2016-02-17, 20:12
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
2016-02-17, 20:30
No english? They aren't protected. You need to know what your doing before making changes. Using Notepad ++ to edit .xml and Kodi xbt extractor to extract the texture files to edit the skin images using an editor like photoshop.
Idk what links you want posted that aren't already. You just gotta search through the pages. A few pages back actually has the most updated skin.
2016-02-19, 11:14
loved this skin in raspberry pi, and am loving it in my tab. just awesome. thanks idorel77 for creating the skin and supporting (along with the other skinners) it in android
there's a feature that I've been looking out for, but then nobody's requesting for it. if it's not too much of an effort, cdart (cd cover and spinning disc) similar to the transparency! skin would be nice in addition to the spectrum analyzer in full screen music playback :-)
a howto or instructions how to do it would be great too.
2016-02-19, 22:36
app radio gestibile come carpc?
radio app manageable as CarPC ?
2016-02-20, 20:14
i like your new icons
2016-02-21, 12:53
you send or post Your complete skin to use it thanks
(2016-02-16, 06:11)DarkerStars Wrote: [ -> ]
I centered the buttons with the middle of the screen and shortened the bottom bar to make it the same size as the top bar. Also changed the buttons and sizes.
You can see here they weren't center from the home button.
I was hoping for a red carbon kevlar background but cannot find anything high enough resolution. So I'll just take a very high dpi image when I get my kevlar for the plastic dash panels.
2016-02-23, 03:34
2016-02-23, 07:25
navigation icon you can change from includes.xml
There are 2 button for navigation, check if you modify the right one.
2016-02-23, 10:33
Hoping someone can help me out. I was using this skin with the OpenElec Kodi distro on my RPi2 with the RPi touch lcd, and all was working perfectly. Touch a menu function once, and the item comes up, nice, simple.
I decided to move to Raspbian as it is more flexible, and loaded Kodi along with the skin. Now however I need to press multiple times in order for a selection to register. I've looked everywhere and cannot find an answer to this, so i'm hoping someone out there has the knowledge i'm missing!
Thanks in advance.
Mike
ps. sorry if this post appears twice, internet connection dropped out..
Thanks in advance.
Mike
2016-02-23, 12:15
maybe you find some help here : http://engineeringdiy.freeforums.org/
2016-02-23, 19:14
Hello, I am new in the Forum
I have tried to install it, but unfortunatelly is not worlking property.
I managed to install it stand alone, but kodi does not open navit
could someone give me a hand with this?
Thanks VARS
Thanks VARS
2016-02-23, 19:44
you use android or raspbian ?
here is 3 different skins : https://github.com/idorel77
If you installed skin for android and you use raspbian will not work.
Skin for android open maps and waze , but you have to select from settings what you want to use. or for custom you need to modify home.xml and includes.xml
2016-02-24, 01:53
2016-02-28, 06:00
Thanks idorel77.
I had a look at the forum but am confused. People talk about a file called 'touchscreen_axis_calib' that should be in the /home/pi folder, however i have no such file! Is there a special program i need to run to generate this file?
Cheers,
Mike
Cheers,
Mike
(2016-02-23, 12:15)idorel77 Wrote: [ -> ]maybe you find some help here : http://engineeringdiy.freeforums.org/
2016-02-28, 08:36
it is an addon , you will find in the update arhive.
you find more about calibration here:
http://www.engineering-diy.blogspot.ro/
