2015-05-09, 16:55
I want to update 14.2 to 15 but Kodi crash at launch, here is the kodi log :
It seems the db is in cause.
I use mysql database. For the upgrade to KODI 14, I have not had a problem
16:45:02 T:140735191696128 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:45:02 T:140735191696128 NOTICE: -----------------------------------------------------------------------
16:45:02 T:140735191696128 NOTICE: Starting Kodi (15.0-BETA2 Git:2015-05-08-e7446ab). Platform: OS X x86 64-bit
16:45:02 T:140735191696128 NOTICE: Using Debug Kodi x64 build
16:45:02 T:140735191696128 NOTICE: Kodi compiled May 9 2015 by Clang 6.0 (clang-600.0.56) for OS X x86 64-bit version 10.7.0 (1070)
16:45:02 T:140735191696128 NOTICE: Running on Apple Inc. iMac15,1 with OS X 10.10.4, kernel: Darwin x86 64-bit version 14.4.0
16:45:02 T:140735191696128 NOTICE: Host CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz, 8 cores available
16:45:02 T:140735191696128 NOTICE: special://xbmc/ is mapped to: /Volumes/Kodi/Kodi.app/Contents/Resources/Kodi
16:45:02 T:140735191696128 NOTICE: special://xbmcbin/ is mapped to: /Volumes/Kodi/Kodi.app/Contents/Resources/Kodi
16:45:02 T:140735191696128 NOTICE: special://masterprofile/ is mapped to: /Users/Cyril/Library/Application Support/Kodi/userdata
16:45:02 T:140735191696128 NOTICE: special://home/ is mapped to: /Users/Cyril/Library/Application Support/Kodi
16:45:02 T:140735191696128 NOTICE: special://temp/ is mapped to: /Users/Cyril/.kodi/temp
16:45:02 T:140735191696128 NOTICE: special://frameworks/ is mapped to: /Volumes/Kodi/Kodi.app/Contents/Libraries
16:45:02 T:140735191696128 NOTICE: The executable running is: /Volumes/Kodi/Kodi.app/Contents/MacOS/Kodi
16:45:02 T:140735191696128 NOTICE: Local hostname: iMac-de-Cyril.local
16:45:02 T:140735191696128 NOTICE: Log File is located: /Users/Cyril/Library/Logs/kodi.log
16:45:02 T:140735191696128 NOTICE: load settings...
16:45:02 T:140735191696128 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
16:45:02 T:140735191696128 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
16:45:02 T:140735191696128 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
16:45:02 T:140735191696128 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/darwin.xml
16:45:02 T:140735191696128 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/darwin_osx.xml
16:45:02 T:140735191696128 NOTICE: Found 1 Lists of Devices
16:45:02 T:140735191696128 NOTICE: Enumerated DARWINOSX devices:
16:45:02 T:140735191696128 NOTICE: Device 1
16:45:02 T:140735191696128 NOTICE: m_deviceName : default
16:45:02 T:140735191696128 NOTICE: m_displayName : Default
16:45:02 T:140735191696128 NOTICE: m_displayNameExtra: Built-in Output
16:45:02 T:140735191696128 NOTICE: m_deviceType : AE_DEVTYPE_PCM
16:45:02 T:140735191696128 NOTICE: m_channels : FL,FR
16:45:02 T:140735191696128 NOTICE: m_sampleRates : 96000,88200,48000,44100
16:45:02 T:140735191696128 NOTICE: m_dataFormats : AE_FMT_S24LE3,AE_FMT_S16LE,AE_FMT_FLOAT
16:45:02 T:140735191696128 NOTICE: Device 2
16:45:02 T:140735191696128 NOTICE: m_deviceName : AirPlay:stream0
16:45:02 T:140735191696128 NOTICE: m_displayName : AirPlay
16:45:02 T:140735191696128 NOTICE: m_displayNameExtra: Freebox Server
16:45:02 T:140735191696128 NOTICE: m_sampleRates : 44100
16:45:02 T:140735191696128 NOTICE: m_dataFormats : AE_FMT_S16LE
16:45:02 T:140735191696128 NOTICE: Device 3
16:45:02 T:140735191696128 NOTICE: m_deviceName : Built-in Output:stream0
16:45:02 T:140735191696128 NOTICE: m_displayName : Built-in Output
16:45:02 T:140735191696128 NOTICE: m_displayNameExtra: Internal Speakers
16:45:02 T:140735191696128 NOTICE: Device 4
16:45:02 T:140735191696128 NOTICE: m_deviceName : Boom2Device:stream0
16:45:02 T:140735191696128 NOTICE: m_displayName : Boom2Device
16:45:02 T:140735191696128 NOTICE: m_sampleRates : 192000,176400,96000,88200,48000,44100
16:45:02 T:140735191696128 NOTICE: m_dataFormats : AE_FMT_S32BE
16:45:02 T:140735191696128 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
16:45:02 T:140735191696128 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
16:45:02 T:140735191696128 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<name>KODI-video</name>
<host>192.168.0.23</host>
<port>3306</port>
<user>KODI</user>
<pass>KODI</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<name>KODI-music</name>
<port>3306</port>
<user>KODI</user>
<pass>KODI</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
</advancedsettings>
16:45:02 T:140735191696128 WARNING: VIDEO database configuration is experimental.
16:45:02 T:140735191696128 NOTICE: Default DVD Player: dvdplayer
16:45:02 T:140735191696128 NOTICE: Default Video Player: dvdplayer
16:45:02 T:140735191696128 NOTICE: Default Audio Player: paplayer
16:45:02 T:140735191696128 NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:45:02 T:140735191696128 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
16:45:02 T:140735191696128 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
16:45:02 T:140735191696128 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:45:02 T:140735191696128 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
16:45:02 T:140735191696128 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
16:45:02 T:140735191696128 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
16:45:02 T:140735191696128 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
16:45:02 T:140735191696128 NOTICE: Loaded playercorefactory configuration
16:45:02 T:140735191696128 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:45:02 T:140735191696128 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:45:02 T:140735191696128 INFO: creating subdirectories
16:45:02 T:140735191696128 INFO: userdata folder: special://masterprofile/
16:45:02 T:140735191696128 INFO: recording folder:
16:45:02 T:140735191696128 INFO: screenshots folder:
16:45:02 T:4570537984 NOTICE: Thread ActiveAE start, auto delete: false
16:45:02 T:4599582720 NOTICE: Thread AESink start, auto delete: false
16:45:02 T:4599582720 INFO: CActiveAESink::OpenSink - initialize sink
16:45:02 T:4599582720 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINOSX:default
16:45:02 T:4599582720 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std::string &): Opening default device Built-in Output
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Finding stream for format AE_FMT_FLOAT
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (96000Hz) rated 929.129272
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (88200Hz) rated 1106.000000
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (48000Hz) rated 1419.564697
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 24-bit Signed Integer LE (44100Hz) rated 1508.000000
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 20-bit Signed Integer LE (96000Hz) rated 928.129272
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 20-bit Signed Integer LE (88200Hz) rated 1105.000000
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 20-bit Signed Integer LE (48000Hz) rated 1418.564697
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 20-bit Signed Integer LE (44100Hz) rated 1507.000000
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 16-bit Signed Integer LE (96000Hz) rated 928.129272
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 16-bit Signed Integer LE (88200Hz) rated 1105.000000
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 16-bit Signed Integer LE (48000Hz) rated 1418.564697
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 16-bit Signed Integer LE (44100Hz) rated 1507.000000
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (96000Hz) rated 930.129272
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (88200Hz) rated 1107.000000
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (48000Hz) rated 1420.564697
16:45:02 T:4599582720 DEBUG: FindSuitableFormatForStream: Physical Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz) rated 1509.000000
16:45:02 T:4599582720 DEBUG: Initialize: Selected stream[0] - id: 0x0027, Physical Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
16:45:02 T:4599582720 DEBUG: CCoreAudioDevice::SupportsMixing: Device mixing support : 'No'.
16:45:02 T:4599582720 DEBUG: CCoreAudioStream::Open: Opened stream 0x0027.
16:45:02 T:4599582720 DEBUG: Initialize: Previous Virtual Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
16:45:02 T:4599582720 DEBUG: Initialize: Previous Physical Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
16:45:03 T:4599582720 DEBUG: CCoreAudioStream::SetPhysicalFormat: Physical format for stream 0x0027. now active ([lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz))
16:45:03 T:4599582720 DEBUG: Initialize: New Virtual Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
16:45:03 T:4599582720 DEBUG: Initialize: New Physical Format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
16:45:03 T:4599582720 DEBUG: GetAEChannelMap Engine requests layout FL,FR
16:45:03 T:4599582720 DEBUG: GetAEChannelMap trying to map to stereo layout: [Left] [Right]
16:45:03 T:4599582720 DEBUG: GetAEChannelMap mapped channels to layout FL,FR
16:45:03 T:4599582720 DEBUG: Initialize: using buffer size: 16384 (0.046440 ms)
16:45:03 T:4599582720 DEBUG: CActiveAESink::OpenSink - DARWINOSX Initialized:
16:45:03 T:4599582720 DEBUG: Output Device : Default
16:45:03 T:4599582720 DEBUG: Sample Rate : 44100
16:45:03 T:4599582720 DEBUG: Sample Format : AE_FMT_FLOAT
16:45:03 T:4599582720 DEBUG: Channel Count : 2
16:45:03 T:4599582720 DEBUG: Channel Layout: FL,FR
16:45:03 T:4599582720 DEBUG: Frames : 512
16:45:03 T:4599582720 DEBUG: Frame Samples : 1024
16:45:03 T:4599582720 DEBUG: Frame Size : 8
16:45:03 T:140735191696128 NOTICE: Running database version Addons19
16:45:03 T:140735191696128 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-x86-osx.so)
16:45:03 T:140735191696128 DEBUG: Loading: /Volumes/Kodi/Kodi.app/Contents/Resources/Kodi/system/libcpluff-x86-osx.so
16:45:03 T:140735191696128 NOTICE: ADDONS: Using repository repository.xbmc.org
16:45:03 T:140735191696128 DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
16:45:03 T:140735191696128 DEBUG: LoadMappings - loaded node "CEC Adapter"
16:45:03 T:140735191696128 DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
16:45:03 T:140735191696128 DEBUG: LoadMappings - loaded node "iMON HID device"
16:45:03 T:140735191696128 DEBUG: USB Device Attach:TomTom GO 5000, 337903616
16:45:03 T:140735191696128 DEBUG: USB Device Attach:Apple Keyboard, 341966848
16:45:03 T:140735191696128 DEBUG: USB Device Attach:ROCCAT Kone XTD, 340787200
16:45:03 T:140735191696128 DEBUG: SECTION:LoadDLL(libcec.3.0.dylib)
16:45:03 T:140735191696128 DEBUG: Loading: /Volumes/Kodi/Kodi.app/Contents/Libraries/libcec.3.0.dylib
16:45:03 T:4602269696 NOTICE: Thread PeripBusCEC start, auto delete: false
16:45:03 T:140735191696128 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
16:45:03 T:140735191696128 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
16:45:03 T:140735191696128 NOTICE: Setup SDL
16:45:03 T:140735191696128 NOTICE: Display 0 has name iMac
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 2560 x 1440 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 3200 x 1800 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 2880 x 1620 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 2048 x 1152 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1600 x 900 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1440 x 810 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1024 x 576 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 960 x 540 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 800 x 600 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 800 x 450 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 5120 x 2880 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 4096 x 2304 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1600 x 1200 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1344 x 756 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1280 x 1024 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 960 x 600 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 840 x 524 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Found possible resolution for display 0 with 640 x 480 @ 60.000000 Hz
16:45:03 T:140735191696128 NOTICE: Checking resolution 15
16:45:03 T:140735191696128 NOTICE: GL_VENDOR = ATI Technologies Inc.
16:45:03 T:140735191696128 NOTICE: GL_RENDERER = AMD Radeon R9 M295X OpenGL Engine
16:45:03 T:140735191696128 NOTICE: GL_VERSION = 2.1 ATI-1.32.20
16:45:03 T:140735191696128 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
16:45:03 T:140735191696128 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGI_color_matrix GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
16:45:03 T:140735191696128 INFO: GL: Maximum texture width: 16384
16:45:03 T:140735191696128 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
16:45:03 T:140735191696128 INFO: load default splash image: /Volumes/Kodi/Kodi.app/Contents/Resources/Kodi/media/Splash.png
16:45:03 T:140735191696128 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-x86-osx.so)
16:45:03 T:140735191696128 DEBUG: Loading: /Volumes/Kodi/Kodi.app/Contents/Resources/Kodi/system/ImageLib-x86-osx.so
16:45:03 T:140735191696128 INFO: load keymapping
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
16:45:03 T:140735191696128 ERROR: Error reading joystick map element, Invalid id: 0
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
16:45:03 T:140735191696128 ERROR: Previous line repeats 25 times.
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
16:45:03 T:140735191696128 ERROR: Previous line repeats 98 times.
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Nintendo.Wii.U.Pro.Controller.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Ouya.Controller.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
16:45:03 T:140735191696128 ERROR: Previous line repeats 13 times.
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.PS4.Controller.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
16:45:03 T:140735191696128 ERROR: Previous line repeats 109 times.
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/mouse.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/remote.xml
16:45:03 T:140735191696128 INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
16:45:03 T:140735191696128 INFO: GUI format 1920x1080, Display Windowed
16:45:03 T:140735191696128 DEBUG: guilib: Fill viewport on change for solving rendering passes
16:45:03 T:140735191696128 INFO: CLangInfo: loading resource.language.fr_fr language information...
16:45:03 T:140735191696128 DEBUG: trying to set locale to fr_FR.UTF-8
16:45:03 T:140735191696128 INFO: global locale set to fr_FR.UTF-8
16:45:03 T:140735191696128 INFO: CLangInfo: loading resource.language.fr_fr language strings...
16:45:03 T:140735191696128 DEBUG: POParser: loaded 3267 strings from file resource://resource.language.fr_fr/strings.po
16:45:03 T:140735191696128 DEBUG: POParser: id:170 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:227 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:263 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:355 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:489 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:638 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:641 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:642 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:708 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:791 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:794 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:1002 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:1260 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:1270 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:10021 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:12383 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:12384 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:13141 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:13146 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:13309 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:13399 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:13433 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:14039 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:14083 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:15108 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19004 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19028 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19048 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19069 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19071 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19072 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19175 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19176 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19182 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19185 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19187 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19188 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19200 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19206 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19222 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19228 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19230 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19231 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19234 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19245 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19250 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19251 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19252 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19253 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19254 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19268 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:19269 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20187 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20188 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20192 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20193 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20194 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20195 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20220 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20341 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20402 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20407 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:20456 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21360 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21370 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21382 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21412 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21413 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21414 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21415 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21419 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:21881 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:22021 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:24033 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36007 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36008 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36020 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36025 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36026 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36040 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36103 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36109 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36110 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36119 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36120 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36124 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36129 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36130 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36133 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36140 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36143 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36146 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36167 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36168 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36170 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36173 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36185 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36200 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36203 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36205 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36206 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36209 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36210 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36220 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36221 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36222 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36223 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36224 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36225 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36230 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36237 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36238 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36241 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36243 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36248 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36251 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36252 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36256 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36257 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36258 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36259 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36265 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36267 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36268 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36269 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36281 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36284 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36293 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36316 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36321 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36322 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36323 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36326 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36328 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36334 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36338 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36342 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36343 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36349 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36351 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36354 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36355 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36377 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36378 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36380 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36386 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36389 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36390 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36393 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36397 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36398 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36417 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36424 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36538 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: id:36549 was recently re-used in the English string file, which is not yet changed in the translated file. Using the English string instead
16:45:03 T:140735191696128 DEBUG: POParser: loaded 258 strings from file resource://resource.language.en_gb/strings.po
16:45:03 T:140735191696128 DEBUG: SECTION:LoadDLL(libcurl.4.dylib)
16:45:03 T:140735191696128 DEBUG: Loading: /Volumes/Kodi/Kodi.app/Contents/Libraries/libcurl.4.dylib
16:45:03 T:140735191696128 DEBUG: Initialize, updating databases...
16:45:03 T:140735191696128 NOTICE: Running database version ViewModes6
16:45:03 T:140735191696128 NOTICE: Running database version Textures13
16:45:03 T:140735191696128 ERROR: SQL: The table does not exist
Query: SELECT idVersion FROM version
