When ever I update my Apple Movie Trailers it has started to lock up whilst updating.
This can be at any time during the update process.
I am using XBMC 2
Any help appriciated.
Mike
so it gives you a message about version ?.?? is newer. Do you want to update?
You select yes and it locks up?
Sounds like a timeout issue maybe. Will look into it.
Thanks for the quick reply.
It starts updating then at random, it will just sit there and not progress any further.
If I use the remote I can hear it click but no response.
If I try to cancel it says canceling, but then does nothing else. Just sits there.
I have to reset the XBox.
I have only got it to update once in about a dozon tries.
On a last note, the search button is always greyed out.
Thanks Again.
Mike
Because those particular functions arent active yet. They are there cosmetically but not active within the script.
when i put 'warning.txt' to the skin folder, the rael path to the skin is changing
before
Apple Movie Trailers/skins/MC360/
after
Apple Movie Trailers/skins/*MC360/
oops, ok it's fixed along with a couple other things.
So everyone should update to the newest SVN or tagged version 0.93.5.
Depending on what version you have your cache may need to be recreated, so if it's a version 0.92.1 or before start fresh.
The buttons that are disabled will soon be enabled as I'm finishing the new database system now.
Edit: By the way smuto, that looks good.
I jnust committed a new version to svn (can't get it from the update button) it enables studio and favorites.
Do NOT update if you don't want trouble, theres bound to be some.
If you do, when it asks to load movie info into database. Answer Yes, or you WILL have trouble.
If you're daring, please check it out and post any problems.
* could a moderator combine these Apple Movie Trailer threads please? Thanks
