somehow I managed to delete all the thumbnails off of kodi which was about 4500 of them and I wanted to know what can I do to get them back other than deleting everything and reinstalling it all back
I would imagine you're going to have to do a fresh install of Kodi unfortunately.
In what way did you delete the thumbnails? Do you mean the thumbnails folder inside the
userdata (wiki) folder? If so, then that can be fixed without a fresh install. You can either delete the userdata/Database/textures##.db files, which will force Kodi to recache everything, or use this:
http://forum.kodi.tv/showthread.php?tid=158373
[/quote][/php]yes I deleted the thumbnails from the userdata folder. I deleted the textures.db file and some thumbnails came back but kodi is using over 90% of my storage space and it's freezing it
