Not sure if anyone has seen this before...when I launch Kodi it opens up and launches File Manager each and every time.
I tried wiping the files with my backup, same issue.
Any ideas how to fix this?
One of the add-ons you have installed is calling this up. I'm unable to figure out which one from the debug log.
It doesn't seem to be that. I deleted every single one of them along with the addon data, and it's still doing it. Tried clearing cache, no luck. Deleted my temp folder also.
Here's a new debug -
http://xbmclogs.com/pzg0avywi
Just did some more digging and I'm 100% it's something in the guisettings.xml file which is causing this. Still investigating...
Haven't you just changed the "Startup Window" setting in Appearance-Theme?
That was the setting! I'm 100% I didn't change it, very weird, I never played with that setting before.
All resolved, thanks
