Full Version: Can't see channel logos
tried addon, wonderful!
Only thing, can't see logos. Pointed to the folder where png files are, but nothing.
Tried to see debug log, but no trace of errors.
Any suggestions?
Thank you,
sdf
Files should be named exactly as channel name, or read this post http://forum.kodi.tv/showthread.php?tid=...pid1339559 to understand how you can edit your m3u file to get logos.
Already done, tried everything.
EPG works, but no logos
anyway thank you
sdf
Adding the file extension should solve the problem.
v1.9.3
- added setting to disable cache m3u/epg
- added support <icon src=""/> for programme in epg
- added possibility to specify logo path as URL
- changed tvg-logo should contains full logo filename (with extention) <-----
- changed don't try download xmltv if it doesn't load after 3 attempt.
That Worked,
thank you!
sdf
