Full Version: Problem with TheMovieDB scraper
Running 14.2, and having a problem scraping any movie with TheMovieDB scraper. The Universal Movie Scraper is working fine, as long as I don't use TMDB for Movie Info.
Debug log: http://xbmclogs.com/pihad8o9h
Scraper seems to find movie okay, but loads it into the database with no name, no description, no artwork, no actors. Only thing that loads is the year.
Tried on a different install on a different computer, and it works okay.
All my movies scrape okay using th Univeral Movie Scraper, as long as I don't use The Movie DB. Then I get the same issue. IMDB works fine.
Any ideas?
Thanks in advance.
Never mind. Solved the issue. Somehow the last auto update corrupted the plugin files. Copied them over from the other PC and all is well.
