2015-05-24, 12:15
2015-05-24, 12:15
2015-05-24, 12:38
Install CCM Helix (Confluence Custom Mod) and simplify the theme as much as you want from within the skin settings - much easier: http://forum.kodi.tv/showthread.php?tid=212898
2015-05-24, 13:51
(2015-05-24, 12:38)jmh2002 Wrote: [ -> ]Install CCM Helix (Confluence Custom Mod) and simplify the theme as much as you want from within the skin settings - much easier: http://forum.kodi.tv/showthread.php?tid=212898
Thank you for fast and great reply jmh2002.
Its solve my problem!! Very nice!! But get me a new one.
How to re-enable this button after hide??
Claudio
2015-05-24, 14:40
If you still want to be able to use it, then instead of hiding it totally, bury it in a submenu or something similar
To re-enable it simply re add it from the skin settings. In the CCM thread you will find more info, but its simple enough.
2015-05-25, 14:57
This can be done with the vanilla Confluence skin.
In Home.xml, look for the following (around line 970):
and comment out the lines:
Save the file, and restart Kodi.
Settings can still accessed using the # key on your remote.
<item id="5">
<label>31959</label>
<onclick>ActivateWindow(Settings)</onclick>
<icon>-</icon>
<thumb>-</thumb>
</item>
<!--item id="5">
<icon>-</icon>
<thumb>-</thumb>
</item-->
2015-07-19, 03:34
Thank you in advance to anyone who can help out! I'm a newbie to Kodi, which I'm running on an Amazon Fire Stick (v.14.2). I've been playing around with the settings, and found a skin that gives me more flexibility as to what's displayed on the Home menu; Amber. My intention was to keep they System option on the main screen while ALSO having it on the Quit options (I love to tweak settings and access it a lot!). I must have inadvertently disabled System from the home menu and not properly enabled the Quit button b/c now neither are there and I can't figure out how to access the System Settings. I feel crippled not being able to access settings, and I'm trying to avoid doing a full reset b/c I've put a lot of effort/time into setting things up.
Can anyone suggest how I can access the System settings?
Thank you!
Thank you!
2015-08-02, 15:20
