operations (7577fe97)
- fixup! [mmal] Move the image pool from decoder to renderer (ab2be8b3)
- fixup! [mmalcodec] flags debug (8401f9e0)
- Added: PR:6979: [switchplayer] fix multiple ghost choices in contextmenu
mmal/dvdplayer video playback is working correctly again with 0419 after issues with 0418.
It's working good again.
but it shows errored squared box too often and showed like lagged often in video.
It didn't showed in build 0417.
(2015-04-20, 02:56)parcel Wrote: [ -> ]but it shows errored squared box too often and showed like lagged often in video.
"errored squared box" - do you mean you're seeing a red square box in the top right of the display? This is the over-temperature warning.
Running bcmstat.sh in ssh will allow you to view the current temperature.
If the square box is rainbow coloured, this is the under-voltage warning and you need a better power supply and/or USB cable.
(2015-04-20, 04:22)Milhouse Wrote: [ -> ] (2015-04-20, 02:56)parcel Wrote: [ -> ]but it shows errored squared box too often and showed like lagged often in video.
It's not a rainbow box, it's like digital noised on videos. Sorry for my inaccuracy expression.
After reboot, It seem to ok now. thank you
(2015-04-19, 22:46)Milhouse Wrote: [ -> ]Build Highlights:
Just for my understanding: would this mean, that any MyVideos<xy>.db with xy < 92 in /.kodi/userdata/Database can be removed? Does this also apply to any other type of database, e.g. MyMusic, TV, Epg, etc.?
(2015-04-19, 20:00)blubserl Wrote: [ -> ]i also posted a thread regarding this topic:
http://forum.kodi.tv/showthread.php?tid=224787
does this sound familiar to you?
Yeah, that seems to be the case. I am using a similar setup, USB audio + stereo amplifier for music, HDMI + receiver for movies. I will do some more testing tonight. I upgraded to 419 last night and it seemed it worked better.
(2015-04-20, 09:26)thent Wrote: [ -> ] (2015-04-19, 22:46)Milhouse Wrote: [ -> ]Build Highlights:
Yes, these can be removed, but by removing you can't go back to an older release because there is no compatible DB file anymore (an empty one will be created and used then). If you keep them you can go back and have the DB state from the time before the upgrade (changes to DB in newer version won't be applied in old version).
(2015-04-19, 18:39)Patrics83 Wrote: [ -> ]And btw, would a sample really matter since no matter what DVD (disc, img, iso) source I use, nothing is playable?
Might be worth trying again with next build which should include
PR6988 which fixes a regression with DVD menus.
Can you provide a sample file that shows this issue? Not something I'm seeing here.
