While watching a video that shows the buffering, toggle the keybaord 'o' key (brings up the OSD) and look for bottle necks, dropped frames, fetching, gfx limitations, or cpu threshold giving issues.
there u have it guys i edited the post
Looks like your hardware is fine, most of the errors are failures to connect, bad gateways, and server issues which could be related to your ISP, the server you're connecting with, the hops between you and the source.
<Connect, didn't get any data from stream.
<HTTP error 502 Bad Gateway
<skipping unplayable item
<Error creating demuxer
<Error, could not open file http://..
<failed to open source <http://
<FillBuffer - Reconnect, (re)try 1
<ailed: HTTP response code said error(22)
<ERROR: Failed to fetch checksum
<Failed: Timeout was reached(28)
Youtube should stream fine.
is there something i can do to make the buffering go away?
Yes...don't use banned addons
Try with local files and report back
(2015-05-24, 20:57)David1977 Wrote: [ -> ]Yes...don't use banned addons
What do you mean by banned addons
It seems you are using addons like 1channel for playback. Those addons are banned
http://kodi.wiki/view/Official:Forum_rul...ed_add-ons
So please check with supported addons like Youtube (what Patk already mentioned) or don't use those addons. There is no support for those addons in here. So you won't get help with buffering videos which came from these addons.
Yep. Most likely the issue is not on the user-side. Bootleg/pirated add-ons are typically hosted on file locker servers that are not designed to handle people using them as a video service, and speeds fluctuate on that server side.
