2015-05-24, 11:40
I tried using the SortTitle-Property for movies which are NOT part of a MovieSet, but this does not work because TMM (2.6.7) overwrites "always" the entered value with a "default-value".
To reproduce this behaviour follow these steps:
* Open Property-Editor for a Movie, which is not part of a MovieSet
* Enter a SortTitle
* Close Property-Editor (<OK>)
* Check corresponding NFO-File. You can see, the SortTitle-Tag is updated
* Reopen Property-Editor for this Movie. You can see, the SortTitle within Property-Editor is empty!
* Closing the Property-Editor with <OK> removes SortTitle also from NFO-File.
When you try to use the SortTitle for renaming the Files/Folder, you can enter any value you want, the entered SortTitle will never be used. This is extremely annoying with numeric Movie-Titles like "1984" or with Movie-Titles starting with symbols like '(', '#', ' " '.
It seems to me, that the SortTitle gets always automatic "recalculated" whenever it is used - independently what value was entered.
I tried removing all "titlePrefix" to deactivate this function, but this doesn't helped.
* Enter a SortTitle
