Full Version: Is there a install for openelec?
Hey,
This seems awsome! Is there a addon install for openelec or is it another process to get to test the build?
Best regards,
C
you need to wait for a testbuild or compile OE on your own. It's not just an addon as it requires major changes in core. Garbear will release some test builds (most likely also OE ones) soon (no exact ETA).
(2015-04-17, 23:33)da-anda Wrote: [ -> ]you need to wait for a testbuild or compile OE on your own. It's not just an addon as it requires major changes in core. Garbear will release some test builds (most likely also OE ones) soon (no exact ETA).
aa thx for answer, will def keep an eye out, exiting project!
