Full Version: Virtual Keyboard
I am trying to update a skin to work with Helix. I have 2 issues that I'm unable to resolve by implementing the changes that are new to Kodi.
* I can't get the cursor to show up in the virtual keyboard thus no txt
* when I attempt to change skins, I do not see the skin names.... the icons do change as I press the up/down arrow.
New to this, so patience is appreciated Smile
Thanks in advance
you may want to show us some code, that would make it easier for people to help you.
I use this code, if this means something to you.
http://pastebin.com/2PFJTNw9
use pastebin, please.....
(2015-04-27, 16:38)phil65 Wrote: [ -> ]use pastebin, please.....
I completely forgot to use pastebin.
you probably need to add a <font> and/or <textcolor> definition to the edit control (with id="312")
I will give that a reply....
thanks!
