2015-04-14, 14:24
THIS THREAD IS OUTDATED! PLEASE REFER TO THE NEW THREAD CREATED BY TROMY: http://forum.kodi.tv/showthread.php?tid=260177
Working Skins Post #1 > http://forum.kodi.tv/showthread.php?tid=...pid1982468
Titian
Metropolis New
Simply
Nix
Skye
Work In Progress Post #2 > http://forum.kodi.tv/showthread.php?tid=...pid1982469
krave's unnamed first skin
How to Install Custom Skins
1) Get the skin files - In most cases it will be in zip format. For example Github links have a "Download Zip" on the side of the page.
2) Extract the files inside the zip file
3) Close Kodi/PTVL if it is open
4) Place the extracted files in the PTVL custom skin folder - The files that should be placed here should include several files and folders such as 720p and media. If those files are inside another folder ie a folder named after the skin, move them from that folder and put them in the skin folder itself.
5) Open Kodi
6) Go to PTVL settings > Visual
7) Set skin to custom and save
8) Start PTVL
9) Enjoy your new skin and give thanks/rep to the creator!
Where is PTVL's Custom Skin Folder? ****Changes Pending****
Linux >> ~/.kodi/addons/script.pseudotv.live/resources/skins/Custom
Windows >> C:\Users\USERNAME\AppData\Roaming\Kodi\addons\script.pseudotv.live\resources\skins\Custom
Mac OS X >> /Users/<your_user_name>/Library/Application Support/Kodi/addons/script.pseudotv.live/resources/skins/Custom
Openelec >> /storage/.kodi/addons/script.pseudotv.live/resources/skins/Custom
iOS >> /private/var/mobile/Library/Preferences/Kodi/addons/script.pseudotv.live/resources/skins/Custom
Android >> Android/data/org.xbmc.kodi/files/.kodi/addons/script.pseudotv.live/resources/skins/Custom
OR /sdcard/Android/data/org.xbmc.kodi/files/.kodi/addons/script.pseudotv.live/resources/skins/Custom
Note: In many cases these folders may be hidden by your OS. For example the entire ".kodi" folder is hidden in most Linux distros. In Openelec you have to manually go to the storage/ folder and type "/.kodi" to access the addons.
PTV skins that need to be updated for PTVL >> https://github.com/Lunatixz/PseudoTV_Skins
Titian
Metropolis New
Simply
Nix
Skye
5) Open Kodi
8) Start PTVL
