2015-05-14, 20:06
I've been trying to google up an answer to this for a little while now and while I'm sure it must be a fairly common requirement, my google fu & search fu are failing me and I'm just not finding what I'm looking for..
I have a setup with two Kodi devices, one in the livingroom and one in the bedroom which share a MySQL hosted library;
Livingroom: Asus EB1502P w/ Kodibuntu, Sharp Aquos LCD, Arcam AV9 & P7, audio via SP/DIV, video via HDMI
Bedroom: Asus EB1502P w/ Kodibuntu, LG Plasma, video & audio via HDMI
The problem is that the setup downstairs needs a consistent 250ms audio offset for the audio & video to be in sync (down to the different audio & video paths, I expect) while upstairs needs a consistent 0ms audio offset (presumably because the audio & video path is pure HDMI)
The audio offset is stored in the database and of course downstairs I've previously set a 250ms delay and then "Set as default" that, if upstairs I "set as default" 0ms then downstairs will be wrong..
A little googling suggested adding this to advancedsettings.xml:
But that doesn't seem to override the 250ms from downstairs, I presume because I've "set as default" that amount..
So is there a dance I can do that will get me 250ms by default downstairs and 0ms by default upstairs?
<advancedsettings>
<defaultvideosettings>
<audiodelay>0</audiodelay>
</defaultvideosettings>
</advancedsettings>
