Full Version: How to modify Menu to launch Kodi on M8N device
I have been using a M8N device running on kit kat and with a menu where XBMC was available as a main icon from the main page of TV BOX launcher.
Since I update with Kodi I don't know how to replace XBMC icon by a Kodi one (knowing that when I click on XBMC icon nothing happens now !!!) to have something like that (picture found on internet) :
Do you have any idea on how to configure this menu/launcher/icon ?
Not sure how to get a large KODI icon on your browser, but you can get a small one by selecting the + sign and checking or unchecking apps you want to appear on the bottom line. If you uncheck them all, then recheck them in order, you can order them from left to right.
My guess is there is probably an ini or setup file of some sort where the main icons are defined -it would seem that it must be configurable. Perhaps a little Google research on configuring android launchers is in order?
