2015-05-17, 17:03
(2015-05-15, 22:37)DanCooper Wrote: [ -> ]We don't need an additional "folder.jpg" field! Simply add "folder.jpg" into the poster field in expert settings and Ember would create an additional folder.jpg file while saving all other files. Ember does also recognize existing folder.jpg with this setting.
Instead of adding folder.jpg to expert settings?
Why not just duplicate/copy the poster.jpg image as a duplicate as folder.jpg.
That way in the folder there would be
-poster image
-folder image.
Then there is no issues with export.
Also can u explain why we need to export these images in kodi, if the files are local to the movie folders?
Do u have your movies in thumbnail mode in Explorer?
You will see how crap it looks without folder.jpg...
Then when you have folder.jpg in each movie folder, it looks great.
This is not just cosmetic but is also functional.
Because I can quickly identify movies from their thumbnail in explorer.
It makes it easier to manage.
Also folder.jpg is used by other programs like Windows Media Center etc..
as pointed out by ...shaktoo
