2015-05-16, 15:01
I started working on my first Kodi addon (I finally broke the seal of starting Kodi development ). I have been searching for more then a day and eventually I will work it out, but I want to continue focusing on my addon development before I will deep dive in skin development.
When I use for example Spotlight and have an album list I could only select the default views like list and wall.
If I enable Library mode via the Music navigation side bar and then go to the add-ons menu item in the library section and then go to Spotlight all the views available like (biglist, infowall), etc.. (I understand some views are 'broken').
I would really appreciate if somebody could point me to:
- The skin XML setting where you could configure the available views for the view modes (Library or non Library)
- I know you can force view mode by using 'Container.SetViewMode' in an addon, but then the view mode will only be used when in Library mode. Is there a way to make this Library view modes working from an addon when not being in Library mode? I think I have to solve this with my above question, but who knows?)
Thanks in advance!
Thanks in advance!
