I changed string in the german translation 7 days ago, but the changes are not yet pushed to an updated language pack. Problem with the translation is that for some reason someone decided to translate GUI to "Benutzeroberfläche" all over the place, which I agree in general is more userfriendly, but also way to long unfortunately.
edit: new and upcoming translation is "Aktualisierungsrate der Benutzeroberfläche begrenzen"
Am I missing something regarding web interface addons ? I installed this Kodi on a new RPI2 and I am unable to find the Chorus addon. I tried to install it manually and it says it has an incorrect structure.
da-anda
Good, verry good translation - think that's a non-destructive readout for grafikbox ;-)
perfect
(2015-05-26, 21:05)ktfzone Wrote: [ -> ]Am I missing something regarding web interface addons ? I installed this Kodi on a new RPI2 and I am unable to find the Chorus addon. I tried to install it manually and it says it has an incorrect structure.
Contact the Chorus maintainer - there's probably a good reason you can't find the addon, is it even compatible with Isengard?
(2015-05-26, 21:08)Milhouse Wrote: [ -> ] (2015-05-26, 21:05)ktfzone Wrote: [ -> ]Am I missing something regarding web interface addons ? I installed this Kodi on a new RPI2 and I am unable to find the Chorus addon. I tried to install it manually and it says it has an incorrect structure.
It's there.
Probably his local setup is flawed
(2015-05-26, 21:09)Martijn Wrote: [ -> ]It's there.
Thanks, I really shouldn't take people at their word...
Will do some more digging. I have 2 RPIs , same version, one of them has it installed for some time, the other one doesn't see the web interface addons. Ignore me for now
When I change refreshrate the confirmation box says something like "return to homescreen". Wasn't like that before. Just reporting.
(2015-05-26, 03:08)MukiDA Wrote: [ -> ]I'm gonna have to test versions individually to be sure, but for versions of OpenELEC past 521, I'm not getting any 3D playback whatsoever. Trying to play a 3D movie results in a black screen and paused playback.
I would also recommend adding "Frame Packed" as a 3D type, outright, rather than attempt to implement it into an existing stereoscopic setup.
I have also the problem, 3D full frame doesn't play anymore. i get also the black screen but with sound
New OpenELEC Isengard build #0526:
RPi /
RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.0.4 #1 Tue May 26 21:02:48 BST 2015 armv6l GNU/Linux
# vcgencmd version
May 23 2015 16:42:55
Copyright (c) 2012 Broadcom
version 29d1114a122b6ef70bdfb7d4db3dd28bdfc38ac2 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20150526210200-#0526-g08f6036 [Build #0526]
# vcdbg log msg 2>&1 | grep DTOK
001542.378: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of
OpenELEC master (08f60365,
changelog) and tip of
XBMC master (b1e80a96,
- Includes newclock4 patches
- Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
- Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.0.y
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest dcadec master (57012ea2, ahead +21)
- Includes latest kodi-platform master (33b6390b, ahead +1)
- Includes latest libcec master (18555911, ahead +5)
- Includes latest libnfs master (7121bc3b, ahead +14)
- Includes latest platform master (aafa6e9f)
- Includes latest addons: pvr.argustv (cffc8b6b, +1), pvr.demo (9c400e19, +1), pvr.dvblink (7f515436), pvr.dvbviewer (05e76da7, +1), pvr.filmon (8c02f43d), pvr.hts (86eb1cc2, +1), pvr.iptvsimple (191972cf, +1), pvr.mediaportal.tvserver (bcfb46f9, +1), pvr.mythtv (6fb769da, +1), pvr.nextpvr (74168dc9, +1), pvr.njoy (9aa05103, +1), pvr.pctv (804dc37c, +1), pvr.stalker (0d6a5d8b, +1), pvr.vbox (375eab31), pvr.vdr.vnsi (244b893c), pvr.vuplus (cdc1d0e3, +2), pvr.wmc (42fb669d, +1)
- Includes commits from shairplay/master, ahead +17 (juhovh)
- Exclude kodi-999.20-PR7102.patch: Temporarily revert dcadec settings and use newclock4 version
- Exclude kodi-999.21-configure.ac-dont-break-if-dcadec-is-missing-dcadec-.patch: Temporarily revert due to breakage
- Include patch: Enable vcsm kernel options for HEVC optimisations
- Include patch: Enable the mailbox driver (new kernel options)
- Include patch: Add experimental splash video
- Include patch: Add ffmpeg dependency and includes for HEVC optimisations
- Include patch: Enable pvr addons
- Include PR:6732: [pvr] fixed crash when multiple add-on instances get registered
- Include PR:6919: added: also hide thumbs for unwatched episodes if option to show plot is off
- Include PR:7048: videodb: Don't allow column value length to exceed key size of unique index
- Include PR:7093: [AirTunes] - features
Build Highlights:
- BD Bookmark change
Build Details:
- XBMC:
- Honor episode bookmarks in bd simple menu (PR:7017, 1 commit, 1 file changed)
(2015-05-25, 20:27)popcornmix Wrote: [ -> ]If you have stuttery videos, try enabling the PTS mode and let me know if it helps.
It helps. It fixes the problem.
Quote:Let me know if enabling PTS mode makes any videos worse.
I didn't find a such
There is another problem for a long time. Frequent recourse to video files causes inhibition of OS. I mean, do start / stop some videos 6-10 times, then the sound disappears and everything starts working slow. Helps to restart.
(2015-05-26, 12:47)popcornmix Wrote: [ -> ] (2015-05-25, 19:16)bagofcrap24 Wrote: [ -> ]Code:
echo "blacklist snd-bcm2835" /storage/.config/modprobe.d/disable-snd-bcm2835.conf
Correction:
echo "blacklist snd-bcm2835" > /storage/.config/modprobe.d/disable-snd-bcm2835.conf
Thank you @
popcornmix. This worked and my hifiberry digi board is alive again.
(2015-05-27, 09:02)MONSTA Wrote: [ -> ]There is another problem for a long time. Frequent recourse to video files causes inhibition of OS. I mean, do start / stop some videos 6-10 times, then the sound disappears and everything starts working slow. Helps to restart.
Can you grab a log next time it happens. I have seen this error (with dvdplayer - not omxplayer):
23:25:16 T:8116 ERROR: ActiveAE::ActiveAE::CActiveAE::MakeStream - could not create stream
23:25:16 T:8116 ERROR: CDVDPlayerAudio::Process - failed to create audio renderer
And that does produce an effect like you've described (video starts without audio, but grinds to a halt after a number of seconds).
Looks like it's
not a Pi specific error.
However I've not seen it in my dev environment and cannot make it fail on demand which is necessary to debug it.
If you identify a reliable way of provoking this error, that would be very useful. If you do, provide a debug log, sample file and explain any settings that are non-default.
I've seen it as well and my workaround which seems to work ok for now is to change the setting for keeping the audio device alive from 1 minute to forever/always. Periodically I would have some weird static sound after stopping a video, but if I started it and then stopped it again the static would go away.
