Full Version: $35 Raspberry Pi clone board with Quad-core A9 and PowerVR544 GPU
I saw this Lemon Pi crowdfunding campaign on https://www.indiegogo.com/projects/lemon...urce-board .I want to know what's the differences of power consumption and computing capacity between ARM A7 and A9? It seems that this board also has 40-pin connect.So can the expansion board I am using on RPi2 work with this clone board directly?
I think KODI can run on it.
Thanks for reply.
http://igg.me/at/lemonpi
I saw this Lemon Pi crowdfunding campaign on https://www.indiegogo.com/projects/lemon...ce-board.I want to know what's the differences of power consumption and computing capacity between ARM A7 and A9? It seems that this board also has 40-pin connect.So can the expansion board I am using on RPi2 work with this clone board directly? Thanks for reply.
Dude its a bad idea to make the same post 3 times in different forums. Be warned (i see you are new so please get used to the netiquette in forums).
merged & moved.
