Well in this case I see 2 ways to see what you want :
A/ a dirty option
B/ a dirtier option
One option (choose A or B), query directly the database.
In this case :
- you know what you are doing
- you know what you are looking for
- you know (or at least you know the minium) to perform a SQL query.
An other option is to tweak the SongInfo Sheet of the theme you are using :
In this case :
- you know how to ssh into your RPi
- you know how to alter a file (how to use nano for example)
1/ go into the skin folder /usr/share/kodi/addons/skin.confluence/720p
2/ DO A BACKUP of the FILE DialogSongInfo.xml !!! and 2! more !!
3/ tweak the file DialogSongInfo.xml
4/ restart kodi
5/ enjoy (I tested it myself)
I'll explain you this method. My configuration is as follow:
- hardware : RPi-B
- OS : OSMC
- software : kodi 14.2
- theme : Confluence
I don't use Confluence any more, but same skin with OpenElec, so adapt if needed
ssh or go into a console of your RPi
and change to /usr/share/kodi/addons/skin.confluence/720p
login : osmc
password : osmc
osmc@rpi:~$ cd /usr/share/kodi/addons/skin.confluence/720p
osmc@rpi:/usr/share/kodi/addons/skin.confluence/720p$
2/ do a backup of the tweaked file DialogSongInfo.xml.
almost all the files are owned by root... you'll need to sudo all your commande
osmc@rpi:/usr/share/kodi/addons/skin.confluence/720p$ sudo cp DialogSongInfo.xml DialogSongInfo.xml.backup
3/ tweak the file DialogSongInfo.xml to add the pathname
osmc@rpi:/usr/share/kodi/addons/skin.confluence/720p$ sudo nano DialogSongInfo.xml
Here is the file : look for this code
<control type="textbox">
<description>Comment value</description>
<left>160</left>
<top>177</top>
<width>460</width>
<height>140</height>
<font>font13</font>
<pagecontrol>-</pagecontrol>
<label fallback="161">$INFO[ListItem.Comment]</label>
</control>
</control>
Insert this code just after
<control type="label">
<description>Path Label</description>
<left>20</left>
<top>415</top>
<width>150</width>
<height>25</height>
<align>left</align>
<aligny>center</aligny>
<font>font13</font>
<textcolor>white</textcolor>
<label fallback="161">$LOCALIZE[573]:</label>
</control>
<control type="fadelabel">
<description>Path Value</description>
<left>170</left>
<top>415</top>
<width>700</width>
<height>25</height>
<align>right</align>
<font>font13</font>
<textcolor>blue</textcolor>
<label fallback="161">$INFO[ListItem.FileNameAndPath]:</label>
</control>
And here is the "end" of the file
<control type="group" id="9000">
<left>40</left>
<top>445</top>
<control type="button" id="10">
<description>Ok button</description>
<left>0</left>
<top>0</top>
<width>200</width>
<height>40</height>
<label>186</label>
<font>font12_title</font>
I tested these values to be as smooth as possible with the display
4/ restart kodi
As I al under OSMC, here is the OSMC command (I don't know the Openelec command)
osmc@rpi:/usr/share/kodi/addons/skin.confluence/720p$ sudo systemctl restart mediacenter
5/ enjoy.
I tested it, it works,
when "info" on a file, it display the path and the filename
