Full Version: Problem to login my youtube account
Hi all:
I'm having a problem to login to my youtube account.
I enter the youtube and select :
Star session:
I get the following message : "YOU MUST ENABLE 2 APPS SO THAT YOU TUBE IS FUNCTIONING PERFECTLY"
I enter OK and next message says: "VISIT YOUTUBE.COM/ACTIVATE AND THE THE FOLLOWING CODE: "
I do it and i can see my account : I select my account, I entered the code. Next message says ; you tube would like to manage your account"
I enter accept.Then I get a message saying: success you have allowed YOUTUBE TV go back to your device to continue,
I go back to kodi but nothing happens , I have repeat all steps all over again.
What am I doing wrong Huh
Hi There,
I had the same issue this morning. After inputting the initial passcode it changes to another code after a few seconds. You need to enter that code quickly and it will ask if you wish it to control the Kodi device, accept and that should be you.
(2015-04-25, 14:41)Glaswegian1973 Wrote: [ -> ]Hi There,
Ok I got it.
This is really a question of speed-
We have to do it quicly as code are changing really fast.
Thank you Glaswegian1973
