New Addon with full episodes. This addon will probably require a VPN outside of the US. It also needs a 4-5 Mbps link as most of the video is 1080.
Requires a Kodi build which has ssl support compiled with ffmpeg. Windows is ok, Android needs 15.0 or higher.
Available in the kodi.org repo
http://mirrors.xbmc.org/addons/gotham/pl...eo.oxygen/
Hi, none of the links are opening, the same situation with Syfy. Bravo addons and on AMC there are no links showing at all, I use US located VPN and CBS, for instance, is working. Great idea to make these addons, is there any chance to fix them? I use minix neo X8h XBMC...
(2015-05-28, 14:29)vovakova Wrote: [ -> ]Hi, none of the links are opening, the same situation with Syfy. Bravo addons and on AMC there are no links showing at all, I use US located VPN and CBS, for instance, is working. Great idea to make these addons, is there any chance to fix them? I use minix neo X8h XBMC...
AMC has changed from brightcove to theplatform for their Video API, so it'll be a while before that works again, if ever.
Is there any chance of getting a debug log for a video that doesn't play for you?
I'm almost certain that they don't play because you have a version of Kodi that doesn't have ssl support compiled in ffmpeg.
I believe that most 15.0 and higher builds have the required https support.
thank you very much, Oxygen and Bravo are working after installed 15.0, but there is a problem with Syfy - only shows on the list 12 monkeys, nothing else..
(2015-05-28, 16:40)vovakova Wrote: [ -> ]thank you very much, Oxygen and Bravo are working after installed 15.0, but there is a problem with Syfy - only shows on the list 12 monkeys, nothing else..
Syfy website changed sometime between yesterday and this morning.
UPDATE Please see:
2015092 (post)
(2015-11-05, 17:41)Ferreirinha Wrote: [ -> ]Hi there...I Upgrade for the new Kodi Isengard 15,2 but regarding the Oxygen add-on concerned...No...The Oxygen Add-on still not working.I try to uninstall it and update it with your Zip Files but still not working
The version in my repo and the kodi.org repo should be 1.0.7.
You may need to go into settings->Metadata->Initialize Metadata Next Start and set it on before running.
If it still isn't working turn on debug logging, try running the addon and post a debug log to xbmclogs or pastebin so I can take a look.
V3.0.3 fixes website changes.
A PR has been made for the Kodi.org repo. The update should be available in a few days.
This add-on has been removed from the kodi.org repo and will no longer be supported by the original author
My oxygen add-on was missing and I had to find another way to install it. But now it’s saying the repository is broken and I can’t find an article or video on how to fix it! Someone please help! I just want to watch snapped and bad girls club
Torii911
Ummm... did you read the post directly above yours?
No longer available.
