Full Version: TMM won't start in fedora 22
Pages: 1 2
I just switched to fedora yesterday. Checked if java, jre was installed and then I proceeded to start my backed up installation of TMM, but it failed. Posting launcher log below. I also tried with a new installation, same issue.
http://www.xbmclogs.com/pkrdygggy
your launcher.log only says that google code is not reachable (dns setting?)
are there any other hints, when you start tmm from a command line/terminal?
(2015-05-28, 06:55)mlaggner Wrote: [ -> ]your launcher.log only says that google code is not reachable (dns setting?)
Terminal shows no error or any info, just goes to the next line. Tried opening both tmm and tmm updater.
Not sure if it's an issue with my dns. Everything else can access internet.
is anything being written to the tmm logs? (folder logs)
(2015-05-28, 19:35)mlaggner Wrote: [ -> ]is anything being written to the tmm logs? (folder logs)
Nope.. nothing is being written in logs folder. This is the current launcher log
http://www.xbmclogs.com/pwx0vj1rf
and what about starting with command from launcher.log?
/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.45-38.b14.fc22.x86_64/jre/bin/java
  -classpath
  /home/akya/TMM/./tmm.jar:/home/akya/TMM/./lib/DJNativeSwing-SWT.jar:/home/akya/TMM/./lib/DJNativeSwing.jar:/home/akya/TMM/./lib/JSplitButton.jar:/home/akya/TMM/./lib/JTattoo.jar:/home/akya/TMM/./lib/LightBox.jar:/home/akya/TMM/./lib/Scaling-bin.jar:/home/akya/TMM/./lib/api-common.jar:/home/akya/TMM/./lib/asm.jar:/home/akya/TMM/./lib/betterbeansbinding-core.jar:/home/akya/TMM/./lib/betterbeansbinding-el.jar:/home/akya/TMM/./lib/betterbeansbinding-swingbinding.jar:/home/akya/TMM/./lib/commons-codec.jar:/home/akya/TMM/./lib/commons-io.jar:/home/akya/TMM/./lib/commons-lang3.jar:/home/akya/TMM/./lib/core.jar:/home/akya/TMM/./lib/fanarttvapi.jar:/home/akya/TMM/./lib/forms.jar:/home/akya/TMM/./lib/glazedlists.jar:/home/akya/TMM/./lib/gson.jar:/home/akya/TMM/./lib/httpclient.jar:/home/akya/TMM/./lib/httpcore.jar:/home/akya/TMM/./lib/httpmime.jar:/home/akya/TMM/./lib/image-viewer.jar:/home/akya/TMM/./lib/imgscalr-lib.jar:/home/akya/TMM/./lib/jackson-annotations.jar:/home/akya/TMM/./lib/jackson-core.jar:/home/akya/TMM/./lib/jackson-databind.jar:/home/akya/TMM/./lib/jcl-over-slf4j.jar:/home/akya/TMM/./lib/jdom.jar:/home/akya/TMM/./lib/jgoodies-common.jar:/home/akya/TMM/./lib/jmte-unbundled.jar:/home/akya/TMM/./lib/jna.jar:/home/akya/TMM/./lib/joda-time.jar:/home/akya/TMM/./lib/json-20131018.jar:/home/akya/TMM/./lib/jsoup.jar:/home/akya/TMM/./lib/jtidy.jar:/home/akya/TMM/./lib/log4j-over-slf4j.jar:/home/akya/TMM/./lib/logback-classic.jar:/home/akya/TMM/./lib/logback-core.jar:/home/akya/TMM/./lib/objectdb.jar:/home/akya/TMM/./lib/platform.jar:/home/akya/TMM/./lib/quaqua-filechooser-only.jar:/home/akya/TMM/./lib/resources.jar:/home/akya/TMM/./lib/retrofit.jar:/home/akya/TMM/./lib/rottentomatoesapi.jar:/home/akya/TMM/./lib/slf4j-api.jar:/home/akya/TMM/./lib/themoviedbapi.jar:/home/akya/TMM/./lib/thetvdbapi.jar:/home/akya/TMM/./lib/trakt-java.jar:/home/akya/TMM/./lib/twinkle.jar:/home/akya/TMM/./lib/xmlrpc-client.jar:lib/swt.jar:locale/*
  -Dcom.threerings.getdown=true
  -Xms64m
  -Xmx512m
  -Xss512k
  -Djava.net.preferIPv4Stack=true
  -Dfile.encoding=UTF-8
  -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/TextMatchers,matches
  -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/BoyerMooreCaseInsensitiveTextSearchStrategy,indexOf
  -Djna.nosys=true
  org.tinymediamanager.TinyMediaManager
New installation, just extracted.
Launched from terminal.
tmm.log in Logs folder is empty
Launcher.log is -
2015/05/29 11:50:55:120 INFO m.a: ------------------ VM Info ------------------
2015/05/29 11:50:55:139 INFO m.a: -- OS Name: Linux
2015/05/29 11:50:55:139 INFO m.a: -- OS Arch: amd64
2015/05/29 11:50:55:139 INFO m.a: -- OS Vers: 4.0.4-301.fc22.x86_64
2015/05/29 11:50:55:140 INFO m.a: -- Java Vers: 1.8.0_45
2015/05/29 11:50:55:140 INFO m.a: -- Java Home: /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.45-38.b14.fc22.x86_64/jre
2015/05/29 11:50:55:140 INFO m.a: -- User Name: root
2015/05/29 11:50:55:140 INFO m.a: -- User Home: /root
2015/05/29 11:50:55:140 INFO m.a: -- Cur dir: /home/akya/tmm_2.6.7_r2013_linux
2015/05/29 11:50:55:140 INFO m.a: ---------------------------------------------
2015/05/29 11:50:55:334 INFO m.a: ---------------- Proxy Info -----------------
2015/05/29 11:50:55:334 INFO m.a: -- Proxy Host: null
2015/05/29 11:50:55:334 INFO m.a: -- Proxy Port: null
2015/05/29 11:50:55:334 INFO m.a: ---------------------------------------------
2015/05/29 11:50:55:355 INFO m.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManager.new]
2015/05/29 11:50:55:355 INFO m.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManagerUpd.new]
2015/05/29 11:50:55:355 INFO m.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManagerCMD.new]
2015/05/29 11:50:55:355 INFO m.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] tinyMediaManagerOSX.sh]
2015/05/29 11:50:55:355 INFO m.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] JavaApplicationStub.new]
2015/05/29 11:50:55:356 INFO m.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] Info.plist]
2015/05/29 11:50:55:357 INFO m.a: Skipping [quals=linux-i386, osname=linux, osarch=amd64, key=resource, value=[linux-i386] native/linux-i386/libmediainfo.so]
2015/05/29 11:50:55:357 INFO m.a: Skipping [quals=linux-i386, osname=linux, osarch=amd64, key=resource, value=[linux-i386] native/linux-i386/libzen.so]
2015/05/29 11:50:55:357 INFO m.a: Skipping [quals=linux-i686, osname=linux, osarch=amd64, key=resource, value=[linux-i686] native/linux-i686/libmediainfo.so]
2015/05/29 11:50:55:357 INFO m.a: Skipping [quals=linux-i686, osname=linux, osarch=amd64, key=resource, value=[linux-i686] native/linux-i686/libzen.so]
2015/05/29 11:50:55:357 INFO m.a: Skipping [quals=mac os x-x86_64, osname=linux, osarch=amd64, key=resource, value=[mac os x-x86_64] native/mac-x86_64/libmediainfo.dylib]
2015/05/29 11:50:55:357 INFO m.a: Skipping [quals=mac os x-i386, osname=linux, osarch=amd64, key=resource, value=[mac os x-i386] native/mac-i386/libmediainfo.dylib]
2015/05/29 11:50:55:358 INFO m.a: Skipping [quals=windows-amd64, osname=linux, osarch=amd64, key=resource, value=[windows-amd64] native/windows-amd64/MediaInfo.dll]
2015/05/29 11:50:55:358 INFO m.a: Skipping [quals=windows-x64, osname=linux, osarch=amd64, key=resource, value=[windows-x64] native/windows-x64/MediaInfo.dll]
2015/05/29 11:50:55:358 INFO m.a: Skipping [quals=windows-x86, osname=linux, osarch=amd64, key=resource, value=[windows-x86] native/windows-x86/MediaInfo.dll]
2015/05/29 11:50:55:358 INFO m.a: Skipping [quals=windows-x86, osname=linux, osarch=amd64, key=resource, value=[windows-x86] native/windows-x86/mingwm10.dll]
2015/05/29 11:50:55:358 INFO m.a: Skipping [quals=mac os x-x86_64, osname=linux, osarch=amd64, key=resource, value=[mac os x-x86_64] native/mac-x86_64/libquaqua.jnilib]
2015/05/29 11:50:55:359 INFO m.a: Skipping [quals=mac os x-x86_64, osname=linux, osarch=amd64, key=resource, value=[mac os x-x86_64] native/mac-x86_64/libquaqua64.jnilib]
2015/05/29 11:50:55:359 INFO m.a: Skipping [quals=mac os x-x86_64, osname=linux, osarch=amd64, key=resource, value=[mac os x-x86_64] native/mac-x86_64/libquaqua64.dylib]
2015/05/29 11:50:55:359 INFO m.a: Skipping [quals=mac os x-i386, osname=linux, osarch=amd64, key=resource, value=[mac os x-i386] native/mac-i386/libquaqua.jnilib]
2015/05/29 11:50:55:359 INFO m.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Dapple.awt.graphics.UseQuartz=true]
2015/05/29 11:50:55:359 INFO m.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Xdock:name=tinyMediaManager]
2015/05/29 11:50:55:365 INFO m.a: Attempting to refetch 'digest.txt' from 'http://tinymediamanager.googlecode.com/svn/dist/digest.txt'.
2015/05/29 11:50:55:785 INFO m.a: remove verification files? true
2015/05/29 11:50:55:801 INFO m.a: Able to lock for updates: true
2015/05/29 11:50:55:802 INFO m.a: Launching without update!
2015/05/29 11:50:55:902 INFO m.a: Didn't find any custom environment variables, not setting any.
2015/05/29 11:50:55:902 INFO m.a: Running /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.45-38.b14.fc22.x86_64/jre/bin/java
  -classpath
  /home/akya/tmm_2.6.7_r2013_linux/./tmm.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/DJNativeSwing-SWT.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/DJNativeSwing.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/JSplitButton.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/JTattoo.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/LightBox.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/Scaling-bin.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/api-common.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/asm.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-el.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-swingbinding.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-codec.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-io.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-lang3.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/fanarttvapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/forms.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/glazedlists.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/gson.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpclient.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpcore.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpmime.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/image-viewer.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/imgscalr-lib.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-annotations.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-databind.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jcl-over-slf4j.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jdom.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jgoodies-common.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jmte-unbundled.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jna.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/joda-time.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/json-20131018.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jsoup.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jtidy.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/log4j-over-slf4j.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/logback-classic.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/logback-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/objectdb.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/platform.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/quaqua-filechooser-only.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/resources.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/retrofit.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/rottentomatoesapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/slf4j-api.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/themoviedbapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/thetvdbapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/trakt-java.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/twinkle.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/xmlrpc-client.jar:lib/swt.jar:locale/*
  -Xms64m
  -Xmx512m
  -Xss512k
  -Djna.nosys=true
2015/05/29 11:50:55:903 INFO m.a: Dropping status 'm.launching'.
try to run the following command in a terminal
Quote:cd /home/akya/tmm_2.6.7_r2013_linux/ && /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.45-38.b14.fc22.x86_64/jre/bin/java -classpath /home/akya/tmm_2.6.7_r2013_linux/./tmm.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/DJNativeSwing-SWT.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/DJNativeSwing.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/JSplitButton.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/JTattoo.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/LightBox.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/Scaling-bin.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/api-common.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/asm.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-el.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-swingbinding.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-codec.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-io.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-lang3.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/fanarttvapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/forms.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/glazedlists.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/gson.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpclient.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpcore.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpmime.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/image-viewer.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/imgscalr-lib.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-annotations.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-databind.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jcl-over-slf4j.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jdom.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jgoodies-common.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jmte-unbundled.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jna.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/joda-time.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/json-20131018.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jsoup.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jtidy.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/log4j-over-slf4j.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/logback-classic.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/logback-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/objectdb.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/platform.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/quaqua-filechooser-only.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/resources.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/retrofit.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/rottentomatoesapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/slf4j-api.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/themoviedbapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/thetvdbapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/trakt-java.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/twinkle.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/xmlrpc-client.jar:lib/swt.jar:locale/* -Dcom.threerings.getdown=true -Xms64m -Xmx512m -Xss512k -splashConfusedplashscreen.png -Djava.net.preferIPv4Stack=true -Dfile.encoding=UTF-8 -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/TextMatchers,matches -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/BoyerMooreCaseInsensitiveTextSearchStrategy,indexOf -Djna.nosys=true org.tinymediamanager.TinyMediaManager
I got this after running the code you posted -
[akya@quady ~] $ cd /home/akya/tmm_2.6.7_r2013_linux/ && /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.45-38.b14.fc22.x86_64/jre/bin/java -classpath /home/akya/tmm_2.6.7_r2013_linux/./tmm.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/DJNativeSwing-SWT.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/DJNativeSwing.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/JSplitButton.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/JTattoo.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/LightBox.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/Scaling-bin.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/api-common.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/asm.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-el.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-swingbinding.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-codec.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-io.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-lang3.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/fanarttvapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/forms.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/glazedlists.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/gson.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpclient.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpcore.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpmime.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/image-viewer.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/imgscalr-lib.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-annotations.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-databind.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jcl-over-slf4j.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jdom.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jgoodies-common.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jmte-unbundled.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jna.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/joda-time.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/json-20131018.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jsoup.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jtidy.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/log4j-over-slf4j.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/logback-classic.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/logback-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/objectdb.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/platform.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/quaqua-filechooser-only.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/resources.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/retrofit.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/rottentomatoesapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/slf4j-api.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/themoviedbapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/thetvdbapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/trakt-java.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/twinkle.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/xmlrpc-client.jar:lib/swt.jar:locale/* -Dcom.threerings.getdown=true -Xms64m -Xmx512m -Xss512k -splash:splashscreen.png -Djava.net.preferIPv4Stack=true -Dfile.encoding=UTF-8 -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/TextMatchers,matches -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/BoyerMooreCaseInsensitiveTextSearchStrategy,indexOf -Djna.nosys=true org.tinymediamanager.TinyMediaManager
CompilerOracle: exclude ca/odell/glazedlists/impl/filter/TextMatchers.matches
CompilerOracle: exclude ca/odell/glazedlists/impl/filter/BoyerMooreCaseInsensitiveTextSearchStrategy.indexOf
=== tinyMediaManager (c) 2012-2015 Manuel Laggner ===
    SYNTAX: java -jar tmm.jar <parameters>
PARAMETERS:
    -updateMovies        update all movie datasources and add new movies/files to DB
    -updateMoviesX       replace X with 1-9 - just updates a single movie datasource; ordering like GUI
    -updateTv            update all TvShow datasources and add new TvShows/episodes to DB
    -updateTvX           replace X with 1-9 - just updates a single TvShow datasource; ordering like GUI
    -update              update all (short for '-updateMovies -updateTv')
    -scrapeNew           auto-scrape (force best match) new found movies/TvShows/episodes from former update(s)
    -scrapeUnscraped     auto-scrape (force best match) all movies, which have not yet been scraped (not for TV/episodes!)
    -renameNew           rename & cleanup of the new found movies/TvShows/episodes
    -checkFiles          does a physical check, if all files in DB are existent on filesystem (might take long!)
[akya@quady tmm_2.6.7_r2013_linux] $
This is the "command line" version of TMM.
Interesting.
Is this a box without GUI?!
Java thinks you are in "headless" mode...
Or are there separate Java packages for GUI?
you might want to try the same command again, but add "-Djava.awt.headless=false" (as second-last parameter)
Does this then work?
exactly what I thought:
on linux there is in general a java "headless" package (with java core packages) and a java package for UI access
unfortunately I could not get a hint which packages to install for Fedora 22.. (I am not familiar with Fedora..)
(2015-05-29, 19:55)myron Wrote: [ -> ]This is the "command line" version of TMM.
Interesting.
No.. Not a headless box. I tried the change you mentioned. Check if I did it right. -
[akya@quady ~] $ cd /home/akya/tmm_2.6.7_r2013_linux/ && /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.45-38.b14.fc22.x86_64/jre/bin/java -classpath /home/akya/tmm_2.6.7_r2013_linux/./tmm.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/DJNativeSwing-SWT.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/DJNativeSwing.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/JSplitButton.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/JTattoo.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/LightBox.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/Scaling-bin.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/api-common.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/asm.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-el.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/betterbeansbinding-swingbinding.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-codec.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-io.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/commons-lang3.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/fanarttvapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/forms.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/glazedlists.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/gson.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpclient.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpcore.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/httpmime.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/image-viewer.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/imgscalr-lib.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-annotations.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jackson-databind.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jcl-over-slf4j.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jdom.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jgoodies-common.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jmte-unbundled.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jna.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/joda-time.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/json-20131018.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jsoup.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/jtidy.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/log4j-over-slf4j.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/logback-classic.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/logback-core.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/objectdb.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/platform.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/quaqua-filechooser-only.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/resources.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/retrofit.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/rottentomatoesapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/slf4j-api.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/themoviedbapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/thetvdbapi.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/trakt-java.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/twinkle.jar:/home/akya/tmm_2.6.7_r2013_linux/./lib/xmlrpc-client.jar:lib/swt.jar:locale/* -Dcom.threerings.getdown=true -Xms64m -Xmx512m -Xss512k -splash:splashscreen.png -Djava.net.preferIPv4Stack=true -Dfile.encoding=UTF-8 -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/TextMatchers,matches -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/BoyerMooreCaseInsensitiveTextSearchStrategy,indexOf -Djava.awt.headless=false -Djna.nosys=true org.tinymediamanager.TinyMediaManager
2015-05-29 23:42:08,609 INFO  [main] org.tinymediamanager.TinyMediaManager:121 - =====================================================
2015-05-29 23:42:08,652 INFO  [main] org.tinymediamanager.TinyMediaManager:122 - === tinyMediaManager (c) 2012-2015 Manuel Laggner ===
2015-05-29 23:42:08,653 INFO  [main] org.tinymediamanager.TinyMediaManager:123 - =====================================================
2015-05-29 23:42:08,668 INFO  [main] org.tinymediamanager.TinyMediaManager:124 - tmm.version      : 2.6.7 (r2013)
2015-05-29 23:42:09,127 WARN  [main] org.tinymediamanager.core.Settings:192 - could not load settings - creating default ones...
Exception in thread "main" java.lang.UnsatisfiedLinkError: Can't load library: /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.45-38.b14.fc22.x86_64/jre/lib/amd64/libawt_xawt.so
    at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1825)
    at java.lang.Runtime.load0(Runtime.java:809)
    at java.lang.System.load(System.java:1086)
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1937)
    at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1843)
    at java.lang.Runtime.loadLibrary0(Runtime.java:870)
    at java.lang.System.loadLibrary(System.java:1122)
    at java.awt.Toolkit$3.run(Toolkit.java:1640)
    at java.awt.Toolkit$3.run(Toolkit.java:1638)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.awt.Toolkit.loadLibraries(Toolkit.java:1637)
    at java.awt.Toolkit.<clinit>(Toolkit.java:1672)
    at java.awt.EventQueue.isDispatchThread(EventQueue.java:1041)
    at javax.swing.SwingUtilities.isEventDispatchThread(SwingUtilities.java:1361)
    at javax.swing.event.SwingPropertyChangeSupport.firePropertyChange(SwingPropertyChangeSupport.java:91)
    at java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:263)
    at org.tinymediamanager.core.AbstractModelObject.firePropertyChange(AbstractModelObject.java:96)
    at org.tinymediamanager.core.Settings.addVideoFileTypes(Settings.java:287)
    at org.tinymediamanager.core.Settings.writeDefaultSettings(Settings.java:461)
    at org.tinymediamanager.core.Settings.getInstance(Settings.java:194)
    at org.tinymediamanager.Globals.<clinit>(Globals.java:27)
    at org.tinymediamanager.TinyMediaManager.main(TinyMediaManager.java:126)
(2015-05-29, 20:04)mlaggner Wrote: [ -> ]exactly what I thought:
I am not that familiar either. First time trying Smile
I would check which java is installed
yum list installed | grep java
When there is only the headless version installed, try to search the full Java package ( http://www.2daygeek.com/openjdk-8-instal...os-fedora/ ).
If
it is still not working, install the development version (java-1.8.0-openjdk-devel.x86_64 : OpenJDK Development Environment) - this must have everything included
(2015-05-29, 20:24)mlaggner Wrote: [ -> ]I would check which java is installed
If
grep showed that I had headless version as you guessed. Installed the devel package and it worked. Finally !! Sorry for the trouble guys. and huge thanks for the help Smile
As of Fedora 24 to run tinymediamanager GUI
Need to install java jdk devel package for GUI support
sudo dnf install java-1.8.0-openjdk-devel.x86_64
(If not using x86_64 machine: find your devel package with:
dnf search java |grep openjdk)
Also needed libmediainfo
sudo dnf install libmediainfo
tinymediamanager should start with
cd /"path to tmm directory"
./tinymediamanager.sh
Add to installation wiki?
Pages: 1 2
