2015-04-19, 00:52
I'm currently using Kodi 14.2 on a FireTV and FireTV Stick (both running the latest firmware).
I noticed that the special folder mapping "special://home/" points to a non existing directory "/storage/emulated/0/...",
as also noted in the log:
Because of this, f.e. downloading a subtitle does not work, as the downloader tries to save the file in the directory which does not exist.
The correct directory pointing to should be "/storage/emulated/legacy/...".
Currently, as workaround I use a substitution rule in the advancedsettings.xml:
This does work, meaning Kodi starts normally and the subtitle downloading also works fine. But I don't really like to put such a hardcoded path as substitution rule, as it may change in upcoming firmwares.
Is this a known bug? Is there a place where I can set the correct mapping?
Greets,
cyb
NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
<pathsubstitution>
<substitute>
<from>special://home/</from>
<to>/storage/emulated/legacy/Android/data/org.xbmc.kodi/files/.kodi</to>
</substitute>
Greets,
cyb
