2015-04-11, 19:04
Is it possible in a video add-on to specify the 'strFileName' value that will be used to store data in MyVideos90.db/Files ?
The reason is that some streaming service change the URL parameters for each call to the same stream. As the 'strFileName' is storing by default all the URL parameters, it makes it impossible to reuse the previously saved bookmarks for example.
Thanx.
Thanx.
