2019-11-15, 02:42
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
2019-11-17, 01:47
(2019-11-15, 02:14)LongMan Wrote: [ -> ]@Montellese
From Luke
"If you had one endpoint to update all of that at the same time, would you do that, or would you still be updating different values at different times?"
Edit:
That being
- watched: this seems to be possible with a call to POST /Users/{UserId}/PlayedItems/{itemId} with the property "DatePlayed" set properly
- unwatched: this seems to be possible with a call to DELETE /Users/{UserId}/PlayedItems/{itemId}. I'm assuming that this also removes the "DatePlayed" property
- date played: see watched / unwatched. The only "problem" here is that in Kodi it's possible to manually mark an item as unwatched but keep the "last played" property set
- resume point: this seems to be possible with a call to DELETE /Users/{UserId}/PlayingItems/{Id}
Whenever an item has changed I check if one of the properties listed above has changed compared to the information provided by the Emby server. Depending on which of the properties has changed I'm currently using different methods to push those differences / changes to the Emby server. If there would be a single endpoint that would make things easier because I would only have to execute a single API call instead of separate ones.
2019-11-17, 01:57
In the mean time I've fixed one of the open issues for sure and the other one most likely (a bit difficult to reproduce). I've started a new test build at https://jenkins.kodi.tv/view/Windows/job/WIN-64/11086/. It should be available on the mirrors at http://mirrors.kodi.tv/test-builds/windo...03-x64.exe shortly.
This test build contains support for
ATTENTION: There were changes to the video database layout so remember to drop your MyVideos117.db before testing this new build.
- manually adding a media provider by enter its URL
- automatically observing changes to imported media imports on the Emby server and synchronizing them to the Kodi library
- updating mark as watched / unwatched and resume point on the Emby server
- improvements to the architecture / implementation
2019-11-17, 18:15
I tried the new build but i am not getting the server to show under media sources. The items in the database previously still plays but it doesn't update the server.
This is playing items that were in the database before
https://drive.google.com/file/d/12G_zbVx...sp=sharing
This log is when I first installed without updating the plugin. Not sure why it crashed so i aatached the log
https://drive.google.com/file/d/1Q6MbYNF...sp=sharing
Hope that helps.
When you are comfortable with the Kodi Build, could you ask @Milhouse to run a LibreELEC build. It is much easier to test with LibreELEC as it is easily isolated, and is it also easier to set up multiple clients.
Hope that helps.
2019-11-17, 22:46
@LongMan thanks for the feedback. I forgot to mention that I made changes to the video database layout but I didn't bump the version. So you need drop the MyVideos117.db database for everything to work.
2019-11-17, 23:04
2019-11-18, 01:12
(2019-11-17, 23:04)LongMan Wrote: [ -> ]Does the Base URI include the Port?
https://drive.google.com/file/d/19FR9A7X...sp=sharing
Yes the port is part of the base URI. Please try again with https://www.dropbox.com/s/qr58iadjfeer1v...y.zip?dl=1 and enable debug logging for Kodi. Did you try to add the media provider manually? IIRC in your case it should work with auto discovery.
2019-11-18, 01:53
Yes. Auto discoery does work but it crashes as soon as I select the user.
https://drive.google.com/file/d/10oI8Adm...sp=sharing
2019-11-20, 12:37
@Montellese,
From Luke,
"OK so in the 4.3 release you'll have this:
/Users/{UserId}/Items/{ItemId}/UserData
Which takes four params:
From Luke,
- PlayCount
- Played
- PlaybackPositionTicks
- LastPlayedDate
2019-11-20, 15:49
(2019-11-18, 01:53)LongMan Wrote: [ -> ]Yes. Auto discoery does work but it crashes as soon as I select the user.
That's odd. I don't see any crashes anymore on my setup but there used to be some due to deadlocks. Unfortunately I wasn't able to load your crash dump. For some reason it can't show the call stacks which makes it useless. Maybe I'm just out of practice
Enabling debug logging would help because right now there's almost no information in your log file.
2019-11-20, 15:50
(2019-11-20, 12:37)LongMan Wrote: [ -> ]@Montellese,
From Luke,
Which takes four params:Please let me know if you have any questions. Thanks."
- PlayCount
- Played
- LastPlayedDate
Great thanks. Any estimate for when 4.3 will be available? I'll add the code to detect / check the Emby server version and then we'll see if it works :-)
2019-11-20, 19:29
When I enable debug logging, it does not crash. It allows me to select the user and to add imports. However no synchronization takes place.
The logs are here.
https://drive.google.com/file/d/1I5-45Mi...sp=sharing
The New API is in the latest Beta of Emby Server, found Here. Choose Beta Channel
Cheers
The logs are here.
Cheers
2019-11-21, 01:29
(2019-11-20, 19:29)LongMan Wrote: [ -> ]When I enable debug logging, it does not crash. It allows me to select the user and to add imports. However no synchronization takes place.That's an interesting hint concerning no crash with debug logging because I always have debug logging enabled. Can you disable debug logging and see if it starts to crash again?
The logs are here.
The debug log indicates that your credentials are not correct. Maybe I should add a test button which allows to manually test if the entered credentials are correct or not.
2019-11-21, 02:16
If I disable debug logging again, it does not crash. Seems like it only crashes before first enabling it.
Emby Server is saying that TestSystem is authenticated. I provided the Emby logs here.
2019-11-21, 03:21
My apologies. It does crash with debug logging. Steps
Logs Here
https://drive.google.com/file/d/1HVisq1J...sp=sharing
NB. It does not crash if the user is typed in. (Which I had started doing)
- Media Providers
- All Providers or Active Providers (no difference)
- EmbyServer
- Select Manual
- Select User (TestSystem in my case).
Logs Here
