2015-05-21, 21:49
hi guys,
Relatively new to this so apologies if some of this sounds non technical, went out today and bought my first amazon fire Tv stick, i've plugged it in and set it all up, downloaded the following:
Adbfire - 1.25 (looks different from the versions in videos i've watched as theres not simply a box for IP address it breaks down into individual device profiles, changed one of the names to "Fire Stick" and entered IP and saved, didn't change anything else)
kodi-14.2-Helix-armeabi-v7a.apk (downloaded the current stable release?)
my problem is that when i try to connect it says its connected, yet when i try to install Kodi it shows it installing then when it gets to the end it just restarts over and over in a loop ........ i've seen another thread that details this as a common problem, i followed the advice in there and restarted my mac, closed every program disconnected and reconnected from the fire stick via the buttons in adbfire and still nothing. every time i try and "pull" from the "sdcard" option in the drop down i get a dialogue box saying "Destination Path Missing"
i've also swapped my name in the pic for ***NAME*** just incase anyone wonders if thats my file path
the way i have my device profile set up
the way my adbfire looks
Im using a Macbook Pro with OSX Yosemite up to date to all required updates.
Any help would be greatly appreciated, im quite a patient person but this has me stumped.
cheers guys.
cheers guys.
