is there a way to make Kodi able to import files from other apps. I have Kodi on a non jail broken device and signed with a developer certificate.
It wouldn't be hard to implement all that would need to be done before compilation is edit info.plist to allow file import which would go into the inbox folder of the app.
Since you are an ios developer i would welcome any contribution in that regard.
I would be able to make the change but I can't compile it.
Can you post what file needs to be changed? I can fire off a test build using our build system.
The info.plist file it needs to be changed to allow the app as an open in option for all files.
What exactly did you add to the plist file? I tried a few things and couldn't get it to work.
You have to add to the CFBundleDocumentTypes.
(2015-07-15, 16:02)scj643 Wrote: [ -> ]You have to add to the CFBundleDocumentTypes.
I did that. What exactly did you do? Why is it so hard for you to answer this? At this point I can only assume that you haven't done any of this and that you are just wasting my time.
what ned said - get your ass up or keep it for yourself
