2015-03-04, 08:06
I am wondering when we're going to realize that pretty much this entire home automation conversation has virtually nothing to do with the topic.
(2015-03-04, 08:06)natethomas Wrote: [ -> ]I am wondering when we're going to realize that pretty much this entire home automation conversation has virtually nothing to do with the topic.
(2015-03-03, 12:44)RockerC Wrote: [ -> ]suggested project idea could be to copy the PVR concept and design a similar common frontend GUI interface and extend the addons API in Kodi, and make a reference client addon.If above is true then perhaps the core concepts from Ninja Sphere or Ninja Blocks could be used as a reference for a project to extent Kodi's addon APIs and the JSON-RPC protocols:
(2015-03-03, 22:28)Martijn Wrote: [ -> ]Unfortunately it does look like today many if not most open source software clients for the Internet of Things looks to are written in JavaScript or Java, however fortunately more are written in either JavaScript than Java so should be more portable.(2015-03-03, 22:26)NEOhidra Wrote: [ -> ]Java.... Ugh(2015-03-03, 13:17)Martijn Wrote: [ -> ]the problem will all home automation currently is there's not a single (opensource) API that can be used to rule them all. Maybe open source AllJoyn SDK could bring some difference in that.I haven't used it but isn't OpenHAB something that unifies different automation technologies?
(2015-03-04, 10:29)Ned Scott Wrote: [ -> ]I found out that the API-end of things is really easy (easy enough for me to understand), so it's probably not a good GSoC idea after all.If the above will not happen as an one-for-all concept then maybe worth checking out Home Assistant's scripts for reusable code as reference home automation platform addon for Kodi.
(2015-03-03, 14:08)da-anda Wrote: [ -> ]Which features would be needed besides of dimming lights in room X, because I don't think you can easily come up with a generic UI for everything supported by home automatation out there. Also configuration of complex tasks might be a PITA to do in a 10foot interface and probably better done via a webinterface or a standalone app. So why does it have to be part of Kodi and why can't it simply be an external cross platform tool providing the generic API to be extended by addons which is using Kodis JSON-RPC (or any other OpenSource media center interface) to trigger the home automatation tasks? Such a tool might be of much more use then a stripped down Kodi integration
(2015-04-16, 13:03)David1977 Wrote: [ -> ]Don´t know if this is really related....but:
http://forum.kodi.tv/showthread.php?tid=...light=fhem
