Full Version: kodi v15 - Skin sound addons, supported audio types.
With v15 will come support for separate skin audio addons.
Is there a specific wav type or program recommended to make these wavs compatible? And are the sounds restricted to wav? Can they be mp3 or other?
The reason I ask is, in the past I tried putting some sounds in and none played even though they were wavs.
ping?
Any wav should do, but if in doubt try "ffmpeg -i in.xx out.wav". That should give you pcm_s16le which definitely work. (And yes, no mp3 or other, only wav)
Right 16bit wav only then, Im pretty sure not all wavs work for navigations side.
Thank you for confirmation.
