2015-04-27, 03:01
2015-04-27, 03:01
2015-04-27, 22:14
I think the issue here is that bookmarks only point to a timestamp in the video, while blurays are using playlists.
2015-04-28, 01:53
(2015-04-27, 22:14)Ned Scott Wrote: [ -> ]I think the issue here is that bookmarks only point to a timestamp in the video, while blurays are using playlists.playlist basically points to what the blu-ray java menu plays, playlist is also a simpler method
you can do something like a button with "mark as episode 1" or "remember as episode 1" popup after the playing of the playlist is done
2015-04-29, 03:38
With episode bookmarks if the ISO is a multiepisode you can add an episode bookmark so when you click the episode from the list it will start the playlist you want directly skipping the menu (right now it fails only with simplified menu because of a bug: https://github.com/xbmc/xbmc/pull/7017)
Btw bookmarks points to whatever you want. You can set how many bookmarks you want for every playlist you want and they will all be displayed in the bookmark dialog so it's by far the simplest method
2015-04-29, 08:38
2015-04-30, 00:49
(2015-04-29, 08:38)wiak Wrote: [ -> ]FYI
http://kodi.wiki/view/Bookmarks#Episode_bookmarks
Imho is actually better because if you put it in the simplified menu:
a) it only works if you have that enabled
b) if you don't know what playlist is the right one (like usually it is) you have to enter, chose one, try, stop playing, go back and enter again only to mark it. With episode bookmarks after you found it there's no need to return and you can also continue to play the episode if you want
2015-05-02, 21:36
2015-05-02, 22:24
I'm not sure if I explained myself well or not.. Episode bookmarks (my version) is already available in kodi since frodo at least for multiple ISO episodes. I'm not sure if it make sense to add another method to get the same result you can already achieve with episode bookmarks
2015-05-17, 22:20
would still be nice to have an alternative direct playlist mapping in nfo file
nfo file is stored with the file, bookmarks are stored in database
2015-05-18, 17:07
One method is enough. Dealing with .nfo outside of the actual BDMV structure is cumbersome nd should be avoided when/where possible.
2015-10-16, 01:58
anyway found a pretty simple solution and that is to use strm files to basicly point to the playlist
bluray://udf%3a%2f%2fC%253a%255cetc%255cdisc1.iso%2f/BDMV/PLAYLIST/00000.mpls (path can be found in the kodi log) thanks to a user on stockoverflow for pointing it out)
wrote a better guide on my blog
http://nwgat.ninja/adding-episodes-on-tv...i-library/
2016-02-06, 22:06
(2015-10-16, 01:58)wiak Wrote: [ -> ]anyway found a pretty simple solution and that is to use strm files to basicly point to the playlist
One problem with that .strm method (at least in v16rc3) is that the information with the show and episode title and thumbnail etc. are missing from the playback overlay. see post with screengrabs at: http://forum.kodi.tv/showthread.php?tid=...pid2237612
