I have kodi with the aeon flux skin. I have my movies sorted into movies categories through a video node editor.
But some of my movies appear in multiple movie categories, is there a way to edit the category for each movie so It does not appear in multiple movie categories?
/Karl
Hi
not sure, but it looks like a media_filename.nfo should do the trick.
read the wiki
http://kodi.wiki/view/NFO_files/Movies#V...ML_and_URL
I'd would like some movies to be sorted into a SPECIFIC order in a movie set.
for the file SuperMovie2 (2017).mkv I created this file SuperMovie2(2017).nfo
<movie>
<title>Super Movie : the return of the come back</title>
<set>Super Movie Pack</set>
<sorttitle>Movie2</sorttitle>
</movie>
https://www.themoviedb.org/movie/012345
using the example in the wiki, adding 1 or multiple genre flags should do what you want
here an example of what I understand you want
<movie>
<genre>AnimAction</genre>
</movie>
rescan your sources and voila
If you have a lot of files... you'll have to create a lot of file...
