2015-05-21, 02:49
Hi All,
I Currently Have the following setup
MachineName = mediabox, 192.168.1.30
Ubuntu 14.04 Trusty
ZFS, Pool = Ocean (Shared to all via SAMBA)
Kodi
LAMP
PHPmyADMIN
I can get the HTPC scraping and building the database all okay and work fine when no AdvancedSetting.xml in place. When I copy in the file shown below, I get nothing.
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.30</host>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
</advancedsettings>
I am also unable to add sources and start a new scrape (so a to build the SQL database).
I have followed this guide http://kodi.wiki/view/MySQL to no avail.
I have been working on this for a number of weeks now and I am having no luck. Any help would be greatly appreciated
Below is shown kodi.log
17:38:40 T:140135947007936 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:38:40 T:140135947007936 NOTICE: -----------------------------------------------------------------------
17:38:40 T:140135947007936 NOTICE: Starting Kodi (14.2 Git:7cc53a9). Platform: Linux x86 64-bit
17:38:40 T:140135947007936 NOTICE: Using Release Kodi x64 build
17:38:40 T:140135947007936 NOTICE: Kodi compiled Mar 27 2015 by GCC 4.8.2 for Linux x86 64-bit version 3.13.11 (199947)
17:38:40 T:140135947007936 NOTICE: Running on Ubuntu 14.04 LTS, kernel: Linux x86 64-bit version 3.13.0-24-generic
17:38:40 T:140135947007936 NOTICE: FFmpeg statically linked, version: 2.4.6-xbmc-2.4.6-Helix
17:38:40 T:140135947007936 NOTICE: Host CPU: AMD Athlon 7750 Dual-Core Processor, 2 cores available
17:38:40 T:140135947007936 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
17:38:40 T:140135947007936 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
17:38:40 T:140135947007936 NOTICE: special://masterprofile/ is mapped to: /home/darryl/.kodi/userdata
17:38:40 T:140135947007936 NOTICE: special://home/ is mapped to: /home/darryl/.kodi
17:38:40 T:140135947007936 NOTICE: special://temp/ is mapped to: /home/darryl/.kodi/temp
17:38:40 T:140135947007936 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
17:38:40 T:140135947007936 NOTICE: Local hostname: MediaBox
17:38:40 T:140135947007936 NOTICE: Log File is located: /home/darryl/.kodi/temp/kodi.log
17:38:40 T:140135947007936 NOTICE: load settings...
17:38:40 T:140135947007936 NOTICE: Found 1 Lists of Devices
17:38:40 T:140135947007936 NOTICE: Enumerated PULSE devices:
17:38:40 T:140135947007936 NOTICE: Device 1
17:38:40 T:140135947007936 NOTICE: m_deviceName : Default
17:38:40 T:140135947007936 NOTICE: m_displayName : Default
17:38:40 T:140135947007936 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
17:38:40 T:140135947007936 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:38:40 T:140135947007936 NOTICE: m_channels : FL,FR
17:38:40 T:140135947007936 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
17:38:40 T:140135947007936 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
17:38:40 T:140135947007936 NOTICE: Device 2
17:38:40 T:140135947007936 NOTICE: m_deviceName : alsa_output.pci-0000_00_07.0.analog-stereo
17:38:40 T:140135947007936 NOTICE: m_displayName : Built-in Audio Analogue Stereo
17:38:40 T:140135947007936 NOTICE: m_displayNameExtra: Analogue Output (PULSEAUDIO)
17:38:40 T:140135947007936 NOTICE: Device 3
17:38:40 T:140135947007936 NOTICE: m_deviceName : alsa_output.pci-0000_02_00.1.hdmi-stereo
17:38:40 T:140135947007936 NOTICE: m_displayName : GF119 HDMI Audio Controller Digital Stereo (HDMI)
17:38:40 T:140135947007936 NOTICE: m_displayNameExtra: HDMI / DisplayPort (PULSEAUDIO)
17:38:40 T:140135947007936 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
17:38:40 T:140135947007936 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
17:38:40 T:140135947007936 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</musicdatabase>
<videolibrary>
</videolibrary>
</advancedsettings>
17:38:40 T:140135947007936 WARNING: VIDEO database configuration is experimental.
17:38:40 T:140135947007936 NOTICE: Default DVD Player: dvdplayer
17:38:40 T:140135947007936 NOTICE: Default Video Player: dvdplayer
17:38:40 T:140135947007936 NOTICE: Default Audio Player: paplayer
17:38:40 T:140135947007936 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:38:40 T:140135947007936 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:38:40 T:140135947007936 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:38:40 T:140135947007936 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:38:40 T:140135947007936 NOTICE: Loaded playercorefactory configuration
17:38:40 T:140135947007936 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:38:40 T:140135947007936 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:38:40 T:140135471863552 NOTICE: Thread ActiveAE start, auto delete: false
17:38:40 T:140135531759360 NOTICE: Thread AESink start, auto delete: false
17:38:40 T:140135531759360 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
17:38:40 T:140135947007936 NOTICE: Running database version Addons16
17:38:41 T:140135947007936 NOTICE: ADDONS: Using repository repository.xbmc.org
17:38:41 T:140135505757952 NOTICE: Thread PeripBusCEC start, auto delete: false
17:38:41 T:140135497365248 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
17:38:41 T:140135947007936 NOTICE: Setup SDL
17:38:41 T:140135947007936 NOTICE: Checking resolution 16
17:38:41 T:140135947007936 NOTICE: Using visual 0x170
17:38:41 T:140135947007936 NOTICE: GL_VENDOR = nouveau
17:38:41 T:140135947007936 NOTICE: GL_RENDERER = Gallium 0.4 on NVD9
17:38:41 T:140135947007936 NOTICE: GL_VERSION = 3.0 Mesa 10.1.0
17:38:41 T:140135947007936 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
17:38:41 T:140135947007936 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_compression_latc GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_multisample GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_NV_vdpau_interop GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_base_instance GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge
17:38:41 T:140135947007936 NOTICE: Running database version Addons16
17:38:41 T:140135947007936 NOTICE: Running database version ViewModes6
17:38:41 T:140135947007936 NOTICE: Running database version Textures13
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic48 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic47 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic46 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic45 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic44 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic43 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic42 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic41 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic40 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic39 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic38 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic37 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic36 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic35 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic34 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic33 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic32 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic31 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic30 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic29 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic28 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic27 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic26 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic25 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic24 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic23 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic22 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic21 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic20 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic19 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyMusic18 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to create new database
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos90 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos89 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos88 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos87 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos86 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos85 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos84 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos83 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos82 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos81 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos80 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos79 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos78 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos77 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos76 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos75 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos74 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos73 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos72 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos71 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos70 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos69 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos68 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos67 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos66 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos65 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos64 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos63 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos62 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos61 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 ERROR: Unable to open database: MyVideos60 [2003](Can't connect to MySQL server on '192.168.1.30' (111))
17:38:41 T:140135947007936 NOTICE: Running database version TV26
17:38:41 T:140135947007936 NOTICE: Running database version Epg8
17:38:41 T:140135947007936 NOTICE: start dvd mediatype detection
17:38:41 T:140135945508608 NOTICE: Thread DetectDVDMedia start, auto delete: false
17:38:41 T:140135947007936 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
17:38:41 T:140135947007936 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
17:38:41 T:140135947007936 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
17:38:41 T:140135947007936 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:38:41 T:140135947007936 NOTICE: initialize done
17:38:41 T:140135947007936 NOTICE: Running the application...
17:38:41 T:140135052080896 NOTICE: Thread LanguageInvoker start, auto delete: false
17:38:41 T:140135052080896 NOTICE: -->Python Interpreter Initialized<--
17:38:41 T:140135033816832 NOTICE: Thread JobWorker start, auto delete: true
17:38:41 T:140135947007936 NOTICE: starting zeroconf publishing
17:38:41 T:140135947007936 NOTICE: ES: Starting event server
17:38:41 T:140135000246016 NOTICE: Thread TCPServer start, auto delete: false
17:38:41 T:140135008638720 NOTICE: Thread EventServer start, auto delete: false
17:38:41 T:140135008638720 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
17:38:41 T:140135008638720 NOTICE: UDP: Listening on port 9777
17:38:41 T:140135017031424 NOTICE: Thread JobWorker start, auto delete: true
17:38:41 T:140135945438976 NOTICE: Thread RSSReader start, auto delete: false
17:38:47 T:140135052080896 NOTICE: Thread BackgroundLoader start, auto delete: false
17:38:49 T:140135947007936 ERROR: GetResumeItemOffset - Cannot open VideoDatabase
17:39:03 T:140135052080896 NOTICE: Thread VideoInfoScanner start, auto delete: false
17:39:03 T:140135052080896 NOTICE: VideoInfoScanner: Starting scan ..
17:39:04 T:140135052080896 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
17:39:04 T:140135052080896 NOTICE: Thread BackgroundLoader start, auto delete: false
17:40:20 T:140135531759360 NOTICE: Previous line repeats 1 times.
17:40:20 T:140135531759360 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
17:40:20 T:140135017031424 NOTICE: Thread JobWorker start, auto delete: true
17:40:38 T:140135947007936 NOTICE: Samba is idle. Closing the remaining connections
17:42:07 T:140135947007936 ERROR: Control 18 in window 10129 has been asked to focus, but it can't
17:42:28 T:140135523366656 NOTICE: Thread JobWorker start, auto delete: true
17:42:54 T:140135531759360 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
17:43:04 T:140135523366656 NOTICE: Thread JobWorker start, auto delete: true
17:44:32 T:140135523366656 NOTICE: Previous line repeats 1 times.
17:44:32 T:140135523366656 WARNING: SMBFile::OpenForWrite() called with overwriting enabled! - smb://darryl:[email protected]/Ocean/MultiMedia/kodi.log
Ubuntu 14.04 Trusty
Kodi
LAMP
PHPmyADMIN
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</musicdatabase>
<videolibrary>
</videolibrary>
</advancedsettings>
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>kodi</pass>
</musicdatabase>
<videolibrary>
</videolibrary>
</advancedsettings>
