Full Version: plays recordings without video
It has been a few days since I setup Kodi with NextPVR addon using two HDHomerun Prime's with a total of six tuners. Took the time to add in all the icons for the few hundred channels. It has been working great except for one problem in recordings. I have recorded a total of twelve episodes out of four series to the NAS. In one series of Castle on TNT, two out of eight episodes play with audio only. The bottom tool bar showed as if they are played as music. If I clicked the text icon, the word LYRIC instead of SUBTITLE was shown. Except these two, the rest played with full video and full audio. This happened in all the clients.
However, if I play these two defective episodes directly from NextPVR, they will play perfectly.
Below is the cut and paste segment from the log file I believe is relevant to the problem from Kodi. Is there any suggestion I can do on my part as remedy?
10:58:29 T:11784 NOTICE: Previous line repeats 29 times.
10:58:29 T:11784 ERROR: PVR - ADDON::CAddonCallbacksPVR:TongueVRTransferTimerEntry - cannot find channel 8101 on client 1887
10:58:29 T:10668 ERROR: Previous line repeats 4 times.
10:58:29 T:10668 NOTICE: Thread FileCache start, auto delete: false
11:00:30 T:4144 NOTICE: Previous line repeats 38 times.
11:00:30 T:4144 NOTICE: Thread JobWorker start, auto delete: true
11:00:30 T:12144 NOTICE: Thread BackgroundLoader start, auto delete: false
11:00:30 T:11092 NOTICE: Thread JobWorker start, auto delete: true
11:00:30 T:11092 NOTICE: Previous line repeats 2 times.
11:00:30 T:11092 ERROR: dll_fgets emulated function failed
11:00:35 T:5076 ERROR: Previous line repeats 2 times.
11:00:35 T:5076 NOTICE: Thread FileCache start, auto delete: false
11:00:35 T:11092 NOTICE: Previous line repeats 2 times.
11:00:35 T:11092 ERROR: dll_fgets emulated function failed
11:00:37 T:11100 NOTICE: DVDPlayer: Opening: http://192.168.11.102:8866/live?recording=907
11:00:37 T:11100 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
11:00:37 T:5880 NOTICE: Thread DVDPlayer start, auto delete: false
11:00:37 T:5880 NOTICE: Creating InputStream
11:00:37 T:5880 NOTICE: Creating Demuxer
11:00:37 T:5676 NOTICE: Thread FileCache start, auto delete: false
11:00:37 T:5880 NOTICE: Opening stream: 1 source: 256
11:00:37 T:5880 NOTICE: Finding audio codec for: 86019
11:00:37 T:5880 NOTICE: Creating audio thread
11:00:37 T:5880 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
11:00:37 T:5236 NOTICE: Thread DVDPlayerAudio start, auto delete: false
11:00:37 T:5236 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
11:00:37 T:5236 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
11:00:37 T:5236 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 3 packets of duration 32
11:00:37 T:5236 NOTICE: Previous line repeats 2 times.
11:00:37 T:5236 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 32
11:00:38 T:11092 NOTICE: Previous line repeats 1 times.
11:00:38 T:11092 ERROR: dll_fgets emulated function failed
If you're getting audio, then the NextPVR addon is definitely passing the bitstream to Kodi. It sounds like Kodi itself must not like something about the stream from the HDHR Prime. Unfortunately I'm not familiar enough with the internals of Kodi to tell you what exactly.
