Hi all,
I've just installed kodi, and I'm trying to get the web interface working (so I can get the remote working). I've enabled 'allow control of Kodi via HTTP', and enabled the two options under remote control.
When I try to browse to
http://192.168.1.2:80 (also tried 8080), I get 'This web page is not available' in chrome. I've tried the same thing from my phone. I turned off windows firewall, and my router firewall. No change. Any advise?
hm... strange. the settings are ok.
what happens if you try to estabilish a telnet connection on the ip and port?
http://localhost:<port> on the machine you installed kodi?
could there be any other software interfere, like an anti virus or another server?
do the kodi log's say something which could help?
(2015-05-17, 19:14)tuxfuxch Wrote: [ -> ]hm... strange. the settings are ok.
what happens if you try http://localhost:<port> on the machine you installed kodi?
Telnet to port 80 fails.
I can't access the web interface on the machine I installed kodi on either.
I tried disabling microsoft security essentials, no luck. That's the only anti-virus I'm running.
Here's my log, I don't see a red flag, but I don't know what I'm looking for.
Quote:14:10:47 T:2324 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:10:47 T:2324 NOTICE: -----------------------------------------------------------------------
14:10:47 T:2324 NOTICE: Starting Kodi (14.2 Git:20150326-7cc53a9). Platform: Windows NT x86 32-bit
14:10:47 T:2324 NOTICE: Using Release Kodi x32 build
14:10:47 T:2324 NOTICE: Kodi compiled Mar 26 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
14:10:47 T:2324 NOTICE: Running on Dell Inc. OptiPlex 3010 with Windows 7 SP1, kernel: Windows NT x86 64-bit version 6.1
14:10:47 T:2324 NOTICE: Host CPU: Intel® Core i5-3450 CPU @ 3.10GHz, 4 cores available
14:10:48 T:2324 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
14:10:48 T:2324 NOTICE: Running with restricted rights
14:10:48 T:2324 NOTICE: Aero is enabled
14:10:48 T:2324 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
14:10:48 T:2324 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
14:10:48 T:2324 NOTICE: special://masterprofile/ is mapped to: C:\Users\keats\AppData\Roaming\Kodi\userdata
14:10:48 T:2324 NOTICE: special://home/ is mapped to: C:\Users\keats\AppData\Roaming\Kodi\
14:10:48 T:2324 NOTICE: special://temp/ is mapped to: C:\Users\keats\AppData\Roaming\Kodi\cache
14:10:48 T:2324 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
14:10:48 T:2324 NOTICE: Local hostname: keats-PC
14:10:48 T:2324 NOTICE: Log File is located: C:\Users\keats\AppData\Roaming\Kodi\kodi.log
14:10:48 T:2324 NOTICE: -----------------------------------------------------------------------
14:10:48 T:2324 NOTICE: load settings...
14:10:48 T:2324 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
14:10:49 T:2324 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
14:10:49 T:2324 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
14:10:49 T:2324 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
14:10:49 T:2324 NOTICE: Default DVD Player: dvdplayer
14:10:49 T:2324 NOTICE: Default Video Player: dvdplayer
14:10:49 T:2324 NOTICE: Default Audio Player: paplayer
14:10:49 T:2324 NOTICE: Disabled debug logging due to GUI setting. Level 0.
14:10:49 T:2324 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
14:10:49 T:2324 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
14:10:49 T:2324 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:10:49 T:2324 NOTICE: Loaded playercorefactory configuration
14:10:49 T:2324 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:10:49 T:2324 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:10:50 T:5144 NOTICE: Thread ActiveAE start, auto delete: false
14:10:50 T:5148 NOTICE: Thread AESink start, auto delete: false
14:10:50 T:5144 NOTICE: Found 2 Lists of Devices
14:10:50 T:5144 NOTICE: Enumerated DIRECTSOUND devices:
14:10:50 T:5144 NOTICE: Device 1
14:10:50 T:5144 NOTICE: m_deviceName : {D071801A-1CA8-4D7D-8DE5-6AF1EF6BB590}
14:10:50 T:5144 NOTICE: m_displayName : Speakers - Speakers (Conexant HD Audio)
14:10:50 T:5144 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (Conexant HD Audio)
14:10:50 T:5144 NOTICE: m_deviceType : AE_DEVTYPE_PCM
14:10:50 T:5144 NOTICE: m_channels : FL,FR
14:10:50 T:5144 NOTICE: m_sampleRates : 44100
14:10:50 T:5144 NOTICE: m_dataFormats : AE_FMT_FLOAT
14:10:51 T:5144 NOTICE: Device 2
14:10:51 T:5144 NOTICE: m_deviceName : default
14:10:51 T:5144 NOTICE: m_displayName : default
14:10:51 T:5144 NOTICE: m_displayNameExtra:
14:10:51 T:5144 NOTICE: m_deviceType : AE_DEVTYPE_PCM
14:10:51 T:5144 NOTICE: m_channels : FL,FR
14:10:51 T:5144 NOTICE: m_sampleRates : 44100
14:10:51 T:5144 NOTICE: m_dataFormats : AE_FMT_FLOAT
14:10:51 T:5144 NOTICE: Enumerated WASAPI devices:
14:10:51 T:5144 NOTICE: Device 1
14:10:51 T:5144 NOTICE: m_deviceName : {D071801A-1CA8-4D7D-8DE5-6AF1EF6BB590}
14:10:51 T:5144 NOTICE: m_displayName : Speakers - Speakers (Conexant HD Audio)
14:10:51 T:5144 NOTICE: m_displayNameExtra: WASAPI: Speakers (Conexant HD Audio)
14:10:51 T:5144 NOTICE: m_sampleRates : 192000,96000,48000,44100
14:10:51 T:5144 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
14:10:52 T:2324 NOTICE: Running database version Addons16
14:10:52 T:2324 NOTICE: ADDONS: Using repository repository.xbmc.org
14:10:52 T:5268 NOTICE: Thread RemoteControl start, auto delete: false
14:10:52 T:5272 NOTICE: Thread PeripBusCEC start, auto delete: false
14:10:52 T:5276 NOTICE: Thread PeripBusUSB start, auto delete: false
14:10:52 T:2324 NOTICE: Found screen: Generic PnP Monitor on Intel® HD Graphics, adapter 0.
14:10:52 T:2324 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
14:10:52 T:2324 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
14:10:52 T:2324 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
14:10:52 T:2324 NOTICE: Previous line repeats 2 times.
14:10:52 T:2324 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
14:10:52 T:2324 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
14:10:52 T:2324 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
14:10:53 T:2324 NOTICE: Additional mode: 848x480@ 60.00 - Full Screen
14:10:53 T:2324 NOTICE: Previous line repeats 2 times.
14:10:53 T:2324 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
14:10:53 T:2324 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
14:10:53 T:2324 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
14:10:53 T:2324 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
14:10:53 T:2324 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
14:10:53 T:2324 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
14:10:53 T:2324 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
14:10:54 T:2324 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
14:10:54 T:2324 NOTICE: Checking resolution 16
14:10:55 T:2324 NOTICE: Running database version Addons16
14:10:55 T:2324 NOTICE: Running database version ViewModes6
14:10:55 T:2324 NOTICE: Running database version Textures13
14:10:55 T:2324 NOTICE: Running database version MyMusic48
14:10:55 T:2324 NOTICE: Running database version MyVideos90
14:10:55 T:2324 NOTICE: Running database version TV26
14:10:55 T:2324 NOTICE: Running database version Epg8
14:11:02 T:2324 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
14:11:02 T:2324 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
14:11:02 T:2324 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
14:11:02 T:2324 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
14:11:02 T:5420 NOTICE: Thread LanguageInvoker start, auto delete: false
14:11:02 T:2324 NOTICE: initialize done
14:11:02 T:2324 NOTICE: Running the application...
14:11:03 T:5460 NOTICE: Thread JobWorker start, auto delete: true
14:11:04 T:2324 NOTICE: ES: Starting event server
14:11:04 T:5472 NOTICE: Thread EventServer start, auto delete: false
14:11:04 T:5472 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
14:11:04 T:5476 NOTICE: Thread TCPServer start, auto delete: false
14:11:04 T:5472 NOTICE: UDP: Listening on port 9777
14:11:04 T:5516 NOTICE: Thread RSSReader start, auto delete: false
14:11:09 T:5420 NOTICE: -->Python Interpreter Initialized<--
14:11:09 T:5660 NOTICE: Thread BackgroundLoader start, auto delete: false
14:11:21 T:2324 NOTICE: Webserver: Starting...
Not sure which remote you're using, but go to port forwarding on your router. Use the port that you have Kodi set to (default is 80, i have mine on 97) and put that as the port to forward (i have mine set to 'BOTH' UDP and TCP...works for me). Then the IP address of the Kodi machine. You can find that in Kodi settings. Save changes.
(2015-05-18, 02:14)handbone Wrote: [ -> ]Not sure which remote you're using, but go to port forwarding on your router. Use the port that you have Kodi set to (default is 80, i have mine on 97) and put that as the port to forward (i have mine set to 'BOTH' UDP and TCP...works for me). Then the IP address of the Kodi machine. You can find that in Kodi settings. Save changes.
Hmmm, I tried that but I'm getting the same result.
