2016-06-29, 19:45
2016-06-29, 19:55
(2016-06-29, 19:44)learningit Wrote: [ -> ](2016-06-29, 19:40)hewligun Wrote: [ -> ]No COX. As I said I have a setup in another room and it works just fine. The other setup is on a rpi2. This is a windows box.No idea then. You need to create a detailed debug log by enabling debug logging and specific logging for cURLib and ffmpeg. It's something to do with https, I think, which shouldn't be a problem on Windows.
Here you go. http://pastebin.com/3W5GpJKG
2016-06-29, 20:06
(2016-06-29, 19:55)hewligun Wrote: [ -> ](2016-06-29, 19:44)learningit Wrote: [ -> ](2016-06-29, 19:40)hewligun Wrote: [ -> ]No COX. As I said I have a setup in another room and it works just fine. The other setup is on a rpi2. This is a windows box.No idea then. You need to create a detailed debug log by enabling debug logging and specific logging for cURLib and ffmpeg. It's something to do with https, I think, which shouldn't be a problem on Windows.
Your problem is on line 799;
10:52:36 T:6216 ERROR: ffmpeg[1848]: [tls] An unexpected TLS handshake packet was received.
I'm not sure why, but https is an issue with your ffmpeg build. AFAIK all windows builds above 15.1 are ok for ffmpeg with https and you're not using a VPN, so I'm at a loss for answers.
My current best answer is to upgrade to 16.0 or 16.1.
2016-06-29, 20:09
(2016-06-29, 20:06)learningit Wrote: [ -> ]Thank you I will try that. HTTPS is ok. I was able to look at the log and find the actual filename and it plays fine direct in VLC. So that lets me rest a little easy. Will Upgrade to 16.1. Hope that fixes it. Thanks.(2016-06-29, 19:55)hewligun Wrote: [ -> ](2016-06-29, 19:44)learningit Wrote: [ -> ]No idea then. You need to create a detailed debug log by enabling debug logging and specific logging for cURLib and ffmpeg. It's something to do with https, I think, which shouldn't be a problem on Windows.
Code:10:52:36 T:6216 ERROR: ffmpeg[1848]: [tls] An unexpected TLS handshake packet was received.
2016-06-29, 20:11
(2016-06-29, 20:09)hewligun Wrote: [ -> ]Thank you I will try that. HTTPS is ok. I was able to look at the log and find the actual filename and it plays fine direct in VLC. So that lets me rest a little easy. Will Upgrade to 16.1. Hope that fixes it. Thanks.
Probably a weird build of ffmpeg without/incomplete https support. 16.0 or above will definitely have that.
2016-06-29, 20:19
(2016-06-29, 20:11)learningit Wrote: [ -> ](2016-06-29, 20:09)hewligun Wrote: [ -> ]Thank you I will try that. HTTPS is ok. I was able to look at the log and find the actual filename and it plays fine direct in VLC. So that lets me rest a little easy. Will Upgrade to 16.1. Hope that fixes it. Thanks.
16.1 Fixed it. Was kinda lagging on the update because 15.2 ran fine for the most part and rpi builds arent the most fun to update. But it worked on windows. Thanks!
2016-07-20, 17:45
2016-07-20, 18:02
I'm in the US. When I click on Bravo it says it has failed and to check the log. I love that channel and wish it would come back up. If you figure it out, please let me know.
2016-07-20, 21:21
V3.0.3 has been submitted to the kodi.org repo.
Should fix the above issue.
Update should be available in a few days.
2016-07-20, 21:22
Brilliant thanks! Do I need to use a VPN or anything for it to work in UK?
Many thanks for getting back to me
2016-07-20, 21:26
(2016-07-20, 21:22)DreamerUK Wrote: [ -> ]Brilliant thanks! Do I need to use a VPN or anything for it to work in UK?
No idea, it's designed for use in the US only.
2016-07-24, 20:11
(2016-07-20, 21:21)learningit Wrote: [ -> ]V3.0.3 has been submitted to the kodi.org repo.
Thanks for the fix...much appreciated
2016-07-26, 06:42
I have updated my app, and it works, but it's still stopping to buffer every 10 seconds (literally). I've checked all my plugs and everything is working well, including my Internet. When I looked on the Add-On settings, it say "This add-on could not be configured." Should I just give the app more time to adjust to the update? Did I update it wrong?
2016-07-26, 06:58
(2016-07-26, 06:42)jessicawise Wrote: [ -> ]I have updated my app, and it works, but it's still stopping to buffer every 10 seconds (literally). I've checked all my plugs and everything is working well, including my Internet. When I looked on the Add-On settings, it say "This add-on could not be configured." Should I just give the app more time to adjust to the update? Did I update it wrong?There's no such thing as "adjust to the update". The Bravo streams are fairly high speed and require a reliable 6-7 Mbps internet link. If you don't think that's your problem you need to post a debug log to xbmclogs.com.
2016-10-11, 17:12
Addon was broke for me yesterday. The shows show up but when you try to get a list of episodes it did not work. Both on my windows install and my rpi.
