Full Version: View ongoing recording issue
I just noticed that if you watch a program that is currently recording it never updates the current recording length,
i.e. if you start watching it and it has recorded 10 minutes, then that's as far as you can watch and then have to relaunch it.
My wife wanted to watch Dancing with the stars and started whining because the playback stopped.
tell me about it! Taking forever to put this bug right! Also unless you use the default skin, you can't set recordings using the recurring dialogue box, without copying a couple of files/fiddling about. Annoying all round!
This is a core Kodi issue rather than a NextPVR addon issue.
I just noticed in the spmc fork of Kodi 14.2 the ongoing
Recording no longer stops, it keeps playing you can't
Fast forward or skip but at least it just doesn't stop
Like before, not sure if this behavior is in the main stream 14.2 or is a patch applied to spmc. Kodi 15 should have
This I would imagine.
