2015-05-27, 16:21
2015-05-27, 16:23
(2015-05-27, 16:21)Funkd Wrote: [ -> ]Did you set that up through xorg.conf? What OS are you using?
I am not familiar with xorg.conf. I am using windows 8.1
2015-05-27, 16:24
(2015-05-27, 16:23)blackreign66 Wrote: [ -> ]I am not familiar with xorg.conf. I am using windows 8.1
Ah right, I need to find a way to get custom resolutions working through OpenELEC.... Did have any luck last time out, maybe a fresh head will help
2015-05-27, 20:01
(2015-05-27, 10:26)eltopo Wrote: [ -> ]I don't know of any projector with a 2.35:1 (21:9) resolution, I think they all are 16:9.
If this skin needs a physical 21:9 resolution like those widescreen monitors, I guess this won't work with projectors.
I think for projector support we would need a 16:9 skin, but with all GUI elements placed inside 800px height (if full HD). And this 800px height GUI would have to be moved to the upper end and the lower end of the screen (like it is possible today with the vertical height setting when watching a 21:9 movie).
But I don't know if this is something BigNoid can support in this skin.
I have a JVC with lens memory can get any size i want
2015-05-27, 20:15
(2015-05-27, 20:01)Saskue Wrote: [ -> ]I have a JVC with lens memory can get any size i want
The sizes we are chatting about is resolutions. Can you get a 21:9 resolution, like 2560x1080 on your JVC?
2015-05-28, 20:09
(2015-05-27, 20:15)Funkd Wrote: [ -> ](2015-05-27, 20:01)Saskue Wrote: [ -> ]I have a JVC with lens memory can get any size i want
That would be up to your pc's gpu to downsample any resolution higher than 1920x1080 either being 16:9 or 21:9 aspect ratio. I sometimes use 2560x1088 when playing some pc games because it's less of a performance hit than using 3200x1360
2015-05-29, 15:52
Yeah thats what I tried to do last time out. Wouldn't work, then got sidetracked with other things in the cinema room
2015-06-01, 01:16
Well, the JVCs wont accept custom resolution. i have tried many times, different JVC projectors, different graphics. Anyway a custom resolution is not ideal for CIH with lens memory.
We really need a 1920*1080 with all of the GUI within ~800 pixels and black bars. I will be happy to elaborate. This has been a huge problem for years.
2015-06-01, 02:42
(2015-06-01, 01:16)AEnz Wrote: [ -> ]Well, the JVCs wont accept custom resolution. i have tried many times, different JVC projectors, different graphics. Anyway a custom resolution is not ideal for CIH with lens memory.
Yeah that's what I've been working on as I had problems getting a custom resolution to work.
See http://forum.kodi.tv/showthread.php?tid=210806
2015-06-04, 04:01
The SIM2 Nero 235 was marketed as a "2.35:1 format projector with advanced electronics", but its actual native resolution was: 2560x1600 (i.e. Aspect Ratio: 16:10 - WQXGA). Note: That is a data mode so not sure if it would accept that via the HDMI port.
As far as I know it is discontinued. Probably not a big seller at over $20K.
2015-06-16, 16:51
(2015-05-25, 12:07)BigNoid Wrote: [ -> ]I pushed a very early version to github if people are interested in testing. Keep in mind that weather, music and pictures section are mostly not done yet and that some viewtypes are not yet available or incomplete.
EDIT: Only for Isengard. github link
I've tested this version, and it looks really good! The only issue I ran in to so far is that the scroll list on the homescreen cuts off too soon (1920px maybe?)
2015-07-16, 21:56
Thanks for this! I just picked up a 34" Dell and this works really well. I hope we see more ultra widescreen support from other skins soon.
2015-07-16, 22:31
(2015-06-16, 16:51)Keewee Wrote: [ -> ]I couldn't reproduce this till today, when i realised you mean with the menu set to fixed. Fixed now, thx.(2015-05-25, 12:07)BigNoid Wrote: [ -> ]I pushed a very early version to github if people are interested in testing. Keep in mind that weather, music and pictures section are mostly not done yet and that some viewtypes are not yet available or incomplete.
(2015-07-16, 21:56)drkhrse Wrote: [ -> ]I just picked up a 34" Dell
That was also for me the main reason to code this
2017-10-10, 23:09
Are you planning on still supporting 21x9 in the krypton branch? I've been waiting to upgrade Kodi until the skin support is there :0)
Thanks for your hard work!
