Hi all,
I have Synology NAS with TVheadend server 3.9 installed and I would like to display TV live on Kodi 14.2 (on win 7), but I havent found the PVR addon.
I tried the native PVR addon on Kodi 15 beta but nothing work...
Can you help me please
How do you suppose someone helps you, you haven't even explained what doesn't work let alone included a log.
(2015-05-12, 12:17)robo989 Wrote: [ -> ]How do you suppose someone helps you, you haven't even explained what doesn't work let alone included a log.
you're right. My TVheadend server (v3.9) is on Synology NAS.
In Kodi 14.2 for windows, no native TVheadend PVR addon found (client exist on Kodi 14 ?). So I installed Kodi 15 beta1 with native TVheadend PVR addon (TVheadend HTSP Client). I configure IP and port and go on TV Live but the all channels is empty.
here is my log
13:43:26 T:4836 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:43:26 T:4836 NOTICE: -----------------------------------------------------------------------
13:43:26 T:4836 NOTICE: Starting Kodi (15.0-BETA1 Git:20150501-d1a2c33). Platform: Windows NT x86 32-bit
13:43:26 T:4836 NOTICE: Using Release Kodi x32 build
13:43:26 T:4836 NOTICE: Kodi compiled May 1 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
13:43:26 T:4836 NOTICE: Running on Windows 7 SP1, kernel: Windows NT x86 64-bit version 6.1
13:43:26 T:4836 NOTICE: Host CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz, 4 cores available
13:43:26 T:4836 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
13:43:26 T:4836 NOTICE: Running with restricted rights
13:43:26 T:4836 NOTICE: Aero is enabled
13:43:26 T:4836 NOTICE: special://xbmc/ is mapped to: D:\Kodi 15
13:43:26 T:4836 NOTICE: special://xbmcbin/ is mapped to: D:\Kodi 15
13:43:26 T:4836 NOTICE: special://masterprofile/ is mapped to: C:\Users\Admin\AppData\Roaming\Kodi\userdata
13:43:26 T:4836 NOTICE: special://home/ is mapped to: C:\Users\Admin\AppData\Roaming\Kodi\
13:43:26 T:4836 NOTICE: special://temp/ is mapped to: C:\Users\Admin\AppData\Roaming\Kodi\cache
13:43:26 T:4836 NOTICE: The executable running is: D:\Kodi 15\Kodi.exe
13:43:26 T:4836 NOTICE: Local hostname: HOMESTATION
13:43:26 T:4836 NOTICE: Log File is located: C:\Users\Admin\AppData\Roaming\Kodi\kodi.log
13:43:26 T:4836 NOTICE: load settings...
13:43:26 T:4836 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
13:43:26 T:4836 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
13:43:26 T:4836 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
13:43:26 T:4836 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
13:43:26 T:4836 NOTICE: Default DVD Player: dvdplayer
13:43:26 T:4836 NOTICE: Default Video Player: dvdplayer
13:43:26 T:4836 NOTICE: Default Audio Player: paplayer
13:43:26 T:4836 NOTICE: Disabled debug logging due to GUI setting. Level 0.
13:43:26 T:4836 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
13:43:26 T:4836 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
13:43:26 T:4836 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:43:26 T:4836 NOTICE: Loaded playercorefactory configuration
13:43:26 T:4836 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:43:26 T:4836 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:43:26 T:4844 NOTICE: Thread ActiveAE start, auto delete: false
13:43:26 T:3344 NOTICE: Thread AESink start, auto delete: false
13:43:26 T:4844 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "PLB2712HDS-1 (NVIDIA High Definition Audio)" seems to be not supported.
13:43:26 T:4844 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "PLB2712HDS-1 (NVIDIA High Definition Audio)" seems to be not supported.
13:43:26 T:4844 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "PLB2712HDS-1 (NVIDIA High Definition Audio)" seems to be not supported.
13:43:26 T:4844 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "PLB2712HDS-1 (NVIDIA High Definition Audio)" seems to be not supported.
13:43:26 T:4844 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "PLB2712HDS-1 (NVIDIA High Definition Audio)" seems to be not supported.
13:43:26 T:4844 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AAC" on device "PLB2712HDS-1 (NVIDIA High Definition Audio)" seems to be not supported.
13:43:26 T:4844 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "PLB2712HDS-1 (NVIDIA High Definition Audio)" seems to be not supported.
13:43:26 T:4844 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "PLB2712HDS-1 (NVIDIA High Definition Audio)" seems to be not supported.
13:43:27 T:4836 NOTICE: Running database version Addons18
13:43:27 T:4836 NOTICE: ADDONS: Using repository repository.aeon-mq5-mod-helix
13:43:27 T:4836 NOTICE: ADDONS: Using repository repository.angelscry.xbmc-plugins
13:43:27 T:4836 NOTICE: ADDONS: Using repository repository.xbmc.org
13:43:27 T:4836 NOTICE: ADDONS: Using repository repository.xbmcmania.helix
13:43:27 T:4600 NOTICE: Thread PeripBusCEC start, auto delete: false
13:43:27 T:4556 NOTICE: Thread PeripBusUSB start, auto delete: false
13:43:27 T:3796 NOTICE: Thread RemoteControl start, auto delete: false
13:43:27 T:4836 NOTICE: Found screen: Moniteur Plug-and-Play générique on NVIDIA GeForce GTX 670, adapter 0.
13:43:27 T:4836 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 640x480@ 50.00 - Full Screen
13:43:27 T:4836 NOTICE: Previous line repeats 2 times.
13:43:27 T:4836 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 800x600@ 56.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1176x664@ 50.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1176x664@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1176x664@ 59.94 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x768@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x800@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x960@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1360x768@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1366x768@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1600x1024@ 59.94 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1600x1024@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1768x992@ 25.00i - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1768x992@ 30.00i - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1768x992@ 29.97i - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
13:43:27 T:4836 NOTICE: Additional mode: 1440x900@ 75.00 - Full Screen
13:43:27 T:4836 NOTICE: Checking resolution 15
13:43:27 T:4836 ERROR: Error reading joystick map element, Invalid id: 0
13:43:27 T:4836 ERROR: Previous line repeats 249 times.
13:43:27 T:4836 NOTICE: Running database version ViewModes6
13:43:27 T:4836 NOTICE: Running database version Textures13
13:43:27 T:4836 NOTICE: Running database version MyMusic52
13:43:27 T:4836 NOTICE: Running database version MyVideos92
13:43:27 T:4836 NOTICE: Running database version TV29
13:43:27 T:4836 NOTICE: Running database version Epg10
13:43:28 T:4836 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
13:43:28 T:4836 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
13:43:28 T:4836 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
13:43:28 T:4836 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
13:43:28 T:1852 NOTICE: Thread LanguageInvoker start, auto delete: false
13:43:28 T:4740 NOTICE: Previous line repeats 8 times.
13:43:28 T:4740 NOTICE: Thread JobWorker start, auto delete: true
13:43:28 T:4740 NOTICE: PVRManager - starting up
13:43:28 T:4788 NOTICE: Thread LanguageInvoker start, auto delete: false
13:43:28 T:3452 NOTICE: Previous line repeats 3 times.
13:43:28 T:3452 NOTICE: Thread PVRManager start, auto delete: false
13:43:28 T:380 NOTICE: Thread AlarmClock start, auto delete: false
13:43:28 T:1124 NOTICE: Thread PVRClient start, auto delete: false
13:43:28 T:4836 NOTICE: DVDPlayer: Opening: special://skin/extras/intro.mkv
13:43:28 T:4836 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
13:43:28 T:4928 NOTICE: Thread DVDPlayer start, auto delete: false
13:43:28 T:4928 NOTICE: Creating InputStream
13:43:28 T:4928 NOTICE: Creating Demuxer
13:43:28 T:3932 NOTICE: -->Python Interpreter Initialized<--
13:43:28 T:4928 NOTICE: Opening stream: 0 source: 256
13:43:28 T:4928 NOTICE: Creating video codec with codec id: 28
13:43:28 T:4928 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
13:43:28 T:4928 NOTICE: Creating video thread
13:43:28 T:4928 ERROR: CSelectionStreams::Get - failed to get stream
13:43:28 T:4928 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
13:43:28 T:4836 NOTICE: CApplication::UpdateLibraries: Starting video library startup scan
13:43:28 T:4836 NOTICE: initialize done
13:43:28 T:4956 NOTICE: Thread DVDPlayerVideo start, auto delete: false
13:43:28 T:4956 NOTICE: running thread: video_thread
13:43:28 T:4956 NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1920x1080)
13:43:28 T:4160 NOTICE: Thread LanguageInvoker start, auto delete: false
13:43:28 T:4956 NOTICE: fps: 50.000000, pwidth: 1920, pheight: 1080, dwidth: 1920, dheight: 1080
13:43:28 T:4956 NOTICE: Display resolution DESKTOP : 1920x1080@ 60.00 - Full Screen (16)
13:43:28 T:4956 NOTICE: D3D: rendering method forced to DXVA processor
13:43:28 T:4836 NOTICE: CJoystick::EnumJoysticksCallback : Enabled Joystick: Virtual Hid Device
13:43:28 T:4836 NOTICE: CJoystick::EnumJoysticksCallback : Total Axis: 6 Total Hats: 1 Total Buttons: 24
13:43:29 T:4836 NOTICE: CJoystick::EnumJoysticksCallback : Enabled Joystick: Logitech G25 Racing Wheel USB
13:43:29 T:4836 NOTICE: CJoystick::EnumJoysticksCallback : Total Axis: 5 Total Hats: 1 Total Buttons: 19
13:43:29 T:4788 NOTICE: -->Python Interpreter Initialized<--
13:43:29 T:4836 NOTICE: Previous line repeats 11 times.
13:43:29 T:4836 NOTICE: Running the application...
13:43:29 T:4836 NOTICE: starting upnp client
13:43:29 T:2904 NOTICE: Thread JobWorker start, auto delete: true
13:43:29 T:4836 NOTICE: ES: Starting event server
13:43:29 T:3756 NOTICE: Thread EventServer start, auto delete: false
13:43:29 T:3756 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
13:43:29 T:3756 NOTICE: UDP: Listening on port 9777
13:43:29 T:4476 NOTICE: Thread TCPServer start, auto delete: false
13:43:29 T:2308 NOTICE: Thread PVRGUIInfo start, auto delete: false
13:43:29 T:4740 NOTICE: VideoInfoScanner: Starting scan ..
13:43:29 T:4652 NOTICE: RCB Service: Start
13:43:29 T:4652 NOTICE: RCB Service: launch RCB on startup = false
13:43:29 T:4652 NOTICE: RCB Service: scrape games on startup = false
13:43:29 T:4652 NOTICE: RCB Service: Done
13:43:29 T:4160 NOTICE: -->Python Interpreter Initialized<--
13:43:29 T:4836 WARNING: CWinRenderer::UpdateVideoFilter - chosen scaling method 1 is not supported by renderer
13:43:29 T:3452 NOTICE: EPG::CEpgContainer::Start - EPG thread started
13:43:29 T:760 NOTICE: Thread EPGUpdater start, auto delete: false
13:43:29 T:3112 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.14)
13:43:29 T:3784 NOTICE: script.grab.fanart: Grab Fanart Service Started
13:43:29 T:4160 NOTICE: StorageServer Module loaded RUN
13:43:29 T:4160 NOTICE: StorageClient-2.5.4 Starting server
13:43:29 T:3416 NOTICE: Thread LanguageInvoker start, auto delete: false
13:43:30 T:3416 NOTICE: -->Python Interpreter Initialized<--
13:43:30 T:2328 NOTICE: Service: 6802 actors took 1.7929999828338623
13:43:32 T:4928 NOTICE: CDVDPlayer::OnExit()
13:43:32 T:4928 NOTICE: DVDPlayer: eof, waiting for queues to empty
13:43:32 T:4928 NOTICE: Closing stream player 2
13:43:32 T:4928 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
13:43:32 T:4956 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
13:43:32 T:4956 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
13:43:32 T:4928 NOTICE: waiting for video thread to exit
13:43:32 T:4956 NOTICE: thread end: video_thread
13:43:32 T:4928 NOTICE: deleting video codec
13:43:32 T:4928 NOTICE: DXVA::CDecoder::Close - closing decoder
13:43:32 T:4928 NOTICE: DXVA::Close - closing decoder context
13:43:33 T:2904 ERROR: XFILE::CDirectory::GetDirectory - Error getting include
13:43:33 T:5108 ERROR: Previous line repeats 1 times.
13:43:33 T:5108 NOTICE: Thread JobWorker start, auto delete: true
13:43:33 T:4836 NOTICE: CDVDPlayer::CloseFile()
13:43:33 T:4836 NOTICE: DVDPlayer: waiting for threads to exit
13:43:33 T:4836 NOTICE: DVDPlayer: finished waiting
13:43:35 T:3928 NOTICE: Thread RSSReader start, auto delete: false
13:43:39 T:4740 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:09
13:43:41 T:5108 WARNING: JpegIO: Error 53: Not a JPEG file: starts with 0x%02x 0x%02x
13:43:56 T:4836 NOTICE: Storing total System Uptime
13:43:56 T:4836 NOTICE: Saving settings
13:43:56 T:4836 NOTICE: stop all
13:43:56 T:4836 NOTICE: stop player
13:43:56 T:4836 NOTICE: PVRManager - stopping
13:43:59 T:4836 NOTICE: ES: Stopping event server
13:43:59 T:4836 NOTICE: stopping upnp
13:44:00 T:3756 NOTICE: ES: UDP Event server stopped
13:44:00 T:4836 NOTICE: stop sap announcement listener
13:44:00 T:4836 NOTICE: clean cached files!
13:44:00 T:4836 NOTICE: unload skin
13:44:02 T:1852 WARNING: CPythonInvoker(0, C:\Users\Admin\AppData\Roaming\Kodi\addons\script.cu.lrclyrics\default.py): the python script "C:\Users\Admin\AppData\Roaming\Kodi\addons\script.cu.lrclyrics\default.py" has left several classes in memory that we couldn't clean up. The classes include: class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class PythonBindings::XBMCAddon_xbmc_Player_Director
13:44:02 T:3172 WARNING: CPythonInvoker(3, C:\Users\Admin\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py): the python script "C:\Users\Admin\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py" has left several classes in memory that we couldn't clean up. The classes include: class PythonBindings::XBMCAddon_xbmc_Player_Director,class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Monitor_Director
13:44:02 T:4160 NOTICE: StorageServer-2.5.4 Closed down
13:44:03 T:1448 WARNING: CPythonInvoker(6, C:\Users\Admin\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py): the python script "C:\Users\Admin\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Player_Director,class PythonBindings::XBMCAddon_xbmc_Monitor_Director
13:44:04 T:3112 NOTICE: script.tv.show.next.aired: ### abort requested -- stopping background processing
13:44:04 T:4836 NOTICE: stopped
13:44:04 T:4836 NOTICE: destroy
13:44:04 T:4836 NOTICE: closing down remote control service
13:44:04 T:4836 NOTICE: unload sections
13:44:04 T:4836 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:44:04 T:4836 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
13:44:04 T:4836 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
13:44:04 T:4836 NOTICE: application stopped...
TVheadend log on the Synology NAS
2015-05-11 22:24:49.694 [ INFO]:main: Log started
2015-05-11 22:24:49.696 [ DEBUG]:config: no configuration, loading defaults
2015-05-11 22:24:49.761 [ INFO]:config: backup: migrating config from unknown (running 3.9.2818)
2015-05-11 22:24:49.762 [ INFO]:config: backup: running, output file /volume1/@appstore/tvheadend-testing/var/backup/unknown.tar.bz2
2015-05-11 22:24:49.762 [ INFO]:config: migrating config from v0 to v1
2015-05-11 22:24:49.763 [ INFO]:spawn: Executing "/bin/tar"
2015-05-11 22:24:49.763 [ INFO]:config: migrating config from v1 to v2
2015-05-11 22:24:49.763 [ INFO]:config: migrating config from v2 to v3
2015-05-11 22:24:49.763 [ INFO]:config: migrating config from v3 to v4
2015-05-11 22:24:49.763 [ INFO]:config: migrating config from v4 to v5
2015-05-11 22:24:49.763 [ INFO]:config: migrating config from v5 to v6
2015-05-11 22:24:49.763 [ INFO]:config: migrating config from v6 to v7
2015-05-11 22:24:49.764 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/accesscontrol/8edbbd233343fa6e761c7af9a0c576ea
2015-05-11 22:24:49.764 [ INFO]:config: migrating config from v7 to v8
2015-05-11 22:24:49.764 [ INFO]:config: migrating config from v8 to v9
2015-05-11 22:24:49.765 [ INFO]:config: migrating config from v9 to v10
2015-05-11 22:24:49.765 [ INFO]:config: migrating config from v10 to v11
2015-05-11 22:24:49.765 [ INFO]:config: migrating config from v11 to v12
2015-05-11 22:24:49.766 [ INFO]:config: migrating config from v12 to v13
2015-05-11 22:24:49.766 [ INFO]:config: migrating config from v13 to v14
2015-05-11 22:24:49.766 [ INFO]:config: migrating config from v14 to v15
2015-05-11 22:24:49.766 [ INFO]:config: migrating config from v15 to v16
2015-05-11 22:24:49.766 [ INFO]:config: migrating config from v16 to v17
2015-05-11 22:24:49.766 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/config
2015-05-11 22:24:49.767 [ INFO]:config: loaded
2015-05-11 22:24:49.768 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/profile/05883f366686cf79dc4ffe886fdba3e9
2015-05-11 22:24:49.768 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/profile/1ab7a0bbcb4382ad499498b899d3f047
2015-05-11 22:24:49.768 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/profile/624c157b3df01a42c0dccf5a694dc6f8
2015-05-11 22:24:49.769 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/profile/2e387fa797f5577834fb06cd1ed620a2
2015-05-11 22:24:49.769 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/profile/82e231eccad332180bc727c2264a0312
2015-05-11 22:24:49.769 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/profile/66a81236a1f7993e59fa20ea4ee0c824
2015-05-11 22:24:49.771 [ INFO]:bouquet: new bouquet 'Canal Digitaal SD'
2015-05-11 22:24:49.771 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/ff4cd2af781ad6bbeb4de03c657f5627
2015-05-11 22:24:49.771 [ INFO]:bouquet: new bouquet 'Canal Digitaal HD'
2015-05-11 22:24:49.771 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/c881efad1a92192c6638249703bcd559
2015-05-11 22:24:49.772 [ INFO]:bouquet: new bouquet 'TV Vlaanderen SD'
2015-05-11 22:24:49.772 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/6b8a23a2f346afaeec66ee3a0e7b8cba
2015-05-11 22:24:49.772 [ INFO]:bouquet: new bouquet 'TV Vlaanderen HD'
2015-05-11 22:24:49.772 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/b8b4dd44b3448f52ccc32a8c15c29fe5
2015-05-11 22:24:49.772 [ INFO]:bouquet: new bouquet 'TéléSAT SD'
2015-05-11 22:24:49.772 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/e34e574e58a5f7a563b0eea05db3a4a4
2015-05-11 22:24:49.773 [ INFO]:bouquet: new bouquet 'TéléSAT HD'
2015-05-11 22:24:49.773 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/7f118ffbdf7901f513c0557d32ce8999
2015-05-11 22:24:49.773 [ INFO]:bouquet: new bouquet 'Mobistar NL Astra1'
2015-05-11 22:24:49.773 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/dae7a2fe9d637ef72e383041adafb3e8
2015-05-11 22:24:49.773 [ INFO]:bouquet: new bouquet 'Mobistar FR Astra1'
2015-05-11 22:24:49.773 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/1a8d1aecd948e1446d96c7057ea50dad
2015-05-11 22:24:49.774 [ INFO]:bouquet: new bouquet 'AustriaSat Astra1'
2015-05-11 22:24:49.774 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/0fb82373380976642825c9554013dd09
2015-05-11 22:24:49.774 [ INFO]:bouquet: new bouquet 'Canal Digitaal HD'
2015-05-11 22:24:49.774 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/6981b822f0a50ee23883382c2fd60d82
2015-05-11 22:24:49.775 [ INFO]:bouquet: new bouquet 'TV Vlaanderen HD'
2015-05-11 22:24:49.775 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/882f4e52350202cb5e052546d5c6083e
2015-05-11 22:24:49.775 [ INFO]:bouquet: new bouquet 'TéléSAT HD'
2015-05-11 22:24:49.775 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/cf7b11b08fec45c3d41aa029f59d19be
2015-05-11 22:24:49.776 [ INFO]:bouquet: new bouquet 'Mobistar NL Astra3'
2015-05-11 22:24:49.776 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/8df9bea7067c2980f2aabe24f56b5c26
2015-05-11 22:24:49.776 [ INFO]:bouquet: new bouquet 'Mobistar FR Astra3'
2015-05-11 22:24:49.776 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/d1d9eb221bcee6b64d4fb5efd1c77648
2015-05-11 22:24:49.776 [ INFO]:bouquet: new bouquet 'AustriaSat Astra3'
2015-05-11 22:24:49.776 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/ac03b06012b81eb65d2a6377cbd80aed
2015-05-11 22:24:49.777 [ INFO]:bouquet: new bouquet 'Skylink: Czech Republic'
2015-05-11 22:24:49.777 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/2f53335b1ec250442e73e7d3917156fc
2015-05-11 22:24:49.777 [ INFO]:bouquet: new bouquet 'Skylink: Slovak Republic'
2015-05-11 22:24:49.777 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/bouquet/6c90473e1a5b55a453f27423687380ec
2015-05-11 22:24:50.259 [ INFO]:scanfile: DVB-T - loaded 43 regions with 729 networks
2015-05-11 22:24:50.260 [ INFO]:scanfile: DVB-S - loaded 1 regions with 92 networks
2015-05-11 22:24:50.260 [ INFO]:scanfile: DVB-C - loaded 16 regions with 51 networks
2015-05-11 22:24:50.260 [ INFO]:scanfile: ATSC - loaded 2 regions with 14 networks
2015-05-11 22:24:50.261 [ DEBUG]:fsmonitor: watch /dev
2015-05-11 22:24:50.671 [ INFO]:dvr: Creating new configuration ''
2015-05-11 22:24:50.671 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/dvr/config/faf9449c430a5ffc389ec940fb00b864
2015-05-11 22:24:50.672 [WARNING]:dvr: Output directory for video recording is not yet configured for DVR configuration "". Defaulting to to "/usr/local/tvheadend-testing/var". This can be changed from the web user interface.
2015-05-11 22:24:50.673 [ INFO]:epggrab: module eit created
2015-05-11 22:24:50.673 [ INFO]:epggrab: module uk_freesat created
2015-05-11 22:24:50.673 [ INFO]:epggrab: module uk_freeview created
2015-05-11 22:24:50.673 [ INFO]:epggrab: module viasat_baltic created
2015-05-11 22:24:50.679 [ DEBUG]:opentv: dictionary skynz loaded
2015-05-11 22:24:50.679 [ DEBUG]:opentv: dictionary skyit loaded
2015-05-11 22:24:50.680 [ DEBUG]:opentv: dictionary skyeng loaded
2015-05-11 22:24:50.681 [ DEBUG]:opentv: dictonaries loaded
2015-05-11 22:24:50.683 [ DEBUG]:opentv: genre map ausat loaded
2015-05-11 22:24:50.683 [ DEBUG]:opentv: genre map skynz loaded
2015-05-11 22:24:50.683 [ DEBUG]:opentv: genre map skyit loaded
2015-05-11 22:24:50.683 [ DEBUG]:opentv: genre map skyuk loaded
2015-05-11 22:24:50.683 [ DEBUG]:opentv: genre maps loaded
2015-05-11 22:24:50.683 [ INFO]:epggrab: module opentv-ausat created
2015-05-11 22:24:50.683 [ DEBUG]:opentv: provider ausat loaded
2015-05-11 22:24:50.683 [ INFO]:epggrab: module opentv-skynz created
2015-05-11 22:24:50.683 [ DEBUG]:opentv: provider skynz loaded
2015-05-11 22:24:50.683 [ INFO]:epggrab: module opentv-skyit created
2015-05-11 22:24:50.684 [ DEBUG]:opentv: provider skyit loaded
2015-05-11 22:24:50.684 [ INFO]:epggrab: module opentv-skyuk created
2015-05-11 22:24:50.684 [ DEBUG]:opentv: provider skyuk loaded
2015-05-11 22:24:50.684 [ DEBUG]:opentv: providers loaded
2015-05-11 22:24:50.685 [ INFO]:epggrab: module pyepg created
2015-05-11 22:24:50.685 [ INFO]:epggrab: module xmltv created
2015-05-11 22:24:50.685 [ DEBUG]:epggrab: using internal grab search
2015-05-11 22:24:50.686 [ DEBUG]:epgdb: database does not exist
2015-05-11 22:24:50.686 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/config
2015-05-11 22:24:50.727 [ NOTICE]:START: HTS Tvheadend version 3.9.2818 started, running as PID:26771 UID:100 GID:1, CWD:/ CNF:/volume1/@appstore/tvheadend-testing/var
2015-05-11 22:25:01.207 [ ERROR]:http: 192.168.1.100: HTTP/1.1 GET / -- 401
2015-05-11 22:29:50.923 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/config
2015-05-11 22:35:19.341 [ DEBUG]:mpegts: Orange TV - adding mux Multiplex [onid:FFFF tsid:FFFF] in Orange TV to scan queue weight 5 flags 1000
2015-05-11 22:35:19.342 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/config
2015-05-11 22:35:29.001 [ DEBUG]:mpegts: D8 in Orange TV - add raw service
2015-05-11 22:35:29.001 [ DEBUG]:service: 1: D8 in Orange TV si 0xc67af0 <unknown> weight 0 prio 1 error 0
2015-05-11 22:35:29.001 [ INFO]:mpegts: D8 in Orange TV - tuning on IPTV
2015-05-11 22:35:29.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0000 (0) [20/0xcd76a0]
2015-05-11 22:35:29.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0001 (1) [16/0xcc6de0]
2015-05-11 22:35:29.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0010 (16) [16/0xcc8250]
2015-05-11 22:35:29.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0011 (17) [20/0xcc96c0]
2015-05-11 22:35:29.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0011 (17) [16/0xccab30]
2015-05-11 22:35:29.003 [ DEBUG]:mpegts: D8 in Orange TV - started
2015-05-11 22:35:29.003 [ INFO]:opentv-skyuk: registering mux D8 in Orange TV
2015-05-11 22:35:29.003 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/epggrab/otamux/6cbe3293f74f7877a65e98a947503dbc
2015-05-11 22:35:29.043 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/epggrab/otamux/6cbe3293f74f7877a65e98a947503dbc
2015-05-11 22:35:29.061 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/epggrab/otamux/6cbe3293f74f7877a65e98a947503dbc
2015-05-11 22:35:29.074 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/epggrab/otamux/6cbe3293f74f7877a65e98a947503dbc
2015-05-11 22:35:29.084 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/epggrab/otamux/6cbe3293f74f7877a65e98a947503dbc
2015-05-11 22:35:29.085 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/epggrab/otamux/6cbe3293f74f7877a65e98a947503dbc
2015-05-11 22:35:29.086 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/epggrab/otamux/6cbe3293f74f7877a65e98a947503dbc
2015-05-11 22:35:29.086 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0012 (18) [20/0xccbfa0]
2015-05-11 22:35:29.086 [ DEBUG]:eit: installed table handlers
2015-05-11 22:35:29.086 [ DEBUG]:eit: grab started
2015-05-11 22:35:29.086 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0BBA (3002) [16/0xccd410]
2015-05-11 22:35:29.086 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0BBB (3003) [16/0xcfb8e0]
2015-05-11 22:35:29.086 [ DEBUG]:uk_freesat: installed table handlers
2015-05-11 22:35:29.086 [ DEBUG]:uk_freesat: grab started
2015-05-11 22:35:29.086 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0039 (57) [16/0xcfcd50]
2015-05-11 22:35:29.086 [ DEBUG]:viasat_baltic: installed table handlers
2015-05-11 22:35:29.086 [ DEBUG]:viasat_baltic: grab started
2015-05-11 22:35:29.086 [ DEBUG]:mpegts: D8 in Orange TV - open PID tables subscription [0042/0xcd6060]
2015-05-11 22:35:29.086 [ INFO]:subscription: 0001: "scan" subscribing to mux "D8", weight: 5, adapter: "IPTV", network: "Orange TV", service: "Raw PID Subscription"
2015-05-11 22:35:29.129 [ DEBUG]:service: D8 in Orange TV: Status changed to [Demuxed packets]
2015-05-11 22:35:29.129 [ DEBUG]:service: D8 in Orange TV: Status changed to [Demuxed packets] [Reassembled packets]
2015-05-11 22:35:29.195 [ DEBUG]:pat: tsid 002A (42)
2015-05-11 22:35:29.195 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/config
2015-05-11 22:35:29.195 [ DEBUG]:pat: sid 106E (4206) on pid 0100 (256)
2015-05-11 22:35:29.195 [ DEBUG]:mpegts: D8 in Orange TV - add service 106E (null)
2015-05-11 22:35:29.195 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0100 (256) [16/0x7ff3000013c0]
2015-05-11 22:35:29.195 [ DEBUG]:pat: sid 079F (1951) on pid 16E1 (5857)
2015-05-11 22:35:29.195 [ DEBUG]:mpegts: D8 in Orange TV - add service 079F (null)
2015-05-11 22:35:29.195 [ DEBUG]:mpegts: D8 in Orange TV - open PID 16E1 (5857) [16/0x7ff300002fe0]
2015-05-11 22:35:29.196 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/services/b82d636e624d43784b9e067de3ce02bd
2015-05-11 22:35:29.197 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/services/98f2e9e49f0ecafd535a4abd630e516f
2015-05-11 22:35:29.260 [ DEBUG]:pat: completed pid 0 table 00000000 / 00000000
2015-05-11 22:35:29.261 [ DEBUG]:pmt: sid 106E (4206)
2015-05-11 22:35:29.261 [ DEBUG]:pmt: pcr_pid 080C
2015-05-11 22:35:29.261 [ DEBUG]:pmt: pid 080C estype 27
2015-05-11 22:35:29.261 [ DEBUG]:pmt: type H264 position 0
2015-05-11 22:35:29.261 [ DEBUG]:pmt: pid 080D estype 4
2015-05-11 22:35:29.261 [ DEBUG]:pmt: type MPEG2AUDIO position 0
2015-05-11 22:35:29.261 [ DEBUG]:pmt: language fre
2015-05-11 22:35:29.261 [ DEBUG]:pmt: pid 080E estype 4
2015-05-11 22:35:29.261 [ DEBUG]:pmt: language eng
2015-05-11 22:35:29.261 [ DEBUG]:pmt: pid 0813 estype 3
2015-05-11 22:35:29.261 [ DEBUG]:pmt: language qaa
2015-05-11 22:35:29.261 [ DEBUG]:pmt: pid 0814 estype 6
2015-05-11 22:35:29.261 [ DEBUG]:pmt: type TELETEXT position 0
2015-05-11 22:35:29.261 [ DEBUG]:pmt: Service "Orange TV/D8/{PMT:256}" PMT (version 4) updated, PCR PID changed, New elementary stream, Language changed, Parent PID changed, PIDs reordered
2015-05-11 22:35:29.262 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/services/b82d636e624d43784b9e067de3ce02bd
2015-05-11 22:35:29.392 [ DEBUG]:pmt: completed pid 256 table 00000002 / 000000ff
2015-05-11 22:35:29.392 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0100 (256) [16/0x7ff3000013c0]
2015-05-11 22:35:29.458 [ DEBUG]:cat: caid 0500 (1280) pid 0301 (769)
2015-05-11 22:35:29.918 [ DEBUG]:cat: completed pid 1 table 00000001 / 000000ff
2015-05-11 22:35:30.199 [ DEBUG]:sdt: onid 0001 (1) tsid 002A (42)
2015-05-11 22:35:30.199 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/config
2015-05-11 22:35:30.226 [ DEBUG]:sdt: mux D8 in Orange TV
2015-05-11 22:35:31.199 [ DEBUG]:eit: completed pid 18 table 00000000 / 00000000
2015-05-11 22:35:32.134 [ DEBUG]:sdt: completed pid 17 table 00000040 / 000000f8
2015-05-11 22:35:44.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 16E1 (5857) [16/0x7ff300002fe0]
2015-05-11 22:35:44.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0010 (16) [16/0xcc8250]
2015-05-11 22:35:44.001 [ INFO]:mpegts: D8 in Orange TV - scan complete
2015-05-11 22:35:44.001 [ DEBUG]:mpegts: D8 in Orange TV - 0100 (256) pmt complete
2015-05-11 22:35:44.001 [ DEBUG]:mpegts: D8 in Orange TV - 0011 (17) sdt complete
2015-05-11 22:35:44.001 [ DEBUG]:mpegts: D8 in Orange TV - 0001 (1) cat complete
2015-05-11 22:35:44.001 [ DEBUG]:mpegts: D8 in Orange TV - 0000 (0) pat complete
2015-05-11 22:35:44.001 [ INFO]:subscription: 0001: "scan" unsubscribing
2015-05-11 22:35:44.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID tables subscription [0042/0xcd6060]
2015-05-11 22:35:44.001 [ DEBUG]:mpegts: D8 in Orange TV - stopping mux
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0000 (0) [20/0xcd76a0]
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0001 (1) [16/0xcc6de0]
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0011 (17) [16/0xccab30]
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0011 (17) [20/0xcc96c0]
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0012 (18) [20/0xccbfa0]
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0039 (57) [16/0xcfcd50]
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0BBA (3002) [16/0xccd410]
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0BBB (3003) [16/0xcfb8e0]
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: Orange TV - removing mux D8 in Orange TV from scan queue
2015-05-11 22:35:44.002 [ DEBUG]:mpegts: Orange TV - adding mux D8 in Orange TV to scan queue weight 5 flags 0000
2015-05-11 22:35:44.002 [ DEBUG]:epggrab: grab done for D8 in Orange TV (stolen)
2015-05-11 22:35:44.003 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/config
2015-05-11 22:36:42.003 [ ERROR]:http: 192.168.1.100: HTTP/1.0 GET /stream/mux/6cbe3293f74f7877a65e98a947503dbc -- 401
2015-05-11 22:36:42.019 [ ERROR]:http: 192.168.1.100: HTTP/1.1 GET /stream/mux/6cbe3293f74f7877a65e98a947503dbc -- 401
2015-05-11 22:36:42.064 [ ERROR]:http: 192.168.1.100: HTTP/1.1 GET /stream/mux/6cbe3293f74f7877a65e98a947503dbc -- 401
2015-05-11 22:36:42.241 [ ERROR]:http: 192.168.1.100: HTTP/1.1 GET /stream/mux/6cbe3293f74f7877a65e98a947503dbc -- 401
2015-05-11 22:36:53.342 [ DEBUG]:mpegts: D8 in Orange TV - add raw service
2015-05-11 22:36:53.342 [ DEBUG]:service: 1: D8 in Orange TV si 0xcc5c90 <unknown> weight 0 prio 1 error 0
2015-05-11 22:36:53.342 [ INFO]:mpegts: D8 in Orange TV - tuning on IPTV
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0000 (0) [20/0xcd76a0]
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0001 (1) [16/0xcc6de0]
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0010 (16) [16/0xcc8250]
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0011 (17) [20/0xcc96c0]
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0011 (17) [16/0xccab30]
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - started
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0012 (18) [20/0xccbfa0]
2015-05-11 22:36:53.344 [ DEBUG]:eit: installed table handlers
2015-05-11 22:36:53.344 [ DEBUG]:eit: grab started
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0BBA (3002) [16/0xccd410]
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0BBB (3003) [16/0xcf00d0]
2015-05-11 22:36:53.344 [ DEBUG]:uk_freesat: installed table handlers
2015-05-11 22:36:53.344 [ DEBUG]:uk_freesat: grab started
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0039 (57) [16/0xcf1540]
2015-05-11 22:36:53.344 [ DEBUG]:viasat_baltic: installed table handlers
2015-05-11 22:36:53.344 [ DEBUG]:viasat_baltic: grab started
2015-05-11 22:36:53.344 [ DEBUG]:mpegts: D8 in Orange TV - open PID fullmux subscription [0003/0x7ff3040011d0]
2015-05-11 22:36:53.344 [ INFO]:subscription: 0002: "HTTP" subscribing to mux "D8", weight: 10, adapter: "IPTV", network: "Orange TV", service: "Raw PID Subscription", hostname="192.168.1.100", username="admin", client="Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; Win64; x64; Trident/7.0; .NET CLR 2.0.50727; SLCC2; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; Tablet PC 2.0)"
2015-05-11 22:36:53.463 [ DEBUG]:service: D8 in Orange TV: Status changed to [Demuxed packets]
2015-05-11 22:36:53.463 [ DEBUG]:service: D8 in Orange TV: Status changed to [Demuxed packets] [Reassembled packets]
2015-05-11 22:36:53.463 [ DEBUG]:webui: Start streaming /stream/mux/6cbe3293f74f7877a65e98a947503dbc
2015-05-11 22:36:53.529 [ DEBUG]:cat: caid 0500 (1280) pid 0301 (769)
2015-05-11 22:36:53.595 [ DEBUG]:pat: tsid 002A (42)
2015-05-11 22:36:53.595 [ DEBUG]:pat: sid 106E (4206) on pid 0100 (256)
2015-05-11 22:36:53.595 [ DEBUG]:pat: sid 079F (1951) on pid 16E1 (5857)
2015-05-11 22:36:53.661 [ DEBUG]:pat: completed pid 0 table 00000000 / 00000000
2015-05-11 22:36:53.990 [ DEBUG]:cat: completed pid 1 table 00000001 / 000000ff
2015-05-11 22:36:55.069 [ DEBUG]:sdt: onid 0001 (1) tsid 002A (42)
2015-05-11 22:36:55.069 [ DEBUG]:sdt: mux D8 in Orange TV
2015-05-11 22:36:55.529 [ DEBUG]:eit: completed pid 18 table 00000000 / 00000000
2015-05-11 22:36:57.069 [ DEBUG]:sdt: completed pid 17 table 00000040 / 000000f8
2015-05-11 22:37:09.922 [ INFO]:subscription: 0002: "HTTP" unsubscribing, hostname="192.168.1.100", username="admin", username="Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; Win64; x64; Trident/7.0; .NET CLR 2.0.50727; SLCC2; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E; Tablet PC 2.0)"
2015-05-11 22:37:09.922 [ DEBUG]:mpegts: D8 in Orange TV - close PID fullmux subscription [0003/0x7ff3040011d0]
2015-05-11 22:37:09.922 [ DEBUG]:mpegts: D8 in Orange TV - stopping mux
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0000 (0) [20/0xcd76a0]
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0001 (1) [16/0xcc6de0]
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0010 (16) [16/0xcc8250]
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0011 (17) [16/0xccab30]
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0011 (17) [20/0xcc96c0]
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0012 (18) [20/0xccbfa0]
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0039 (57) [16/0xcf1540]
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0BBA (3002) [16/0xccd410]
2015-05-11 22:37:09.924 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0BBB (3003) [16/0xcf00d0]
2015-05-11 22:37:09.924 [ DEBUG]:epggrab: grab done for D8 in Orange TV (stolen)
2015-05-11 23:15:29.815 [ INFO]:htsp: Got connection from 192.168.1.100
2015-05-11 23:15:29.815 [ INFO]:htsp: 192.168.1.100: Welcomed client software: XBMC Media Center (HTSPv12)
2015-05-11 23:15:29.823 [ INFO]:htsp: 192.168.1.100 [ XBMC Media Center ]: Identified as user admin
2015-05-11 23:15:29.823 [ INFO]:htsp: 192.168.1.100 [ admin | XBMC Media Center ]: Privileges raised
2015-05-11 23:15:39.826 [ INFO]:htsp: 192.168.1.100 [ admin | XBMC Media Center ]: Disconnected
2015-05-11 23:15:39.986 [ INFO]:htsp: Got connection from 192.168.1.100
2015-05-11 23:15:39.997 [ INFO]:htsp: 192.168.1.100: Welcomed client software: XBMC Media Center (HTSPv12)
2015-05-11 23:15:39.997 [ INFO]:htsp: 192.168.1.100 [ XBMC Media Center ]: Identified as user admin
2015-05-11 23:15:39.997 [ INFO]:htsp: 192.168.1.100 [ admin | XBMC Media Center ]: Privileges raised
2015-05-11 23:19:36.022 [ INFO]:htsp: 192.168.1.100 [ admin | XBMC Media Center ]: Disconnected
2015-05-11 23:47:52.425 [ INFO]:htsp: Got connection from 192.168.1.100
2015-05-11 23:47:52.425 [ INFO]:htsp: 192.168.1.100: Welcomed client software: XBMC Media Center (HTSPv12)
2015-05-11 23:47:52.429 [ INFO]:htsp: 192.168.1.100 [ XBMC Media Center ]: Identified as user admin
2015-05-11 23:47:52.430 [ INFO]:htsp: 192.168.1.100 [ admin | XBMC Media Center ]: Privileges raised
2015-05-11 23:49:18.435 [ INFO]:htsp: 192.168.1.100 [ admin | XBMC Media Center ]: Disconnected
2015-05-12 02:04:01.001 [ DEBUG]:mpegts: D8 in Orange TV - add raw service
2015-05-12 02:04:01.001 [ DEBUG]:service: 1: D8 in Orange TV si 0xc67af0 <unknown> weight 0 prio 1 error 0
2015-05-12 02:04:01.001 [ INFO]:mpegts: D8 in Orange TV - tuning on IPTV
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0000 (0) [20/0xcd76a0]
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0001 (1) [16/0xcc6de0]
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0010 (16) [16/0xcc8250]
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0011 (17) [20/0xcc96c0]
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0011 (17) [16/0xccab30]
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - started
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0012 (18) [20/0xccbfa0]
2015-05-12 02:04:01.002 [ DEBUG]:eit: installed table handlers
2015-05-12 02:04:01.002 [ DEBUG]:eit: grab started
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0BBA (3002) [16/0xccd410]
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0BBB (3003) [16/0xcfb8e0]
2015-05-12 02:04:01.002 [ DEBUG]:uk_freesat: installed table handlers
2015-05-12 02:04:01.002 [ DEBUG]:uk_freesat: grab started
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID 0039 (57) [16/0xcfcd50]
2015-05-12 02:04:01.002 [ DEBUG]:viasat_baltic: installed table handlers
2015-05-12 02:04:01.002 [ DEBUG]:viasat_baltic: grab started
2015-05-12 02:04:01.002 [ DEBUG]:mpegts: D8 in Orange TV - open PID tables subscription [0042/0xcd6060]
2015-05-12 02:04:01.002 [ INFO]:subscription: 0003: "epggrab" subscribing to mux "D8", weight: 4, adapter: "IPTV", network: "Orange TV", service: "Raw PID Subscription"
2015-05-12 02:04:01.119 [ DEBUG]:service: D8 in Orange TV: Status changed to [Demuxed packets]
2015-05-12 02:04:01.119 [ DEBUG]:service: D8 in Orange TV: Status changed to [Demuxed packets] [Reassembled packets]
2015-05-12 02:04:01.119 [ DEBUG]:pat: tsid 002A (42)
2015-05-12 02:04:01.119 [ DEBUG]:pat: sid 106E (4206) on pid 0100 (256)
2015-05-12 02:04:01.119 [ DEBUG]:pat: sid 079F (1951) on pid 16E1 (5857)
2015-05-12 02:04:01.119 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/services/b82d636e624d43784b9e067de3ce02bd
2015-05-12 02:04:01.151 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/input/iptv/networks/260780e28286c7b211a5a102ac69aa8a/muxes/6cbe3293f74f7877a65e98a947503dbc/services/98f2e9e49f0ecafd535a4abd630e516f
2015-05-12 02:04:01.251 [ DEBUG]:pat: completed pid 0 table 00000000 / 00000000
2015-05-12 02:04:01.448 [ DEBUG]:cat: caid 0500 (1280) pid 0301 (769)
2015-05-12 02:04:01.777 [ DEBUG]:sdt: onid 0001 (1) tsid 002A (42)
2015-05-12 02:04:01.777 [ DEBUG]:sdt: mux D8 in Orange TV
2015-05-12 02:04:01.909 [ DEBUG]:cat: completed pid 1 table 00000001 / 000000ff
2015-05-12 02:04:03.132 [ DEBUG]:eit: completed pid 18 table 00000000 / 00000000
2015-05-12 02:04:03.790 [ DEBUG]:sdt: completed pid 17 table 00000040 / 000000f8
2015-05-12 02:05:02.199 [ DEBUG]:eit: completed pid 18 table 00000000 / 00000000
2015-05-12 02:14:16.000 [ DEBUG]:epggrab: grab done for D8 in Orange TV (timeout)
2015-05-12 02:14:16.000 [WARNING]:epggrab: EIT: DVB Grabber - data completion timeout for D8 in Orange TV
2015-05-12 02:14:16.000 [WARNING]:epggrab: UK: Freesat - data completion timeout for D8 in Orange TV
2015-05-12 02:14:16.000 [WARNING]:epggrab: VIASAT: Baltic - data completion timeout for D8 in Orange TV
2015-05-12 02:14:16.000 [ INFO]:subscription: 0003: "epggrab" unsubscribing
2015-05-12 02:14:16.000 [ DEBUG]:mpegts: D8 in Orange TV - close PID tables subscription [0042/0xcd6060]
2015-05-12 02:14:16.000 [ DEBUG]:mpegts: D8 in Orange TV - stopping mux
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0000 (0) [20/0xcd76a0]
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0001 (1) [16/0xcc6de0]
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0010 (16) [16/0xcc8250]
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0011 (17) [16/0xccab30]
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0011 (17) [20/0xcc96c0]
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0012 (18) [20/0xccbfa0]
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0039 (57) [16/0xcfcd50]
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0BBA (3002) [16/0xccd410]
2015-05-12 02:14:16.001 [ DEBUG]:mpegts: D8 in Orange TV - close PID 0BBB (3003) [16/0xcfb8e0]
2015-05-12 02:14:16.001 [ DEBUG]:settings: saving to /volume1/@appstore/tvheadend-testing/var/epggrab/otamux/6cbe3293f74f7877a65e98a947503dbc
2015-05-12 08:48:34.001 [ ERROR]:satip: Cannot get http://192.168.1.100:8089/description.xml: Success
2015-05-12 13:22:19.181 [ INFO]:htsp: Got connection from 192.168.1.100
2015-05-12 13:22:19.181 [ INFO]:htsp: 192.168.1.100: Welcomed client software: XBMC Media Center (HTSPv12)
2015-05-12 13:22:19.200 [ INFO]:htsp: 192.168.1.100 [ XBMC Media Center ]: Identified as user admin
2015-05-12 13:22:19.200 [ INFO]:htsp: 192.168.1.100 [ admin | XBMC Media Center ]: Privileges raised
2015-05-12 13:24:33.205 [ INFO]:htsp: 192.168.1.100 [ admin | XBMC Media Center ]: Disconnected
2015-05-12 13:25:01.336 [ INFO]:htsp: Got connection from 192.168.1.100
2015-05-12 13:25:01.336 [ INFO]:htsp: 192.168.1.100: Welcomed client software: Kodi Media Center (HTSPv12)
2015-05-12 13:25:01.338 [ INFO]:htsp: 192.168.1.100 [ Kodi Media Center ]: Identified as user admin
2015-05-12 13:25:01.338 [ INFO]:htsp: 192.168.1.100 [ admin | Kodi Media Center ]: Privileges raised
2015-05-12 13:32:30.407 [ INFO]:htsp: 192.168.1.100 [ admin | Kodi Media Center ]: Disconnected
2015-05-12 13:32:32.363 [ INFO]:htsp: Got connection from 192.168.1.100
2015-05-12 13:32:32.373 [ INFO]:htsp: 192.168.1.100: Welcomed client software: Kodi Media Center (HTSPv12)
2015-05-12 13:32:32.374 [ INFO]:htsp: 192.168.1.100 [ Kodi Media Center ]: Identified as user admin
2015-05-12 13:32:32.374 [ INFO]:htsp: 192.168.1.100 [ admin | Kodi Media Center ]: Privileges raised
2015-05-12 13:43:02.402 [ INFO]:htsp: 192.168.1.100 [ admin | Kodi Media Center ]: Disconnected
2015-05-12 13:43:29.603 [ INFO]:htsp: Got connection from 192.168.1.100
2015-05-12 13:43:29.604 [ INFO]:htsp: 192.168.1.100: Welcomed client software: Kodi Media Center (HTSPv12)
2015-05-12 13:43:29.606 [ INFO]:htsp: 192.168.1.100 [ Kodi Media Center ]: Identified as user admin
2015-05-12 13:43:29.606 [ INFO]:htsp: 192.168.1.100 [ admin | Kodi Media Center ]: Privileges raised
2015-05-12 13:43:58.132 [ INFO]:htsp: 192.168.1.100 [ admin | Kodi Media Center ]: Disconnected
2015-05-12 13:48:55.691 [ ERROR]:http: 192.168.1.100: HTTP/1.1 GET / -- 401
2015-05-12 13:49:32.701 [ ERROR]:http: 192.168.1.100: HTTP/1.1 GET /stream/channel -- 400
2015-05-12 13:49:51.764 [ ERROR]:http: 192.168.1.100: HTTP/1.1 GET /stream/channel -- 400
2015-05-12 14:04:01.000 [ DEBUG]:epggrab: no OTA modules active for D8 in Orange TV, check again next time
2015-05-12 15:21:44.255 [ INFO]:epgdb: snapshot start
2015-05-12 15:21:44.255 [ INFO]:epgdb: queued to save (size 191)
2015-05-12 15:21:44.255 [ INFO]:epgdb: brands 0
2015-05-12 15:21:44.255 [ INFO]:epgdb: seasons 0
2015-05-12 15:21:44.255 [ INFO]:epgdb: episodes 0
2015-05-12 15:21:44.255 [ INFO]:epgdb: broadcasts 0
2015-05-12 15:21:44.275 [ INFO]:mpegts: D8 in Orange TV (0x7ff2fc03ea30) - deleting
2015-05-12 15:21:44.275 [ DEBUG]:mpegts: Orange TV - removing mux D8 in Orange TV from scan queue
2015-05-12 15:21:44.275 [ DEBUG]:fsmonitor: unwatch /dev
2015-05-12 15:21:44.426 [ INFO]:epgdb: save start
2015-05-12 15:21:44.426 [ INFO]:epgdb: stored (size 191)
2015-05-12 15:21:44.625 [ NOTICE]:STOP: Exiting HTS Tvheadend
2015-05-12 15:26:01.459 [ INFO]:main: Log started
2015-05-12 15:26:01.616 [ INFO]:config: loaded
2015-05-12 15:26:02.084 [ INFO]:scanfile: DVB-T - loaded 43 regions with 729 networks
2015-05-12 15:26:02.084 [ INFO]:scanfile: DVB-S - loaded 1 regions with 92 networks
2015-05-12 15:26:02.084 [ INFO]:scanfile: DVB-C - loaded 16 regions with 51 networks
2015-05-12 15:26:02.084 [ INFO]:scanfile: ATSC - loaded 2 regions with 14 networks
2015-05-12 15:26:02.134 [ DEBUG]:mpegts: D8 in Orange TV - add service 106E D8
2015-05-12 15:26:02.134 [ DEBUG]:mpegts: D8 in Orange TV - add service 079F D8
2015-05-12 15:26:02.134 [ DEBUG]:fsmonitor: watch /dev
2015-05-12 15:26:02.554 [ INFO]:dvr: Creating new configuration ''
2015-05-12 15:26:02.554 [WARNING]:dvr: Output directory for video recording is not yet configured for DVR configuration "". Defaulting to to "/usr/local/tvheadend-testing/var". This can be changed from the web user interface.
2015-05-12 15:26:02.556 [ INFO]:epggrab: module eit created
2015-05-12 15:26:02.556 [ INFO]:epggrab: module uk_freesat created
2015-05-12 15:26:02.556 [ INFO]:epggrab: module uk_freeview created
2015-05-12 15:26:02.556 [ INFO]:epggrab: module viasat_baltic created
2015-05-12 15:26:02.563 [ DEBUG]:opentv: dictionary skynz loaded
2015-05-12 15:26:02.563 [ DEBUG]:opentv: dictionary skyit loaded
2015-05-12 15:26:02.564 [ DEBUG]:opentv: dictionary skyeng loaded
2015-05-12 15:26:02.565 [ DEBUG]:opentv: dictonaries loaded
2015-05-12 15:26:02.566 [ DEBUG]:opentv: genre map ausat loaded
2015-05-12 15:26:02.566 [ DEBUG]:opentv: genre map skynz loaded
2015-05-12 15:26:02.566 [ DEBUG]:opentv: genre map skyit loaded
2015-05-12 15:26:02.566 [ DEBUG]:opentv: genre map skyuk loaded
2015-05-12 15:26:02.566 [ DEBUG]:opentv: genre maps loaded
2015-05-12 15:26:02.567 [ INFO]:epggrab: module opentv-ausat created
2015-05-12 15:26:02.567 [ DEBUG]:opentv: provider ausat loaded
2015-05-12 15:26:02.567 [ INFO]:epggrab: module opentv-skynz created
2015-05-12 15:26:02.567 [ DEBUG]:opentv: provider skynz loaded
2015-05-12 15:26:02.567 [ INFO]:epggrab: module opentv-skyit created
2015-05-12 15:26:02.568 [ DEBUG]:opentv: provider skyit loaded
2015-05-12 15:26:02.568 [ INFO]:epggrab: module opentv-skyuk created
2015-05-12 15:26:02.569 [ DEBUG]:opentv: provider skyuk loaded
2015-05-12 15:26:02.569 [ DEBUG]:opentv: providers loaded
2015-05-12 15:26:02.570 [ INFO]:epggrab: module pyepg created
2015-05-12 15:26:02.570 [ INFO]:epggrab: module xmltv created
2015-05-12 15:26:02.570 [ DEBUG]:epggrab: using internal grab search
2015-05-12 15:26:02.585 [ INFO]:epgdb: loaded v2
2015-05-12 15:26:02.585 [ INFO]:epgdb: config 1
2015-05-12 15:26:02.585 [ INFO]:epgdb: channels 0
2015-05-12 15:26:02.585 [ INFO]:epgdb: brands 0
2015-05-12 15:26:02.585 [ INFO]:epgdb: seasons 0
2015-05-12 15:26:02.585 [ INFO]:epgdb: episodes 0
2015-05-12 15:26:02.585 [ INFO]:epgdb: broadcasts 0
2015-05-12 15:26:02.586 [ NOTICE]:START: HTS Tvheadend version 3.9.2818 started, running as PID:14607 UID:100 GID:1, CWD:/ CNF:/volume1/@appstore/tvheadend-testing/var
2015-05-12 15:26:02.587 [ DEBUG]:epggrab: no OTA modules active for D8 in Orange TV, check again next time
The PVR clients are part of the Windows installer - they should all be installed by default (which can be a pain, but evidently not as much of a pain as not having them installed at all).
So, during installation, you get this:
If you want, you can expand this tree to only select specific PVR clients:
Just make sure 'hts' is enabled, as that's the tvheadend addon.
It may be that you simply need to re-install Kodi - it should simply install over the top of what you have and not affect any of your settings.
EDIT
That's a 14.2 install screen, by the way - 15 would be similar, I suspect, although I haven't looked so can't be certain.
Ok I re-installed Kodi 14.2 with HTS PRV. So I have "TVHeadend Client" and "TVHeadend HTSP Client" in the addon PVR setup with the NAS IP.
Here is the screen in TV Live (no channel displayed)
TVHeadend server on Synology NAS
Config TVHeadend server
I don't understand why nothing displayed in TV Live
Two thoughts:
1. I'm not sure about having both of those PVR addons enabled. You only need one - the HTSP client is the default for 14.2, although the other one (assuming it's pvr.tvh) will also work. You just don't need boths.
2. Are the addons configured properly to connect to the tvh server - IP address, username, password?
3. Are there any access control rules (under 'Access Entries') that are getting in the way?
4. You have a mux defined - only one, which is odd, but... - have you scanned it for services? Mapped the service to channels? And, before that, associated it with a TV tuner?
... okay, that was four. I type faster than I think sometimes...
1. Ok I enable only the HTSP Client addon
2. IP, username, pwd OK
3. I don't understand (sorry I'm so french)
4. I'm on IPTV, so no TV tuner, but, perhaps the source of the problem ? I've network name Orange. Only one channel for test (no DRM)
Apologies...
I meant "3. Are there any access control entries that may prevent you from getting access?", But you've checked that.
I don't use IPTV, so I don't know exactly how it works, but not having a tuner shouldn't be a problem because... well, because you can't have one.
Looking back up - one line in your log - 'no OTA modules active...'. Do you have an EPG source? Is it working?
In other words, if you look in the tvheadend web interface, can you see the programme schedule? If it's blank there, Kodi has nothing to display. If there isn't an over-the-air EPG then you may have to use XMLTV or something instead.
Do you think that no EPG can be the source of the problem ?
I have an EPG but It isn't connect to TVH because I use DVBViewer at this time on my windows computer for TV Live
I suppose it's worth shifting attention back to tvheadend first... I don't know what happens if you have no EPG entries, though. It might be that there's nothing to 'lock onto' from Kodi.
Do you have a list of services in tvheadend's web interface? Can you play any of them in, say, VLC?
Have you mapped them to channels? Can you play the channels in VLC?
Are any of them mapped to channel groups (tags)? Can you see any of these in Kodi?
1) check the channel tab in tvheadend to make sure you really have any channels mapped
2) only enable one of the addons you have. I recommend the one named "Tvheadend Client", it's based on newer code. Once you upgrade to Isengard you'll have to uninstall that one though and use the other one ("Tvheadend HTSP Client").
3) enable debug logging in Kodi and post a new log if you still can't see any channels.
