hi i got cloud tv box it a xbmc install already but a need upgrade and istall a kodo 14 .0 wher I can find what plataform i need to install arm, o x86
When using the default skin called Confluence, move to the "System" option of the main menu and select "System information" in the submenu below. There go to the "Hardware" section and you should see some info about the CPU used in your box. You most likely need Android ARM (would be surprised if cheap chineese boxes used x86 chipsets)
