I'm using Kodibuntu 14.2 on a NUC and would like to schedule Deluge (or something else) to download a daily video podcast at night so that I can watch it using Kodi the next day.
Do you have to log out of Kodi and into Kodibuntu each night so that Deluge can handle the download? Or can you leave Kodi running somehow and Deluge will start up in the background?
you can easily run any application in the background. Since kodi-standalone mode does not use a window manager, you should use a daemon service with a web gui. Most torrent clients support this, e.g. transmission
(2015-04-27, 17:29)wsnipex Wrote: [ -> ]you can easily run any application in the background. Since kodi-standalone mode does not use a window manager, you should use a daemon service with a web gui. Most torrent clients support this, e.g. transmission
To run Kodi I usually have to log out of Kodibuntu (where I would e.g. run Transmisson from) and then log back into Kodi - do you just run Kodi directly from kodibuntu (to avoid logging out)?
Sorry for the dumb questions and many thanks for your help.
You could just run rtorrent in a screen.
yep rtorrent is perfect for this.
(2015-04-28, 10:51)nickr Wrote: [ -> ]yep rtorrent is perfect for this.
Thanks for that - I'll also give this a go
