############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Thu May 21 09:23:03 CDT 2015
Kodi Options:
Arch: x86_64
Kernel: Linux 3.13.0-51-generic #84-Ubuntu SMP Wed Apr 15 12:08:34 UTC 2015
Release: Ubuntu 14.04.1 LTS, Trusty Tahr
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/dustin/core (2015-05-21 09:23:02.080209401 -0500)
[New LWP 2129]
[New LWP 2141]
[New LWP 2131]
[New LWP 2144]
[New LWP 2139]
[New LWP 2145]
[New LWP 2142]
[New LWP 2149]
[New LWP 2146]
[New LWP 2152]
[New LWP 2147]
[New LWP 2148]
[New LWP 2174]
[New LWP 2150]
[New LWP 2151]
[New LWP 2179]
[New LWP 2153]
[New LWP 2132]
[New LWP 2154]
[New LWP 2130]
[New LWP 2155]
[New LWP 2223]
[New LWP 2143]
[New LWP 2171]
[New LWP 2173]
[New LWP 2175]
[New LWP 2176]
[New LWP 2178]
[New LWP 2209]
[New LWP 2217]
[New LWP 2057]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 memset () at ../sysdeps/x86_64/memset.S:80
Thread 31 (Thread 0x7fb98ef357c0 (LWP 2057)):
#0 0x00007fb98ca6a915 in gluProject () from /usr/lib/x86_64-linux-gnu/libGLU.so.1
#1 0x0000000001a402f9 in CRenderSystemGL:
roject(float&, float&, float&) ()
#2 0x000000000085b3f8 in CGraphicContext::generateAABB(CRectGen<float> const&) const ()
#3 0x00000000008a015b in CGUIControl:
rocess(unsigned int, std::vector<CDirtyRegion, std::allocator<CDirtyRegion> >&) ()
#4 0x00000000008ad64b in CGUIControlGroup:
#5 0x00000000008a2636 in CGUIControl:
oProcess(unsigned int, std::vector<CDirtyRegion, std::allocator<CDirtyRegion> >&) ()
#6 0x000000000087cfc4 in CGUIWindow:
#7 0x0000000000881604 in CGUIWindowManager:
rocess(unsigned int) ()
#8 0x0000000000cac36e in CApplication::FrameMove(bool, bool) ()
#9 0x0000000000d3a732 in CXBApplicationEx::Run() ()
#10 0x0000000000d40497 in XBMC_Run ()
#11 0x0000000000756f65 in main ()
Thread 30 (Thread 0x7fb92d7fa700 (LWP 2217)):
#0 0x00007fb986f1d823 in select () at ../sysdeps/unix/syscall-template.S:81
#1 0x0000000000dbcd7d in NPT_BsdSocketFd::WaitForCondition(bool, bool, bool, int) ()
#2 0x0000000000dbd375 in NPT_BsdSocketInputStream::Read(void*, unsigned int, unsigned int*) ()
#3 0x0000000000dd708b in NPT_BufferedInputStream::FillBuffer() ()
#4 0x0000000000dd6daa in NPT_BufferedInputStream::ReadLine(char*, unsigned int, unsigned int*, bool) ()
#5 0x0000000000dd7267 in NPT_BufferedInputStream::ReadLine(NPT_String&, unsigned int, bool) ()
#6 0x0000000000da682c in NPT_HttpRequest:
arse(NPT_BufferedInputStream&, NPT_SocketAddress const*, NPT_HttpRequest*&) ()
#7 0x0000000001a584b5 in PLT_HttpServerSocketTask::Read(NPT_Reference<NPT_BufferedInputStream>&, NPT_HttpRequest*&, NPT_HttpRequestContext*) ()
#8 0x0000000001a5811c in PLT_HttpServerSocketTask:
oRun() ()
#9 0x0000000000dd316a in PLT_ThreadTask::Run() ()
#10 0x0000000000dc04df in NPT_PosixThread::EntryPoint(void*) ()
#11 0x00007fb98d12e182 in start_thread (arg=0x7fb92d7fa700) at pthread_create.c:312
#12 0x00007fb986f25efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 29 (Thread 0x7fb92f7fe700 (LWP 2209)):
oRun() ()
#11 0x00007fb98d12e182 in start_thread (arg=0x7fb92f7fe700) at pthread_create.c:312
Thread 28 (Thread 0x7fb91bff7700 (LWP 2178)):
#2 0x0000000000dbe804 in NPT_BsdTcpClientSocket::WaitForConnection(int) ()
#3 0x0000000000dbe755 in NPT_BsdTcpClientSocket::Connect(NPT_SocketAddress const&, int) ()
#4 0x0000000000db9272 in NPT_HttpTlsConnector::Connect(NPT_HttpUrl const&, NPT_HttpClient&, NPT_HttpProxyAddress const*, bool, NPT_HttpClient::Connection*&) ()
#5 0x0000000000daf028 in NPT_HttpClient::SendRequestOnce(NPT_HttpRequest&, NPT_HttpResponse*&, NPT_HttpRequestContext*) ()
#6 0x0000000000db0451 in NPT_HttpClient::SendRequest(NPT_HttpRequest&, NPT_HttpResponse*&, NPT_HttpRequestContext*) ()
#7 0x0000000000de4f32 in PLT_HttpClientSocketTask:
oRun() ()
#8 0x0000000000dd316a in PLT_ThreadTask::Run() ()
#9 0x0000000000dc04df in NPT_PosixThread::EntryPoint(void*) ()
#10 0x00007fb98d12e182 in start_thread (arg=0x7fb91bff7700) at pthread_create.c:312
#11 0x00007fb986f25efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 27 (Thread 0x7fb91cff9700 (LWP 2176)):
oRun() ()
#10 0x00007fb98d12e182 in start_thread (arg=0x7fb91cff9700) at pthread_create.c:312
Thread 26 (Thread 0x7fb91d7fa700 (LWP 2175)):
#0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_timedwait.S:238
#1 0x0000000000dc02ec in NPT_PosixSharedVariable::WaitUntilEquals(int, int) ()
#2 0x0000000000da9930 in NPT_HttpConnectionManager::Run() ()
#3 0x0000000000dc04df in NPT_PosixThread::EntryPoint(void*) ()
#4 0x00007fb98d12e182 in start_thread (arg=0x7fb91d7fa700) at pthread_create.c:312
#5 0x00007fb986f25efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 25 (Thread 0x7fb91dffb700 (LWP 2173)):
oRun() ()
#10 0x00007fb98d12e182 in start_thread (arg=0x7fb91dffb700) at pthread_create.c:312
Thread 24 (Thread 0x7fb91e7fc700 (LWP 2171)):
oRun() ()
#11 0x00007fb98d12e182 in start_thread (arg=0x7fb91e7fc700) at pthread_create.c:312
Thread 23 (Thread 0x7fb959428700 (LWP 2143)):
#1 0x0000000000b4ed31 in XFILE::CCircularCache::WaitForData(unsigned int, unsigned int) ()
#2 0x0000000000aa89bd in XFILE::CFileCache::Read(void*, unsigned long) ()
#3 0x0000000000aa461c in XFILE::CFile::Read(void*, unsigned long) ()
#4 0x0000000000aa62d0 in XFILE::CFile::LoadFile(CURL const&, XUTILS::auto_buffer&) ()
#5 0x0000000000aa635c in XFILE::CFile::LoadFile(std:
tring const&, XUTILS::auto_buffer&) ()
#6 0x0000000000f63c33 in CXBMCTinyXML::LoadFile(std:
tring const&, TiXmlEncoding) ()
#7 0x000000000099fe92 in ADDON::CRepository:
arse(ADDON::CRepository:
irInfo const&, std::vector<boost:
hared_ptr<ADDON::IAddon>, std::allocator<boost:
hared_ptr<ADDON::IAddon> > >&) ()
#8 0x00000000009a18b9 in ADDON::CRepositoryUpdateJob::GrabAddons(boost:
hared_ptr<ADDON::CRepository> const&, std::vector<boost:
#9 0x00000000009a2028 in ADDON::CRepositoryUpdateJob:
oWork() ()
#10 0x0000000000ee4d49 in CJobWorker:
rocess() ()
#11 0x0000000001a957d8 in CThread::Action() ()
#12 0x0000000001a95e99 in CThread:
taticThread(void*) ()
#13 0x00007fb98d12e182 in start_thread (arg=0x7fb959428700) at pthread_create.c:312
#14 0x00007fb986f25efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 22 (Thread 0x7fb92ffff700 (LWP 2223)):
#1 0x0000000000aa94a0 in XFILE::CFileCache:
rocess() ()
#2 0x0000000001a957d8 in CThread::Action() ()
#3 0x0000000001a95e99 in CThread:
#4 0x00007fb98d12e182 in start_thread (arg=0x7fb92ffff700) at pthread_create.c:312
Thread 21 (Thread 0x7fb9427fc700 (LWP 2155)):
#1 0x0000000000e7a274 in JSONRPC::CTCPServer:
rocess() ()
#4 0x00007fb98d12e182 in start_thread (arg=0x7fb9427fc700) at pthread_create.c:312
Thread 20 (Thread 0x7fb96bfff700 (LWP 2130)):
#1 0x00000000009ef194 in ActiveAE::CActiveAESink:
rocess() ()
#4 0x00007fb98d12e182 in start_thread (arg=0x7fb96bfff700) at pthread_create.c:312
Thread 19 (Thread 0x7fb942ffd700 (LWP 2154)):
#1 0x0000000000e77d92 in SOCKETS::CSocketListener::Listen(int) ()
#2 0x0000000000e6a166 in EVENTSERVER::CEventServer::Run() ()
#3 0x0000000000e6a638 in EVENTSERVER::CEventServer:
rocess() ()
#4 0x0000000001a957d8 in CThread::Action() ()
#5 0x0000000001a95e99 in CThread:
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb942ffd700) at pthread_create.c:312
#7 0x00007fb986f25efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 18 (Thread 0x7fb96ad79700 (LWP 2132)):
#0 0x00007fb986f18bad in poll () at ../sysdeps/unix/syscall-template.S:81
#1 0x000000000197dee2 in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#2 0x000000000197dfa0 in PERIPHERALS::CPeripheralBusUSB:
rocess() ()
#3 0x0000000001a957d8 in CThread::Action() ()
#4 0x0000000001a95e99 in CThread:
#5 0x00007fb98d12e182 in start_thread (arg=0x7fb96ad79700) at pthread_create.c:312
#6 0x00007fb986f25efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 17 (Thread 0x7fb9437fe700 (LWP 2153)):
#2 0x0000000000dd1535 in PLT_ThreadTask::IsAborting(int) ()
#3 0x0000000001a5c9bd in PLT_SsdpDeviceAnnounceTask:
oRun() ()
#4 0x0000000000dd316a in PLT_ThreadTask::Run() ()
#5 0x0000000000dc04df in NPT_PosixThread::EntryPoint(void*) ()
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb9437fe700) at pthread_create.c:312
Thread 16 (Thread 0x7fb91b7f6700 (LWP 2179)):
oRun() ()
#10 0x00007fb98d12e182 in start_thread (arg=0x7fb91b7f6700) at pthread_create.c:312
Thread 15 (Thread 0x7fb94cff9700 (LWP 2151)):
oRun() ()
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb94cff9700) at pthread_create.c:312
Thread 14 (Thread 0x7fb94d7fa700 (LWP 2150)):
#2 0x0000000000dbeabd in NPT_BsdTcpServerSocket::WaitForNewClient(NPT_Socket*&, int, unsigned int) ()
#3 0x0000000001a57c8b in PLT_HttpListenTask:
oRun() ()
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb94d7fa700) at pthread_create.c:312
Thread 13 (Thread 0x7fb91f7fe700 (LWP 2174)):
oRun() ()
#11 0x00007fb98d12e182 in start_thread (arg=0x7fb91f7fe700) at pthread_create.c:312
Thread 12 (Thread 0x7fb94e7fc700 (LWP 2148)):
#3 0x0000000001a4f4c6 in PLT_CtrlPointHouseKeepingTask:
oRun() ()
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb94e7fc700) at pthread_create.c:312
Thread 11 (Thread 0x7fb94effd700 (LWP 2147)):
oRun() ()
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb94effd700) at pthread_create.c:312
Thread 10 (Thread 0x7fb943fff700 (LWP 2152)):
oRun() ()
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb943fff700) at pthread_create.c:312
Thread 9 (Thread 0x7fb94f7fe700 (LWP 2146)):
#2 0x0000000000dbd6c5 in NPT_BsdUdpSocket::Receive(NPT_DataBuffer&, NPT_SocketAddress*) ()
#3 0x0000000001a75129 in PLT_InputDatagramStream::Read(void*, unsigned int, unsigned int*) ()
#4 0x0000000000dd708b in NPT_BufferedInputStream::FillBuffer() ()
#5 0x0000000000dd6daa in NPT_BufferedInputStream::ReadLine(char*, unsigned int, unsigned int*, bool) ()
#6 0x0000000000dd7267 in NPT_BufferedInputStream::ReadLine(NPT_String&, unsigned int, bool) ()
#7 0x0000000000da682c in NPT_HttpRequest:
#8 0x0000000001a584b5 in PLT_HttpServerSocketTask::Read(NPT_Reference<NPT_BufferedInputStream>&, NPT_HttpRequest*&, NPT_HttpRequestContext*) ()
#9 0x0000000001a5811c in PLT_HttpServerSocketTask:
oRun() ()
#10 0x0000000000dd316a in PLT_ThreadTask::Run() ()
#11 0x0000000000dc04df in NPT_PosixThread::EntryPoint(void*) ()
#12 0x00007fb98d12e182 in start_thread (arg=0x7fb94f7fe700) at pthread_create.c:312
#13 0x00007fb986f25efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 8 (Thread 0x7fb94dffb700 (LWP 2149)):
#7 0x0000000000da6f79 in NPT_HttpResponse:
arse(NPT_BufferedInputStream&, NPT_HttpResponse*&) ()
#8 0x0000000000dad22b in NPT_HttpClient::ReadResponse(NPT_Reference<NPT_InputStream>&, bool, bool, NPT_HttpResponse*&, NPT_Reference<NPT_HttpClient::Connection>*) ()
#9 0x0000000001a5a14f in PLT_SsdpSearchTask:
oRun() ()
#12 0x00007fb98d12e182 in start_thread (arg=0x7fb94dffb700) at pthread_create.c:312
Thread 7 (Thread 0x7fb959c29700 (LWP 2142)):
#1 0x00007fb98e50e99c in ?? () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#2 0x00007fb98e50e51b in avahi_simple_poll_run () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#3 0x00007fb98e50e6f8 in avahi_simple_poll_iterate () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#4 0x00007fb98e50e92d in avahi_simple_poll_loop () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#5 0x00007fb98e50e9f4 in ?? () from /usr/lib/x86_64-linux-gnu/libavahi-common.so.3
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb959c29700) at pthread_create.c:312
Thread 6 (Thread 0x7fb94ffff700 (LWP 2145)):
#1 0x00007fb98e2fb178 in ?? () from /usr/lib/x86_64-linux-gnu/libmicrohttpd.so.10
#2 0x00007fb98e2fb352 in ?? () from /usr/lib/x86_64-linux-gnu/libmicrohttpd.so.10
#3 0x00007fb98d12e182 in start_thread (arg=0x7fb94ffff700) at pthread_create.c:312
#4 0x00007fb986f25efd in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
Thread 5 (Thread 0x7fb970077700 (LWP 2139)):
#1 0x0000000001a95d3b in CThread::Sleep(unsigned int) ()
#2 0x0000000000c7852c in MEDIA_DETECT::CDetectDVDMedia:
rocess() ()
#5 0x00007fb98d12e182 in start_thread (arg=0x7fb970077700) at pthread_create.c:312
Thread 4 (Thread 0x7fb958c27700 (LWP 2144)):
#3 0x00007fb98d12e182 in start_thread (arg=0x7fb958c27700) at pthread_create.c:312
Thread 3 (Thread 0x7fb96b57a700 (LWP 2131)):
#1 0x0000000001980d9c in PERIPHERALS::CPeripheralBus:
rocess() ()
#4 0x00007fb98d12e182 in start_thread (arg=0x7fb96b57a700) at pthread_create.c:312
Thread 2 (Thread 0x7fb95a42a700 (LWP 2141)):
#1 0x0000000000ee4a62 in CJobManager::GetNextJob(CJobWorker const*) ()
#2 0x0000000000ee4d6a in CJobWorker:
rocess() ()
#5 0x00007fb98d12e182 in start_thread (arg=0x7fb95a42a700) at pthread_create.c:312
Thread 1 (Thread 0x7fb970ebb700 (LWP 2129)):
#1 0x00000000009e7a65 in ActiveAE::CActiveAE::RunStages() ()
#2 0x00000000009e8df9 in ActiveAE::CActiveAE::StateMachine(int, Actor:
rotocol*, Actor::Message*) ()
#3 0x00000000009e92da in ActiveAE::CActiveAE:
rocess() ()
#6 0x00007fb98d12e182 in start_thread (arg=0x7fb970ebb700) at pthread_create.c:312
############# END STACK TRACE ###############
################# LOG FILE ##################
09:22:22 T:140434943989696 NOTICE: special://profile/ is mapped to: special://masterprofile/
09:22:22 T:140434943989696 NOTICE: -----------------------------------------------------------------------
09:22:22 T:140434943989696 NOTICE: Starting Kodi (14.2 Git:7cc53a9). Platform: Linux x86 64-bit
09:22:22 T:140434943989696 NOTICE: Using Release Kodi x64 build
09:22:22 T:140434943989696 NOTICE: Kodi compiled Mar 27 2015 by GCC 4.8.2 for Linux x86 64-bit version 3.13.11 (199947)
09:22:22 T:140434943989696 NOTICE: Running on Ubuntu 14.04.1 LTS, kernel: Linux x86 64-bit version 3.13.0-51-generic
09:22:22 T:140434943989696 NOTICE: FFmpeg statically linked, version: 2.4.6-xbmc-2.4.6-Helix
09:22:22 T:140434943989696 NOTICE: Host CPU: Intel® Core2 Duo CPU E4500 @ 2.20GHz, 2 cores available
09:22:22 T:140434943989696 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
09:22:22 T:140434943989696 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
09:22:22 T:140434943989696 NOTICE: special://masterprofile/ is mapped to: /home/dustin/.kodi/userdata
09:22:22 T:140434943989696 NOTICE: special://home/ is mapped to: /home/dustin/.kodi
09:22:22 T:140434943989696 NOTICE: special://temp/ is mapped to: /home/dustin/.kodi/temp
09:22:22 T:140434943989696 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
09:22:22 T:140434943989696 NOTICE: Local hostname: XBMCBUNTU
09:22:22 T:140434943989696 NOTICE: Log File is located: /home/dustin/.kodi/temp/kodi.log
09:22:22 T:140434943989696 NOTICE: load settings...
09:22:22 T:140434943989696 ERROR: PulseAudio: Failed to connect context
09:22:22 T:140434943989696 NOTICE: PulseAudio might not be running. Context was not created.
09:22:22 T:140434943989696 NOTICE: Found 1 Lists of Devices
09:22:22 T:140434943989696 NOTICE: Enumerated ALSA devices:
09:22:22 T:140434943989696 NOTICE: Device 1
09:22:22 T:140434943989696 NOTICE: m_deviceName : default
09:22:22 T:140434943989696 NOTICE: m_displayName : Default (HDA NVidia HDMI 0)
09:22:22 T:140434943989696 NOTICE: m_displayNameExtra:
09:22:22 T:140434943989696 NOTICE: m_deviceType : AE_DEVTYPE_PCM
09:22:22 T:140434943989696 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
09:22:22 T:140434943989696 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
09:22:22 T:140434943989696 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
09:22:22 T:140434943989696 NOTICE: Device 2
09:22:22 T:140434943989696 NOTICE: m_deviceName : hdmi:CARD=NVidia,DEV=0
09:22:22 T:140434943989696 NOTICE: m_displayName : HDA NVidia
09:22:22 T:140434943989696 NOTICE: m_displayNameExtra: HDMI
09:22:22 T:140434943989696 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
09:22:22 T:140434943989696 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
09:22:22 T:140434943989696 NOTICE: Device 3
09:22:22 T:140434943989696 NOTICE: m_deviceName : @:CARD=Audigy2,DEV=0
09:22:22 T:140434943989696 NOTICE: m_displayName : SB Audigy 2 [SB0350b] (@:CARD=Audigy2,DEV=0)
09:22:22 T:140434943989696 NOTICE: m_displayNameExtra: ADC Capture/Standard PCM Playback
09:22:22 T:140434943989696 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000
09:22:22 T:140434943989696 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
09:22:22 T:140434943989696 NOTICE: Device 4
09:22:22 T:140434943989696 NOTICE: m_deviceName : rear:CARD=Audigy2,DEV=0
09:22:22 T:140434943989696 NOTICE: m_displayName : SB Audigy 2 [SB0350b] (rear:CARD=Audigy2,DEV=0)
09:22:22 T:140434943989696 NOTICE: m_channels : UNKNOWN1,BL,BR
09:22:22 T:140434943989696 NOTICE: Device 5
09:22:22 T:140434943989696 NOTICE: m_deviceName : center_lfe:CARD=Audigy2,DEV=0
09:22:22 T:140434943989696 NOTICE: m_displayName : SB Audigy 2 [SB0350b] (center_lfe:CARD=Audigy2,DEV=0)
09:22:22 T:140434943989696 NOTICE: m_channels : UNKNOWN1,FC,LFE
09:22:22 T:140434943989696 NOTICE: Device 6
09:22:22 T:140434943989696 NOTICE: m_deviceName : side:CARD=Audigy2,DEV=0
09:22:22 T:140434943989696 NOTICE: m_displayName : SB Audigy 2 [SB0350b] (side:CARD=Audigy2,DEV=0)
09:22:22 T:140434943989696 NOTICE: m_channels : UNKNOWN1,SL,SR
09:22:22 T:140434943989696 NOTICE: Device 7
09:22:22 T:140434943989696 NOTICE: m_deviceName : iec958:CARD=Audigy2,DEV=0
09:22:22 T:140434943989696 NOTICE: m_displayNameExtra: ADC Capture/Standard PCM Playback S/PDIF
09:22:22 T:140434943989696 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
09:22:22 T:140434943989696 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
09:22:22 T:140434943989696 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
09:22:22 T:140434943989696 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
09:22:22 T:140434943989696 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<useddsfanart>true</useddsfanart>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<disableipv6>true</disableipv6>
</network>
</advancedsettings>
09:22:22 T:140434943989696 NOTICE: Default DVD Player: dvdplayer
09:22:22 T:140434943989696 NOTICE: Default Video Player: dvdplayer
09:22:22 T:140434943989696 NOTICE: Default Audio Player: paplayer
09:22:22 T:140434943989696 NOTICE: Disabled debug logging due to GUI setting. Level 0.
09:22:22 T:140434943989696 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
09:22:22 T:140434943989696 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
09:22:22 T:140434943989696 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
09:22:22 T:140434943989696 NOTICE: Loaded playercorefactory configuration
09:22:22 T:140434943989696 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
09:22:22 T:140434943989696 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
09:22:22 T:140434440173312 NOTICE: Thread ActiveAE start, auto delete: false
09:22:22 T:140434357614336 NOTICE: Thread AESink start, auto delete: false
09:22:24 T:140434440173312 ERROR: CActiveAEResampleFFMPEG::Init - init resampler failed
09:22:24 T:140434943989696 NOTICE: Running database version Addons16
09:22:24 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:24 T:140434943989696 NOTICE: ADDONS: Using repository repository.xbmc.org
09:22:24 T:140434346583808 NOTICE: Thread PeripBusCEC start, auto delete: false
09:22:24 T:140434338191104 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
09:22:24 T:140434943989696 NOTICE: Setup SDL
09:22:25 T:140434943989696 NOTICE: Checking resolution 16
09:22:25 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:25 T:140434943989696 NOTICE: Using visual 0x28
09:22:25 T:140434943989696 NOTICE: GL_VENDOR = NVIDIA Corporation
09:22:25 T:140434943989696 NOTICE: GL_RENDERER = GeForce 210/PCIe/SSE2
09:22:25 T:140434943989696 NOTICE: GL_VERSION = 3.3.0 NVIDIA 331.113
09:22:25 T:140434943989696 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
09:22:25 T:140434943989696 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 1048576
09:22:25 T:140434943989696 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 1048576
09:22:25 T:140434943989696 NOTICE: GL_EXTENSIONS = GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
09:22:25 T:140434943989696 NOTICE: Running database version Addons16
09:22:25 T:140434943989696 NOTICE: Running database version ViewModes6
09:22:25 T:140434943989696 NOTICE: Running database version Textures13
09:22:25 T:140434943989696 NOTICE: Running database version MyMusic48
09:22:25 T:140434943989696 NOTICE: Running database version MyVideos90
09:22:25 T:140434943989696 NOTICE: Running database version TV26
09:22:25 T:140434943989696 NOTICE: Running database version Epg8
09:22:25 T:140434943989696 NOTICE: start dvd mediatype detection
09:22:25 T:140434425214720 NOTICE: Thread DetectDVDMedia start, auto delete: false
09:22:26 T:140434943989696 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
09:22:26 T:140434943989696 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
09:22:26 T:140434943989696 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
09:22:26 T:140434943989696 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
09:22:26 T:140434440173312 ERROR: CActiveAEResampleFFMPEG::Init - init resampler failed
09:22:26 T:140434440173312 ERROR: CActiveAEResampleFFMPEG::Resample - resample failed
09:22:26 T:140434089178880 NOTICE: Thread LanguageInvoker start, auto delete: false
09:22:26 T:140434943989696 NOTICE: initialize done
09:22:26 T:140434943989696 NOTICE: Running the application...
09:22:26 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:26 T:140434089178880 NOTICE: -->Python Interpreter Initialized<--
09:22:26 T:140434059994880 NOTICE: Thread JobWorker start, auto delete: true
09:22:26 T:140434943989696 NOTICE: starting zeroconf publishing
09:22:26 T:140434943989696 NOTICE: Webserver: Starting...
09:22:26 T:140434943989696 NOTICE: WebServer: Started the webserver
09:22:26 T:140434943989696 NOTICE: starting upnp controller
09:22:26 T:140434943989696 NOTICE: starting upnp server
09:22:26 T:140434043209472 NOTICE: Thread JobWorker start, auto delete: true
09:22:26 T:140434943989696 NOTICE: starting upnp renderer
09:22:26 T:140434943989696 NOTICE: ES: Starting event server
09:22:26 T:140433669740288 NOTICE: Thread EventServer start, auto delete: false
09:22:26 T:140433669740288 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
09:22:26 T:140433669740288 NOTICE: UDP: Listening on port 9777
09:22:26 T:140433661347584 NOTICE: Thread TCPServer start, auto delete: false
09:22:26 T:140434424825600 NOTICE: Thread RSSReader start, auto delete: false
09:22:28 T:140433350981376 ERROR: Previous line repeats 4 times.
09:22:28 T:140433350981376 NOTICE: Thread FileCache start, auto delete: false
09:22:28 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:28 T:140433065760512 NOTICE: Thread FileCache start, auto delete: false
09:22:29 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:37 T:140433350981376 ERROR: Previous line repeats 14 times.
09:22:37 T:140433350981376 NOTICE: Thread FileCache start, auto delete: false
09:22:37 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:40 T:140434943989696 ERROR: Previous line repeats 4 times.
09:22:40 T:140434943989696 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
09:22:40 T:140434943989696 NOTICE: Enabled debug logging due to GUI setting. Level 2.
09:22:40 T:140434943989696 DEBUG: ------ Window Init () ------
09:22:40 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:41 T:140434943989696 ERROR: Previous line repeats 1 times.
09:22:41 T:140434943989696 INFO: Python, unloading python shared library because no scripts are running anymore
09:22:41 T:140434943989696 DEBUG: UnloadExtensionLibs, clearing python extension libraries
09:22:41 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:43 T:140434943989696 ERROR: Previous line repeats 3 times.
09:22:43 T:140434943989696 DEBUG: ------ Window Init (Pointer.xml) ------
09:22:43 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:47 T:140434943989696 ERROR: Previous line repeats 9 times.
09:22:47 T:140434943989696 DEBUG: ------ Window Deinit (Pointer.xml) ------
09:22:47 T:140434943989696 DEBUG: ProcessMouse: trying mouse action leftclick
09:22:47 T:140434943989696 DEBUG: CGUIWindowManager:
reviousWindow: Deactivate
09:22:47 T:140434943989696 DEBUG: ------ Window Init (Pointer.xml) ------
09:22:47 T:140434943989696 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
reviousWindow: Activate new
09:22:47 T:140434943989696 DEBUG: ------ Window Init (Settings.xml) ------
09:22:48 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:48 T:140434943989696 DEBUG: ------ Window Init (Pointer.xml) ------
09:22:49 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:50 T:140434943989696 DEBUG: ------ Window Deinit (Pointer.xml) ------
09:22:50 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:50 T:140434943989696 DEBUG: ProcessMouse: trying mouse action leftclick
09:22:50 T:140434943989696 DEBUG: CGUIWindowManager:
09:22:50 T:140434943989696 DEBUG: ------ Window Init (Pointer.xml) ------
09:22:50 T:140434943989696 DEBUG: ------ Window Deinit (Settings.xml) ------
09:22:50 T:140434943989696 DEBUG: ------ Window Init (Home.xml) ------
09:22:51 T:140434357614336 ERROR: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
09:22:53 T:140434943989696 ERROR: Previous line repeats 2 times.
09:22:53 T:140434943989696 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0
09:22:53 T:140434943989696 DEBUG: OnKey: left (0xf082) pressed, action is Left
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
