2015-05-22, 19:25
Hello,
I can't play dvd iso file with Kodibuntu (up-to-date).
Log below says libdvdnav can't find /VIDEO_TS/VIDEO_TS.IFO and /VIDEO_TS/VIDEO_TS.BUP, but I opened the iso and the files are there.
I can mount the iso on windows and play it just fine with VLC.
Path and filename contain some parenthesis, and I think it's the issue.
I have a few others dvd isos files and I can only play the ones with parenthesis in the path and filename.
Quote:19:16:59 T:140619132872640 DEBUG: OnKey: c (0xf043) pressed, action is ContextMenu
19:16:59 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers(/mnt/nas/Films/Benvenuti al sud (2010)/Benvenuti al sud (2010).iso)
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: dvdimage
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: adding player: DVDPlayer (1) for rule: dvdimage
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
19:16:59 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
19:16:59 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: matched 1 rules with players
19:16:59 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
19:16:59 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
19:16:59 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
19:16:59 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
19:16:59 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
19:16:59 T:140619132872640 DEBUG: CFavourites::Load - no system favourites found, skipping
19:16:59 T:140619132872640 DEBUG: CFavourites::Load - no userdata favourites found, skipping
19:16:59 T:140619132872640 INFO: Loading skin file: DialogContextMenu.xml, load type: KEEP_IN_MEMORY
19:16:59 T:140619132872640 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
19:17:01 T:140619132872640 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0
19:17:01 T:140619132872640 DEBUG: OnKey: down (0xf081) pressed, action is Down
19:17:01 T:140619132872640 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
19:17:01 T:140619132872640 DEBUG: OnKey: return (0xf00d) pressed, action is Select
19:17:01 T:140619132872640 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
19:17:01 T:140619132872640 DEBUG: OnPlayMedia /mnt/nas/Films/Benvenuti al sud (2010)/Benvenuti al sud (2010).iso
19:17:01 T:140619132872640 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
19:17:01 T:140619132872640 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
19:17:01 T:140619132872640 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
19:17:01 T:140619132872640 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
19:17:01 T:140619132872640 DEBUG: Loading settings for /mnt/nas/Films/Benvenuti al sud (2010)/Benvenuti al sud (2010).iso
19:17:01 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers(/mnt/nas/Films/Benvenuti al sud (2010)/Benvenuti al sud (2010).iso)
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: dvdimage
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: adding player: DVDPlayer (1) for rule: dvdimage
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
19:17:01 T:140619132872640 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
19:17:01 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: matched 1 rules with players
19:17:01 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
19:17:01 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
19:17:01 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
19:17:01 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
19:17:01 T:140619132872640 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
19:17:01 T:140619132872640 NOTICE: DVDPlayer: Opening: /mnt/nas/Films/Benvenuti al sud (2010)/Benvenuti al sud (2010).iso
19:17:01 T:140619132872640 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
19:17:01 T:140619132872640 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
19:17:01 T:140619132872640 DEBUG: LinuxRendererGL: Cleaning up GL resources
19:17:01 T:140619132872640 DEBUG: CLinuxRendererGL:reInit - precision of luminance 16 is 16
19:17:01 T:140617539634944 NOTICE: Thread DVDPlayer start, auto delete: false
19:17:01 T:140617539634944 NOTICE: Creating InputStream
19:17:01 T:140617539634944 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/libdvdnav-x86_64-linux.so)
19:17:01 T:140617539634944 DEBUG: Loading: /usr/lib/kodi/system/players/dvdplayer/libdvdnav-x86_64-linux.so
19:17:01 T:140617539634944 INFO: msg: libdvdnav: Using dvdnav version 4.2.1
19:17:02 T:140617539634944 INFO: msg: libdvdnavVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
19:17:02 T:140617539634944 INFO: msg: libdvdnavVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
19:17:02 T:140617539634944 DEBUG: libdvdread: Can't open file VIDEO_TS.IFO.
19:17:02 T:140617539634944 DEBUG: libdvdnav: vm: failed to read VIDEO_TS.IFO
19:17:02 T:140617539634944 ERROR: Error on dvdnav_open
19:17:02 T:140617539634944 ERROR: CDVDPlayer::OpenInputStream - error opening [/mnt/nas/Films/Benvenuti al sud (2010)/Benvenuti al sud (2010).iso]
19:17:02 T:140617539634944 NOTICE: CDVDPlayer::OnExit()
19:17:02 T:140617539634944 DEBUG: OnPlayBackStopped: play state was 1, starting 1
19:17:02 T:140617539634944 DEBUG: Thread DVDPlayer 140617539634944 terminating
19:17:02 T:140619132872640 DEBUG: OnPlayBackStopped: play state was 3, starting 0
19:17:02 T:140619132872640 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
19:17:02 T:140619132872640 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
19:17:02 T:140619132872640 ERROR: Playlist Player: skipping unplayable item: 0, path [/mnt/nas/Films/Benvenuti al sud (2010)/Benvenuti al sud (2010).iso]
