My bad, here's the log when running in debug mode
18:21:03 M: 29536256 DEBUG: CApplication::OnKey: 256 pressed, action is 7
18:21:03 M: 29523968 DEBUG: CApplication::OnMessage : Translating XBMC.PlayDVD()
18:21:03 M: 29523968 DEBUG: CApplication::OnMessage : To XBMC.PlayDVD()
18:21:03 M: 29523968 DEBUG: CPlayerCoreFactor::GetPlayers(dvd://1)
18:21:03 M: 29523968 NOTICE: DVDPlayer: Opening: dvd://1
18:21:03 M: 29523968 NOTICE: CDVDPlayer::CloseFile()
18:21:03 M: 29523968 NOTICE: DVDPlayer: waiting for threads to exit
18:21:03 M: 29523968 NOTICE: DVDPlayer: finished waiting
18:21:03 M: 28999680 NOTICE: Creating InputStream
18:21:03 M: 28999680 INFO: msg: libdvdnav: Using dvdnav version 0.2.0cvs from
http://dvd.sf.net
18:21:03 M: 28999680 INFO: msg: libdvdread: Using libdvdcss version 1.2.9 for DVD access
18:21:03 M: 28999680 INFO: Stating file \Device\Cdrom0
18:21:03 M: 28999680 INFO: msg: libdvdcss debug:
18:21:03 M: 28999680 INFO: msg: opening target `\Device\Cdrom0'
18:21:03 M: 28999680 INFO: msg: using Win2K API for access
18:21:04 M: 28999680 INFO: msg: libdvdcss debug:
18:21:04 M: 28999680 INFO: msg: disc is scrambled
18:21:04 M: 28999680 INFO: msg: requesting AGID
18:21:04 M: 28999680 INFO: msg: drive authenticated, using variant 0
18:21:04 M: 28999680 INFO: msg: authentication established
18:21:04 M: 28999680 INFO: msg: GetASF authenticated, ASF=1
18:21:04 M: 28999680 INFO: msg: decrypting disc key e4:59:a6:0e:eb
18:21:04 M: 28999680 INFO: msg: trying player key 01:af:e3:12:80
18:21:04 M: 28999680 INFO: msg: decrypted disc key is 00:00:00:00:4e
18:21:04 M: 28999680 INFO: msg: using CSS key cache dir: T:\cache/BABYLON5_SEASON5_DISC6/2004100815324100-000000004e/
18:21:04 M: 28999680 INFO: msg: libdvdnav: vm: DVD Title: BABYLON5_SEASON5_DISC6
18:21:04 M: 28999680 INFO: msg: libdvdnav: Unable to find map file 'Q:\dvdplayer/.dvdnav/BABYLON5_SEASON5_DISC6.map'
18:21:04 M: 28999680 INFO: msg: libdvdnav: DVD disk reports itself with Region mask 0x00e50000. Regions:
18:21:04 M: 28999680 INFO: msg: 2
18:21:04 M: 28999680 INFO: msg: 4
18:21:04 M: 28999680 INFO: msg: 5
18:21:04 M: 28999680 DEBUG: msg:
18:21:04 M: 28999680 NOTICE: DVDPlayer: playing a dvd with menu's
18:21:04 M: 28999680 NOTICE: Creating Demuxer
18:21:04 M: 28962816 DEBUG: Playback has started
18:21:04 M: 28962816 DEBUG: DVDNAV_HIGHLIGHT: Highlight button 1
18:21:04 M: 28962816 DEBUG: DVDNAV_VTS_CHANGE
18:21:04 M: 28962816 INFO: CDVDInputStreamNavigator::GetVideoAspectRatio - Aspect wanted: 3, Scale permissions: 2
18:21:04 M: 28962816 FATAL: CDVDMessageQueue:
ut MSGQ_NOT_INITIALIZED
18:21:04 M: 28962816 DEBUG: DVDNAV_CELL_CHANGE
18:21:04 M: 28962816 DEBUG: DVDNAV_SPU_CLUT_CHANGE
18:21:04 M: 28962816 DEBUG: DVDNAV_SPU_STREAM_CHANGE
18:21:04 M: 28962816 DEBUG: DVDNAV_AUDIO_STREAM_CHANGE
18:21:04 M: 28962816 INFO: msg: libdvdcss debug:
18:21:04 M: 28962816 INFO: msg: title key found in cache c0:00:00:00:01
18:21:04 M: 28962816 INFO: msg: libdvdnav: demux error! 00 00 00 (should be 0x000001)
18:21:04 M: 28962816 INFO: msg: libdvdnav: Language 'en' not found, using 'ÿÿ' instead
18:21:04 M: 28962816 DEBUG: libdvdnav: Menu Languages available:
18:21:04 M: 28962816 INFO: msg: ÿÿ
18:21:04 M: 28962816 DEBUG: msg:
18:21:04 M: 28909568 ERROR: Error reading data from demuxer
18:21:04 M: 28909568 DEBUG: DVDNAV_VTS_CHANGE
18:21:04 M: 28909568 INFO: CDVDInputStreamNavigator::GetVideoAspectRatio - Aspect wanted: 3, Scale permissions: 1
18:21:04 M: 28909568 FATAL: CDVDMessageQueue:
18:21:04 M: 28909568 DEBUG: DVDNAV_CELL_CHANGE
18:21:04 M: 28909568 DEBUG: DVDNAV_SPU_CLUT_CHANGE
18:21:04 M: 28909568 DEBUG: DVDNAV_SPU_STREAM_CHANGE
18:21:04 M: 28909568 DEBUG: DVDNAV_AUDIO_STREAM_CHANGE
18:21:04 M: 28909568 INFO: msg: libdvdcss debug:
18:21:04 M: 28909568 INFO: msg: title key found in cache c0:00:00:00:03
18:21:04 M: 28909568 INFO: msg: libdvdnav: demux error! 00 00 00 (should be 0x000001)
18:21:04 M: 27881472 DEBUG: DVDNAV_DISCONTINUITY(from: -1, to: 8373622)
18:21:05 M: 27836416 NOTICE: Opening audio stream: 1
18:21:05 M: 27836416 NOTICE: Finding audio codec for: 86020
18:21:05 M: 27820032 DEBUG: FactoryCodec - Audio: passthrough - Opening
18:21:05 M: 27746304 DEBUG: FactoryCodec - Audio: passthrough - Opened
18:21:05 M: 27746304 NOTICE: Creating audio thread
18:21:05 M: 27222016 NOTICE: running thread: CDVDPlayerAudio:
rocess()
18:21:05 M: 27222016 INFO: CDVDInputStreamNavigator::GetVideoAspectRatio - Aspect wanted: 3, Scale permissions: 1
18:21:05 M: 27222016 FATAL: CDVDMessageQueue:
18:21:05 M: 27222016 DEBUG: CDVDAudioCodecPassthrough: Synced to AC3 frame
18:21:05 M: 27222016 NOTICE: Creating audio device with codec id: 86020, channels: 2, sample rate: 48000, pass-through
18:21:05 M: 27598848 DEBUG: CDVDPlayerAudio:: Resync - clock:8341622, delay:59666
18:21:05 M: 27418624 NOTICE: Opening video stream: 0
18:21:05 M: 27418624 NOTICE: Creating video codec with codec id: 2
18:21:05 M: 27418624 DEBUG: FactoryCodec - Video: libmpeg2 - Opening
18:21:05 M: 26165248 DEBUG: FactoryCodec - Video: libmpeg2 - Opened
18:21:05 M: 26169344 NOTICE: Creating video thread
18:21:05 M: 25645056 NOTICE: running thread: video_thread
18:21:05 M: 25645056 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC
18:21:05 M: 23797760 DEBUG: CDVDPlayer:
rocessSubData: Got complete SPU packet
18:21:05 M: 23781376 NOTICE: Initializing video device
18:21:05 M: 23781376 DEBUG: CXBoxRenderManager:
reInit - Selected RGB-Renderer
18:21:05 M: 23273472 NOTICE: fps: 25.000000, pwidth: 720, pheight: 576, dwidth: 768, dheight: 576
18:21:05 M: 23273472 NOTICE: Display resolution USER : 720p 16:9 (1)
18:21:05 M: 22609920 DEBUG: Created YV12 texture 0
18:21:05 M: 21946368 DEBUG: Created YV12 texture 1
18:21:05 M: 21897216 DEBUG: CDVDPlayerAudio:: Detected Audio Discontinuity, syncing clock. diff was: -74, -49205, av: -24639
18:21:05 M: 21336064 DEBUG: CDVDInputStreamNavigator::SetActiveSubtitleStream - id: 0, stream: -1
18:21:05 M: 20307968 DEBUG: Activating window ID: 12005
18:21:05 M: 20307968 DEBUG: DVDNAV_SPU_STREAM_CHANGE
18:21:05 M: 20201472 DEBUG: Checking if window ID 12005 is locked.
18:21:05 M: 26603520 DEBUG: Deleted YV12 texture 1
18:21:05 M: 26603520 INFO: Loading skin file: VideoFullscreen.xml
18:21:05 M: 26251264 INFO: Loading skin file: VideoOSD.xml
18:21:05 M: 25182208 INFO: Loading skin file: VideoOSDSettings.xml
18:21:05 M: 24354816 INFO: Loading skin file: VideoOSDSettings.xml
18:21:05 M: 23863296 DEBUG: CGUIFontTTF::Load Scaled size of font Q:\Media\Fonts\Arial.ttf (28): width = 76, height = 39
